Question about Cadkey Corp Cadkey 19 Full Version for PC
I NEED TO DOWNLOAD CADKEY 7.5 AND I HAVE CADKET19 BUT I NEED TO RUN A PROGRAM ON CADKEY 7.5
I USE WINDOWS XP PROFESSIONAL
3 Suggested Answers
SOURCE: CADKEY 97
I had a similar problem trying to run under Windows XP and 2000 Pro.
I deleted the file named opengl32.dll from the Cadkey directory and now everything works fine.
By the way, Cadkey would load up and it seemed to be OK until I needed to type anything in, then it would make a warning sound and ignored the key strokes.
I hope this helps and works for you.
Posted on Mar 14, 2009
SOURCE: I have tried to install CADKEY 97 in a Windows 7
yes can be, just follow these steps:
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Posted on Dec 06, 2010
Does cadkey 19 run in windows 8
Yes, it does! So far I've run it on every MS ISO but 10. It look like thats going to be possible too. I have Cadkey 19 full. Every thing works. See me on GrabCad.com search Rob Hart. All drawn on Cadkey 19 and rendered with the latest veiwer.
Jul 31, 2014 | Cadkey Corp Cadkey 19 Full Version for PC
I've got this laptop ACER ASPIRE 5742G it runs on windows 7 -- 5GB memory , 500 GB HHD ; intel core i5-460M ... some of my program run on Microsoft Windows XP Professional Version 2002 Service...
You don't want to download any program to run programs compatible for windows XP, you can find a built in program coming with windows 7, and it is very easy to do,
go to control panel and open troubleshoot, then select programs, click next, after scanning it will all the programs that installed on your laptop, then select any programs which has compatibility problem with windows 7,
then you can see one option to start that program with Windows XP compatibility mode, after opening that software, click on next, and save that settings,,,,
finished....
you can fix all problems,
I hope it will be useful for you, so don't forget to rate me if you are happy
Thank you
Sep 03, 2011 | Microsoft Windows XP Professional With...
Does CAD KEY 19 work in windows 7 ?
If you run it in Windows 7 in Windows 95/98/00 or NT 4.x compatibility mode then there is no reason why it wouldn't work. To do this;
1. Right-click on the executable (.exe) file and click on 'Properties'
2. Click on the 'Compatibility' tab
3. Check the box next to 'Run this program in compatibility mode for:'
4. Select 'Windows 98/Windows Me', 'Windows 2000' or 'Windows NT 4.0 (Service Pack 5)'
5. Click 'Apply' then 'OK'
6. Double-click the executable (.exe) file to open.
Hope this helps!
Regards,
Matt
Mar 03, 2011 | Cadkey Corp Cadkey 19 Full Version for PC
My old computer with a Borland dBase 5.0 program on it crashed but the hard drive was salvaged and I have hooked it up to my new computer. However, my old computer ran Windows XP on 32 bit, the new one...
Do I need Windows XP Mode?
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software. Visit the Windows 7 Compatibility Center to find software that works with Windows 7.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
It's the best of both worlds: The new Windows XP Mode lets you run older Windows XP business software right on your Windows 7 desktop.
Designed primarily with small- and medium-sized businesses in mind, Windows XP Mode comes as a separate download and works only with Windows 7 Professional, Ultimate, and Enterprise. Windows XP Mode also requires virtualization software such as Windows Virtual PC. Both are available free on the Microsoft website.
Download
Learn how
Jan 23, 2011 | Borland DBASE 5.0 Upgrade Version Academic...
Will not function with Windows 7, what is wrong?
Not all programs that worked in Windows XP will run in Windows Vista or Windows 7.
I suggest you try compatibility mode to see if it helps.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1) Right click on the Program
2) Click on Properties
3) Click on Compatibility tab
4) Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
If the compatibility is not successful, then try and runthe Program Compatibility troubleshooter:
1. Open the Program Compatibility troubleshooter by clicking theStart button.
Then click Control Panel. In the search box, type troubleshooter, and then clickTroubleshooting. Under Programs, clickRun programs made for previous versions of Windows.
2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
If you run Windows 7 Professional or Ultimate version, install Windows Virtual PC and Windows XP mode (http://www.microsoft.com/windows/virtual-pc/default.aspx) and execute your software in Windows XP.
If you run Windows 7 Home Premium, try VirtualBox (www.virtualbox.org) or VMware Player (www.vmware.com) and install a separate copy of Windows XP (either Home Edition or Professional) for that purpose.You can find virtualization software free of charge that will run on Windows 7 Home Premium.
Hope this helps.
Oct 28, 2010 | MGI Software PhotoSuite 3 for PC
I used Photo Expl 2 on my previous (XP) computer, but recently upgraded on a new computer to Windows 7 Home Premium. Had a problem with Photo Expl 2 on Windows 7 Home Premium, and I see by posts that...
Here's one from left field,
Download this photo app. It on all new customer's software builds.
http://www.faststone.org/FSViewerDetail.htm
After that, yes, there is an XP Mode available for free download to users of W7 Pro, Ultimate or Enterprise and would run your previous more "friendly" version.
Best Regards,
TheSelkie
Oct 02, 2010 | Nova Development Photo Explosion Deluxe...
I have tried to install CADKEY 97 in a Windows 7 machine. The initial installation screen comes up, I click on Install CADKEY 97 and it tells me "Could not run CADKEY 97 Install. Try manually running the...
Mar 17, 2010 | Cadkey Corp CADKEY Version 6
Picture project not detecting camera since installed windows 7, how do we download pictures now. camera is being detected by pc so it doesnt appear to be a hardware issue, nikon resource center say they...
You could try the folowings:
1) Run your picture project program under XP SP 2 'compatibilty mode'.
2) Run the picture project program in XP mode if your computer and version of Windows 7 allows it (eg. Professional or Ultimate versions but your computer processor will need to support 'hardware virtualization).
3) Run the program in a Virtual machine with XP installed: I would use Sun VirtualBox which is free and does not need hardware virtualisation (unlike windows 7 'native' XP mode or VPC2007).
As you can see, you do have some options to overcome Windows 7 shortcomings! Hope it helps.
Jan 30, 2010 | Cameras
CADKEY 97
May 12, 2008 | Cadkey Corp CADKEY Version 6
Cadkey Corp Cadkey 19 Full Version for PC Logo
120 people viewed this question
Top Cadkey Corp Computers & Internet Experts
David Payne
David Payne
Are you a Cadkey Corp Computer and Internet Expert? Answer questions, earn points and help others
