Free download for manual for casio ce-2300
SOURCE: CASH REGISTER CASIO CE 3115 DISPLAY E 03 AND ALARM
This ino might help: Cleaning ERRORS: ______________________________
1.- Turn the Mode lock to OFF
2.- Press down the RECEIPT FEED button
3.- Turn the key to PROGRAM
4.- Lift up RECEIPT FEED button (FFFFFFFFFF)
appears on the display panel
5.- Press SUBTOTAL (wait for receipt to issue)
6.- Turn Mode Switch back to REG and use as Normal.
Also another bit goes like this:
RESET: _______________________________________
1.- Insert the OW key and turn to OFF
2.- Hold down the JOURNAL FEED button and turn the key to PROGRAM mode
3.- Release the JOURNAL FEED button. The display should shows "00000000".
4.- Turn the key to OFF
5.- Turn to REG1. The display shows "INIT" and "0.00"
6.-
Press the number 10801 and then press SUBTOTAL. Initialisation is
completed when the printer stops operation. The display shows: "_ 0.00"
Hope this helps in restting to factory settings................................sodeep
SOURCE: Changing VAT rate on Casio CE-3410
Hi.
This is an old rare UK model so i don't have the sequence for it. Do you have any manuals for it? I can help you to look up the correct settings if you have a manual. I may have some similar models but sometimes you can muck up other programming if you get it wrong.
Mark
SOURCE: i want to connect my casio CE-4000 cash register with my computer
Sorry. Far too old. No connectivity whatsoever for this model. It was a very low end register.
Mark
SOURCE: I have a Casio CE-3700 cash register. How do I
tina -
I found the service manual here:
ftp://ftp.totalpos.co.nz/Oldmanuals/Casio-CE3700.pdf
It is New Zealand, and the file is a little over 3 MB. If you have a problem, contact me and I can email it to you.
It has a section on programming the CE-3700.
Michael
SOURCE: service manual for casio cash register ce-3700
Try this link : ftp://ftp.totalpos.co.nz/Oldmanuals/Casio-CE3700.pdf
This is the link for manual.
Hope this helped you. All the best. Thanks
