Question about Yamaha AX-596 Amplifier
No volume I have a Yamaha RX V596 5.1 channel 500 Watt Home TheathReceiver. The sound stopped working and the LED on the volume control is blinking. Is there an easy fix to this issue?
  • jeff_bjle Oct 28, 2008
    I have tried to change the settings and have verified the speaker connections. These were not the issue.
  • 1,800 Answers
Turn it of for 20 mins +check connections + check the volume control
and first of all maybe u r using the MUTE MODE check the R.COntrol!!
Posted on Oct 28, 2008
    Genius:
  • 1,550 Answers
You need to check the settings and also check the connection from receiver to five speakers .
Have a Sony 32" Bravia TV & Yamaha RX-V5000 Receiver. Unable to get the sound to come from the Stereo speakers connected to the RX-V5000 if watching TV. However, can get the Radio to play through the TV...
You probably want to connect the av Audio output from your tv and connect to the RX-V5000. The audio that you are getting from Radio through the tv is probably coming from the output of the RX-V5000 coming to your tv, to which the desiredd route is the other way.
The Outputs at the back should be labeled to tell you which channels are inputs or outputs.
Oct 09, 2013 | Yamaha Audio Players & Recorders
I have a Yamaha RX-385 receiver. I want to increase the number of speakers I can use from the receiver. I am considering buying a speaker selector that says it can connect 4 sets of speakers I can run to...
This speaker selector is standard accessory equipment for home audio equipment -- just follow the instructions with the unit.
The speaker selector unit has circuitry which prevents the amp from being overloaded by connecting too many speakers in parallel to the receiver. The receiver will have to be run at a higher volume level to drive all the additional speakers at the same volume as two sets of speakers, but this will not damage the amp in so doing.
Charlie
Jul 17, 2011 | Yamaha Audio Players & Recorders
Flashing LED on the volume
i have problem with amp yamaha dsp-a1000 the led the volume it like blinks everytime is good the transistor the output is good, i dont no whats happening can u help me please
Jul 19, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
AMPLIFIER CENTER CHANNEL NOT FUNCTIONING
Center channel will not work unless unit is set for Surround or Pro Logic. Make sure center channel's volume is up
Apr 28, 2008 | Yamaha DSP-A3090 7-Channel Amplifier
Sound cuts when volume is turned up
check that power amplifier rating(how many watt)must be more than total speaker rating by 20% at least..
exampel:if speakers watts are 100 watt-amplifier watt must be 120 watt.
Mar 14, 2008 | Technics SUV500 2-Channel Amplifier
Yamaha DSP A-1000 input selector switch not working properly
As that unit is well over 5+ years old, I seriously doubt the part is available any longer. I doubt that you will even find a used part, and even if you do, it will probably be as bad as your switch. As I have worked on audio for over40 years, I would use LPS 2. It is a lubricant. Do not try this with WD40 or similar. Just spray the LPS on the wafers, or through any open holes in the switch. You just need a little. If you just squeeze the button, you will see just a little bit of foam. That is all you need. No more; no less. Rotate the switch from from left to right and back again multiple times. Try that. BTW, no manufacture uses these mechanical switches any more.The controls are now called Rotary Encoders, which basically are inputs to a display microprocessor IC(a computer within the new product) which in turn controls the inputs of a switching IC. It's the same as your old switch, just electronic, and much more complicated. If you need more information, or would like to inquire about repairing your unit, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Feb 10, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Technics SUV500 problem in stand-by
The problem is not the relay. The unit is trying to start, but detecting a problem and shuting down again. Check the output transistors for a shorted condition.
Dan
Jan 31, 2008 | Technics SUV500 2-Channel Amplifier
Yamaha AX-596 Amplifier Logo
172 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
