Question about Remington 16" Electric Chain Saw Assembled 3.0 Peak
Leaking oil. comes out and is all over the bottom of the saw.
    Sergeant:
  • 316 Answers
How do yo stop oil leak?
replace the oil tank
it will leak out if the saw is not in use
Oct 02, 2017 | Garden
How to stop the bar chain oil leak
There should be an adjusting screw around the bar somewhere. Turn it anti clockwise until it stops and then just crack it one turn. If it still leaks too much then turn it down slightly.also try and store the saw on its side to stop the oil just coming out.
Apr 20, 2017 | Garden
Chain saw setting not running the bar oil leaks out, but doesn't if laying on its side
what kind of saw? where is it coming from? all saws will leak some bar oil so how bad is the leak?
Sep 22, 2013 | Husqvarna Garden
Leaks chain oil out while setting, not running
The oil inside the tank will expand and contract with heat and cold from where it is stored. It is good to check and see that there is nothing between the bar and the body of the saw which causes the two parts from having a good seal and leaking oil instead of having all the oil go into the bar channel. Take the side cover and bar off the chainsaw and clean where all these parts meet. Sometimes it will not leak as much. If you store a saw in a place that has temperature fluctuations some oil is always going to leak out. I've always stored mine in a plastic container with rags on the bottom.
Sep 22, 2013 | Husqvarna Chain Saw 20" Bar
My 450 Husky has a leak from the oil tank at the bottom of the saw. Is there an oil plug at the bottom of the tank that come loose or unscrewed??????
if same as mine there is a screw under side to stop oil flow altogether for storage or to slow down if excessive flow but remember to open if using so the chain doesn`t burn out to soon
Jan 14, 2013 | Husqvarna 450 e-series 18" Chain Saw
Leaks chain oil when not in use
two things come to mind. 1. The oil adjustment screw on the bottom of the saw is set too high for the type of cutting you're doing.
2.If the oil setting is too high, your saw will have an excess residue of oil on the , chain, sprocket, and oiler. When you set the saw down Oil runs out. Try setting the oil adjustment screw back a turn. Find the screw on the bottom of the saw., or check the owners manual. Good Luck! Alvin
Aug 31, 2011 | Echo CS310 14" Bar Length Fully Assembled...
Kawasaki Oil Pump Leak
Bad seal in the pump itself. It is like a weep hole in a water pump. It is letting you know it is time to be replaced.
Jun 09, 2009 | 1996 kawasaki ZX-6R Ninja
Craftsman 2.3 14" / Poulan 1800 auto oiler leaking
Loosten the oil filler cap before putting it away. The tank is pressurized to force oil to the chain. Relieve the pressure before storing. Lou
Jun 05, 2009 | Poulan 1630 16" Chain Saw
Bar oil leaking
My guess is the tube has come loose inside.
Apr 19, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Remington 16" Electric Chain Saw Assembled 3.0 Peak Logo
168 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
