Question about Breville Coffee Makers & Espresso Machines
Coffee maker will not come on.
In the past we have had other issues, the digital light display does not come on. We have to reset the machine (cutting it off and on) then it MAY start working. But now the problem is that the machine will not even come on. We have unplugged it, descaled it and nothing seems to help. In the past we have descaled regularly and changed the filter, all the things that are required to keep up the maintenance on it. The is the second one that we have had, with similar problems. And we have only had this one for 18 months. Please advise us as to the next action that we should take.
josh1856
  • 105 Answers
SOURCE: Descaling a Miele Coffee maker
Put them in the water chamber then they dissolve and you run they cycle. I would cycle through a second time also with water only to flush the system out.
hope that helps.
Posted on Jan 27, 2008
  • 2039 Answers
SOURCE: Water leakage- V'spresso machine
the pool of water its probably the boiler that leak you can order a seal kit from saeco but itell you the bolt that hold the boiler you have to remove them to change the seal most of time they brake and you got to drill them out big job new seal kit for brew group cheers p.s descaling with vinegar no good descaling solution is the best solution melts calcium vinegar remove in flake and can block maybe thats why our valve leaking cheers
Posted on Jan 29, 2008
SOURCE: After performing a descaling cycle, the descaling light still flashes, what is wrong?
The manual states that after you descale, you have to hold down the hot water button for 6 seconds, that will turn it off and "reset the timer" till the next time it needs to descale.
Posted on Feb 02, 2009
SOURCE: How do i clean my krups proaroma coffee maker
I put a mixture of water and vinegar thru the coffee maker and let it sit for about one hour. Then i rinse clear water thru and its find.
Thanks.
Posted on Jun 06, 2009
SOURCE: i have descaled my saeco magic deluxe automatic
i have discovered my manual. I now have to read it!
Posted on Aug 25, 2009
Prima donna coffee machine hot water spout not working
does it get past the waiting part if not try resetting coffee maker by disconnecting from power point for 24hr the try unit again.
Sep 06, 2014 | DeLonghi Coffee Makers & Espresso Machines
Just bought my Black and Decker coffee maker(2 days ago). Model CM2020B, 12 cup. The digital display for the clock does not light up. Is it supposed to?
As you can see from this photo, the B&D Model CM2020B digital display screen is supposed to light up when the coffee maker is plugged into a working electric plug. You couldn't control/operate the machine if it did not. The machine is useless without it. Bring it back to the seller.
Jun 14, 2014 | Black & Decker TCM700 Coffee Maker
Cannot get past prime funtion
Dirty tubes, manually clean,
Nov 17, 2013 | Keurig B60 Coffee Maker
I have had the machine for two years and it just died. None of the dials or toggle switches work, the digital clock display is dead, the coffee maker will not receive power. I have tried different...
The thermal fuse is probably open, it is usually welded to the heating element and tied into the on/off switch, and usually involves the replacement of the bottom section. The thermal fuse prevents the coffee machine from over heating.
May 04, 2011 | Cuisinart DCC-1200 Coffee Maker
How do I program the stay or go coffee maker to turn on at a certain time, I worked the past few evenings, but the green light will not come on, I did have trouble the other times also
To Program Automatic Brew
1. Make sure clock is set for correct
time of day.
2. Press PROG button and digits will
flash.
3. Press H and M buttons until desired
brewing time is reached.
4. Press PROG button to confirm setting.
Digits will stop flashing and
return to set time of day.
5. Once brewing time has been set,
follow this procedure:
• Follow steps in "How to Make
Coffee."
• Push AUTO-ON-OFF button once
and "Auto" will be shown in display
indicating the brew cycle will begin
at the set time.
NOTE: If AUTO-ON-OFF is pushed
twice, the light will glow and brewing
will begin immediately. Press AUTOON-
OFF once to turn off and once
more to set programming mode.
Jan 13, 2011 | Hamilton Beach Stay or Go 45234 Coffee...
When I turn on the machine it says warming up and rinsing but it doesn't rinse and I can't get it to make a coffee it won't go past rinsing
Probably overheat protector thermal switches on the water boiler is tripped. Need to open the machine and reset those switches by pushing in the pins on the switches.
OR the element on the boiler is blown.
May 25, 2010 | Saeco Royal Digital Plus Coffee...
Krups XP7200 series date problem
It seems that the dial knob and the electronic opto coupler don't work anu more. You can replace the digital panel by try to find a broken machine on ebay. Unless you are an electronics engineer like me (you can try to replace the optocoupler). See the post on leaking xp7240 for opening up the machine... it's tricky but easy.
Apr 14, 2010 | Krups XP7230 Compact Super Automatic...
Machine will not move past Warming Up start up
check with voltmetar your element on boiler for espresso,element need have continuidi,and check reset button if your machine have button on tank,and check small fuse on tank(with white rubber around)
Aug 24, 2009 | Saeco Royal Digital Plus Coffee...
Cuisinart grind and brew's program light wont stop blinking
Could be electrical, but: Hold in the program set button for several seconds. Set it for some time. Press the program set button one more time. See if it resolves the issue.
-Tha Mp3 Doctor
Nov 03, 2008 | Cuisinart DGB-500 Coffee Maker
Saeco italia error
What happens when you open the knob on the right? It may just need priming.
Jan 21, 2008 | Starbucks Saeco Italia Digital Barista...
Coffee Makers & Espresso Machines Logo
26 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
