Comes up succesfully copied but wont let me finalise
Programmes record ok put in blank dvd, says succesfully copied message stays on screen and wont let me go to the next stage to finalise
    Guru:
  • 513 Answers
This is almost always a laser problem within the recorder. The recorder can write the disc but needs to write the TOC (table of contents) and can't do it (That's finalising). On occasion, the make of the DVD-r or DVD+r (they are different!) can fail to work on some machines. Try a different make of disc.
Posted on Feb 22, 2012
  • 236 Answers
SOURCE: how to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Posted on Feb 09, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Can't finalise dvd containing AVI movies copied from USB
I would use your PC to finalize discs containing AVI files. There just isn't a way to do it from the Philips. I personally use Dr. Divx, but there are many programs out there that will do this.
Posted on Sep 04, 2008
  • 35 Answers
SOURCE: Can't finalising the recorded discs, and can't record at high speed from SKY box to DVD recorder.
instruction man available on line
plug the sky output cable directly into the recorder then press record
Posted on Jun 01, 2009
SOURCE: Funai VCR/DVD recorder DVR 2737. My -R discs
I was advised to try another make of blank discs. I bought Sony discs & they worked ok. I had been using supermarket own brand.
Posted on Oct 18, 2009
Sebin
  • 712 Answers
SOURCE: I own the sony dvd
Does the DVD work fine on your computer and have a problem only when it is put in the DVD player?
Posted on Sep 09, 2010
Can anyone with a RH1777 help me finalise my dvd blank disk with his/her recorder?
If you can't find someone with the same recorder you could try putting the DVD into a computer DVD drive. It might be possible to get the video files off the DVD. DVD files are called VOB. You can get free software that will play them. It might even rip the files from the disc for you. You can then transfer them to a DVD disc using the computer.
Jan 06, 2015 | LG RH1777 DVD Recorder
Machine will not recognise a new disc when trying to copy a recording
Did the previous machine show EXACTLY the same problem, or did that machine have another issue?
Regarding this one, does the DVD drive respond well to playback discs, such as commercial release DVDs, or DVDs recorded on other machines? Does it play back CDs OK? If it passes these tests, move on to-
I suggest trying to record on different discs - such as a DVD-RAM, or on a different brand of DVD-R, or DVD-Rs from a different batch to your current ones.
If the machine succeeds here, all good and well, if it fails at this point, it seems the machine is faulty and should be returned.
Oct 09, 2014 | Panasonic DMR-EX773 DVD Player/Recorder -...
Trying to write to blank disk first time (Memorex CD-RW). Get message: Record failed: wrong format for re-write Spectroniq SDR-205 DVD Recorder
Some DVD recorders cannot write CD-RW - only DVD-RW (+ and -) as well as DVD-R (+ and -) (this depends on the brand/model). This unit probably does not support CD recording. Try using DVD-RW instead for this machine - see if it records that (do not finalise even if unit prompts you to with an on-screen message prior to ejecting disc).
There are DVD players and recorders which can play CD-RW (mp3, jpegs etc.) but I don't know of any which record this format (a PC CD/DVD-ROM drive can do this though).
Mar 09, 2011 | Televison & Video
My DVD recorder doesn;t record. When I go to replay there is nothing on the Recorded list. (The message PSO is showing on the front of the recorder.Is this coneected?)
Ok recording is impossible.
1.this unit may not record programs that contain copy protection signal.
2.Check that there is nothing on the disc to start off with.
3.check that the disc is CPRM compatible.copy onc programmes can only be copied onto the disc which is CPRM compatible.
4.check if the the disc is protected or finalised.Undo the protection or the finalisation.
5.DVD-RW usually once formatted in another unit cannot be recorded in your unit unless formatted.
6.Check all connections are properly made.
Oct 18, 2009 | Televison & Video
Jun 01, 2009 | Televison & Video
Recorded discs wont play on an other dvd player
you have to finalise the disc when finished recording then it plays on any dvd player
Feb 15, 2009 | Philips DVDR3380/05 DVD Recorder
Hi i have just bought a samsung dvd-sr150m of ebay the problem is,i tried to put a to put a new tevion 4.7gb dvd rwto recorder a programme but a message came on the screen unable to record or play this...
Some DVD recorders don't like some types of blank discs. You could have two discs the same but made by different companys and it might only record to one. Also this recorder will only record to - discs eg. DVD-R, DVD-R DL and DVD-RW. Hope this helps.
Aug 16, 2008 | Televison & Video
Any clues on how to copy multiple programmes from my hd to a dvd?
Depending on the DVD Media used.
If you used DVD-R Or DVD+R, then these are write once Only.
Once data has been written, and finalised by writting the Table-of-Contents to the Disk. Then no-more can be added. Hence read-Only.
If you use RW/ DVDs then they can be written to several Times. Although your Player may insist on you Formatting/Erasing any previous Data from the Disk. Before re-writing.
If you are using Write Once only media i.e DVD-R Or +R.
Then it would be a good suggestion to write approximately 4 gig of data Or between 2-3 Hours Of entertainment, to 1 Disk.
Re-Writables are the Practical option For You.
Mike @ compurepair.
Feb 16, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
"Recorded" or "Blank"? this is the Problem!
Check to see what format you are able to play on you Laptop
Sometimes they only work on some formats. Also make sure you are not recording in progressive scan
Jan 21, 2008 | Samsung DVD-R155
My dvd recorder no longer records
take your DVD player to a tech and your problem will be all over.good luck
May 17, 2007 | Funai FDRV90E DVD Recorder/VCR
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
