Question about Heavy Duty LA9-3 Heavy-Duty digital Fingerprint Lock- Left Hand
How to reset digital finger lock - Heavy Duty LA9-3 Heavy-Duty digital Fingerprint Lock- Left Hand
  • sergio nunez Feb 21, 2012
    how to reset a digital finger lock
  • 963 Answers
Your lock is sold by Axxis Biometrics.
Here is the direct link to their support page, where you'll find a phone number as well as a link for the manual for your lock:
http://www.axxisbiometrics.com/support/
Here is the direct link to the manual for your model lock:
http://www.axxisbiometrics.com/images/upload/File/pdfs/LA9Manual.pdf
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Good luck, Sergio!
Posted on Feb 24, 2012
RCA Android tablet. It has a crack across the screen. How do I unlock it? its got a pattern lock on it?
As far as I am aware you will have set the pattern lock.. It's usually a four digit code that you need to input by sliding your finger across a digital pad WITHOUT removing the finger from the pad until you've finished. If you can't remember the code try some possibles, remembering that you probably have a limited number of attempts before itr locks up you could also try settings on the android.
Jun 17, 2015 | Tablets & eReaders
My ipod doe not have sound and a popup says generic volume cannot be stopped
Follow these steps to reset an iPod Classic, or in fact any iPod with a Click Wheel.
Make sure the iPod Classic isn't simply paused or locked.
Check the screen for a lock symbol.
If you see a lock, unlock the Hold switch.
You should be back in business.
Put the iPod on a flat surface to stabilize it.
Slide the Hold switch on, then slide it off.
Hold down Select and Menu together for several seconds with two fingers.
Make sure your finger isn't touching the Click Wheel.
When the Apple logo appears, release Select and Menu.
If the iPod Classic doesn't reset, repeat the above step.
If that still doesn't get your iPod Classic to restart, plug the iPod into a power adapter or a computer and see if it starts up.
http://support.apple.com/kb/TS1382?viewlocale=en_US(URL)
Aug 01, 2013 | Apple iPod Audio Players & Recorders
Is there a way to restore my ipod with my tablet?
Jul 06, 2013 | Apple Audio Players & Recorders
How to remove the screen lock
Where did all the lovely music go? When your iPod Classic freezes up, you may need to restart or reset the iPod. Follow these steps to reset an iPod Classic, or in fact any iPod with a Click Wheel.
Make sure the iPod Classic isn't simply paused or locked. Check the screen for a lock symbol. If you see a lock, unlock the Hold switch. You should be back in business. Put the iPod on a flat surface to stabilize it. Slide the Hold switch on, then slide it off. Hold down Select and Menu together for several seconds with two fingers. Make sure your finger isn't touching the Click Wheel. When the Apple logo appears, release Select and Menu. If the iPod Classic doesn't reset, repeat the above step. If that still doesn't get your iPod Classic to restart, plug the iPod into a power adapter or a computer and see if it starts up.
Apr 17, 2013 | Apple iPod classic MP3 Player
W202 ignition key wont turn past1
  • Reset your Mercedes-Benz key by placing the key in the ignition of your vehicle while the vehicle is turned off. Do not turn on the vehicle. Press a finger on the "lock" button of your key fob while the key is in the Mercedes' ignition.
  • Pull the key out of the ignition while continuing to hold the "lock" button down. Continue to hold the "lock" button for the duration of the key resetting process
  • Use another finger to push down on the "unlock" button five consecutive times. Keep holding down the "lock" button.
  • Release the "lock" button. This is the end of the resetting process for your Mercedes-Benz. Use your key fob to ensure it is properly working
  • Read more: How to Reset a Mercedes Key ' eHow.com http://www.ehow.com/how_7492936_reset-mercedes-key.html#ixzz2DPwSK6xa
  • Read more: How to Reset a Mercedes Key ' eHow.com http://www.ehow.com/how_7492936_reset-mercedes-key.html#ixzz2DPwCappG
    Nov 23, 2012 | 2008 Mercedes-Benz Mercedes Benz C Class
    Iphone touch issue
    attempt to reset the phone. Press and hold the home button and the top lock button. it should shut off and restart, if this doesnt work, it's possible your digitizer is bad and will need to be replaced. The digitizer is a thin film sheet underneath the glass that senses static electricity in your fingers.
    May 17, 2012 | Apple iPhone4 4G iPhone 4
    My ipod touch is locked up for 21738236 minutes does any one now how to help me???
    Have you reset it? if not
    To restart iPod touch, first turn iPod touch off by pressing and holding the Sleep/Wake button until a red slider appears. Slide your finger across the slider and iPod touch will turn off after a few moments.
