Question about LG LRBC22544 Bottom Freezer Refrigerator
No water in water dispensor
Changed filter and unclogged ice dispensor
  • LG Master
  • 4,654 Answers
Don't forget that your dual water control valve has two sides. One side is for the ice maker and other side is for water dispenser. The water dispenser side may have recently failed causing water to not enter water filter area or dispenser, Thanks Sea Breeze
5220JA2013A Water Inlet Valveno water in water dispensor - 2_22_2012_3_16_09_am.jpg
Posted on Feb 22, 2012
I have a Kitched Aid SxS fridge,model KSBS25TNBL02. I changed the water filter, cleaned everythng, etc. It makes water and ice jst fine, but when I press the Ice dispenser, no ice comes out. I can look...
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
Aug 21, 2012 | KitchenAid Refrigerators
My GE Profile side by side refrigerator ice dispensor and water dispensor has quit working. The appliance is less than 4 years old. Wanda
The common connection between the two starts at the water fill valve. I have found also that the filter (water) if clogged, will prevent water flow to both. Change the filter first, cheapest and eaisest.
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice maker stopped making ice. Any solutions?
A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
Oct 23, 2009 | Kenmore Refrigerators
The water dispensor and ice maker have no water pressure. There is plenty of pressure up to the filter but very little past the filter. The filter is new.
the water dispensor and ice maker have no water pressure.There is water/pressure up to the inlet water point to the fridge but no water past the first valve
Aug 17, 2009 | Samsung RS2630SH Side by Side Refrigerator
Water dispensor problem (zIss420dmass)
hmm, wonder if the flap is broken inside where the water comes out or the control board is not working properly
Jun 23, 2009 | GE Refrigerators
No water from Water dispensor
Have you checked your water valve? I dont have your model number but you could have what you call a double water valve and one side of it may be out, alternately you may need to change your water filter if you havent done that yet. I have seen were the water stops dispensing first and then stops making ice. have you changed the filter lately? If not change it then if that doesnt work check water inlet valve...
May 12, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispensor not working
Did you use the correct filter?
Remove filter, and re-install. Make sure you have properly locked the filter into place as the locking mechanism assures the filter cut off valve opens.
Also, make sure any air was purged from the water circuit by holding the water valve open for a short period of time.
Jan 30, 2009 | GE Refrigerators
Water dispensor does not dispense water. Ice maker works.
you have prime the system air out of the water lines this is easy to do
put a glass big enough to cover water dispensor outlet cause its going to project water out at you press and hold button till water starts to run smooth
these fridges will spit water at you when you prime the system at first cause theres air blockage in lines
May 20, 2008 | Frigidaire FRS3R5EMB Side by Side...
LG LRBC22544 Bottom Freezer Refrigerator Logo
160 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