    Next, turn iPod touch on by pressing and holding the Sleep/Wake button until the Apple logo appears.
    If its not responding do a hard reset.
    To reset it, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds, until the Apple logo appears.
    Jun 29, 2011 | Apple iPod touch
    We tried to rekey our kwikset smart key, but couldn't and now the original key doesn't work
    I had mine do the same thing right before I was leaving to the airport [re-keying for the house-sitter]. I was setting the lock and I hear a spring-type ping and the keying was lost.
    The tumbler can be reset to your key. However, it involves disassembling the device and has small parts.If you are feeling lucky, you can do this yourself or take it to a qualified person.
    If you are feeling lucky:
    A: Disassemble the lock from the door
    B: Remove the door handle from around the key side.
    C: Remove the U retaining-clip from the outside of the lock that is securing it to the shaft.
    D: Remove the lock from the shaft
    E: Remove the U retaining-clip from the tumbler body and the case
    F: You will have to press the five fingers down evenly on the length of the case to slide the cylinder out of the case. (I cut a plastic card with small wire cutters to make a tool, but you could probably use thick card-stock and some scissors.)
    Be careful; you will have to watch for and secure the check ball on one side of the tumbler and the finger lock bar on the other side as you slide this out.
    G: Remove and store the check ball securely as well as the finger lock bar. (careful with the plate surrounding the fingers that the finger lock bar resides in)
    H: Remove the finger locking plate. Carefully, make sure the fingers are still inside and oriented correctly and the spring at the back of the finger locking plate is left in place.
    I: You will notice a u channel groove in the fingers and the finger locking plate. Align the fingers in the finger locking plate evenly so that the grooves in the fingers match the groove in the finger locking plate.
    J: Replace the finger locking plate with fingers aligned evenly with the u channel groove back onto the tumbler body and hold back against the spring left on the rear of the tumbler body. This puts the tumbler into re-key position.
    K: Replace the finger locking bar onto the finger locking plate while holding the assembly against the spring and tumbler body. (If this is done correctly, the finger locking bar will now be flush with the side of the finger locking plate and not raised as normal.)
    L: While holding the tumbler assembly together and maintaining the locking plate pressed against the spring, Insert your new key into the tumbler body.
    M: While holding this assembly in this position, add the check ball to the tumbler assembly.
    N: While holding the assembly in position, slightly depress the black plastic block at the back of the finger locking plate and slide this tumbler assembly back into the tumbler case taking care to rotate the case 90 degrees clockwise from normal. (Note the U channel groove inside the tumbler case that normally receives the finger lock bar and use that for orientation.)
    If the tumbler does not insert cleanly, verify the finger locking bar is flush. If it is not, redo while maintaining proper pressure to keep the finger locking plate firmly against the spring in re-assembly. Also, verify the fingers are not protruding from the tumbler body. If they are, redo the procedure taking care to align the fingers properly on assembly and maintain proper force on the finger locking plate against the tumbler body during re-assembly and new key insertion
    O: Rotate the key and tumbler body in the case to the normal position (counter-clockwise 90 degrees).
    P: While holding the tumbler body firmly against the case, remove the key.
    Q: Re-insert the key and verify smooth rotation.
    R: Align the tumbler body and case back to the normal position and while holding the tumbler body firmly against the case, remove the key.
    S: Replace the U retaining-clip that belongs on the back of the tumbler body to secure it within the case.
    T: Replace the tumbler body in the main lock shaft and secure with the shaft U retaining clip.
    Mar 24, 2010 | Kwikset Professional Door Lock...
    Batteries won't maintain electrical connection
    hi jensen,
    in that case u'll have to change the body of the camera.
    i can tell u a trick: place a piece of an aluminum foil (kitchen foil) between the contacts and the batteries. this will ensure a good connection.
    try it and please rate this solution.
    good luck!
    Feb 13, 2009 | Vivitar ViviCam 3715 Digital Camera
    Factory reset Cannon PowerShot S2 IS
    I found this solution elsewhere, so I can't take credit for it. It seems a small piece of dirt gets stuck between the camera case and the button to take the picture. The button doesn't release fully, and it acts like the shutter button is pressed halfway down. Try running your finger over the top of the button in a circle to release it.
    May 29, 2008 | Cameras
    Heavy Duty LA9-3 Heavy-Duty digital Fingerprint Lock- Left Hand Logo
    133 people viewed this question
    Top Heavy Duty Locks & Locksmithing Experts
    ray gallant
    Tom Chichester
    Are you a Heavy Duty Lock and Locksmithing Expert? Answer questions, earn points and help others
