Question about Toshiba Satellite Computers & Internet
The mouse move round with the touch pad but fail to click on to items again
The touch pad work when opening the laptop;shortly after the password the touch pad stop functioning
  • Toshiba Master
  • 27,725 Answers
Click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel harware and sound mouse you will see the same tabs and options as with xp
hope this helps
Posted on Feb 21, 2012
5 Suggested Answers
  • 81 Answers
SOURCE: UNABLE TO DOUBLE CLICK USING THE TOUCH PAD
Go back to your control panel of your mouse; once there, in your pointer options menu, lower your speed of your cursor. Your speed might be set too high, and if it is, it will prevent your mouse from functioning properly, including not being able to click.
Posted on Sep 04, 2008
Philster
  • 113 Answers
SOURCE: frozen mouse with a touch pad laptop computer
Many laptops have a button, usually located right above the touchpad, that disables the touchpad.
And there may be drivers that need to be loaded for some touchpads to operate properly, in case you've reinstalled the OS.
Posted on Jan 26, 2008
mnewelski
  • 8 Answers
SOURCE: Not working right click of touch pad of Acer Aspire 4710z
Hey!
What operating system are you running? All I could find was a manual for your model: http://tinyurl.com/6gc7pl
If you are using Windows XP, you might try going to Control Panel -> Mouse -> On the first tab (Buttons) check "Switch primary and secondary buttons." then hit "Apply".
Try left-clicking (currently assigned to be the right-click) on your Start button and see if the menu with "Explore All Users" on the very bottom opens. If it does, then your touchpad is most likely defective and would have to be fixed (www.fixmyacer.com). If the menu doesn't come up, then it is a software issue and is 100% fixable.
Matt Newelski
www.newelski.com
Posted on Dec 08, 2008
SOURCE: My Hp laptop - the touch pad will not work. I can
try going through control panel and then enabling the tap. see how that works for u
Posted on Nov 22, 2009
Mouse pad cursor works but cannot click
my laptop pad is not working the cursor is moving but not clicking on anything ......now wot can i do ???
Feb 11, 2012 | HEWLETT-PACKARD Computers & Internet
My mouse on my satellite a660 scrolls up,down,left and right without a glitch but i can't get it to double click and enter to open up pages. on the opening windows 7 blue page where the little icon...
hello friend,
I THINK THE PROBLEM IS FROM THE MOUSE PAD, I THINK IS EITHER YOUR HAND IS WET OR SOME LITTLE WATER POURED ON IT, IF NOT, THEN IT IS DEVELOPING SOME FAULTS THAT I THINK MAY TAKE SOME TIME. PLEASE IF YOU CAN LOOK FOR AN EXTERNAL MOUSE TO USE FOR THE MINE TIME NOW AND AVOID TOUCHING THE MOUSE PAD FOR SOME TIME THEN I THINK IT WILL COME BACK TO NORMAL LATTER.
Jul 11, 2011 | Toshiba Satellite A660-BT2G22 Customizable...
How to use touch pad dell latitude D610
The touch pad on a Dell Latitude D610 works much the same as with other laptops. You can move your finger around the pad to simulate the movement of a mouse, and it will cause the pointer to move across the screen. You can also tap on the touch pad (gently) to "click" on a file, folder, or other item. The touch pad on a D610 doesn't have a hardware switch like some other laptops do so that you can turn it on or off -- it's just always on.
Aug 08, 2010 | Dell Latitude D610 Notebook
Touch pad doesn't work
Determine What's Wrong
laptop'smag-glass_10x10.gif touch pad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touch pad may be damaged by excessive use or foreign substances such as water, dirt or food items.
Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return."
Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touch pad to become unresponsive. But if any of these steps fail to remedy the problem, then the touch pad may need to be repaired or replaced.
Repairing/Replacing TouchpadA touch pad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touch pad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touch pad is deemed a necessity, such repairs are rarely worth the cost.
Attempting to replace the touch pad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop.So just attach a mouse to it so you can work easily.Please rate me if this solution works for you
Thanks......Have a great time.
Jul 28, 2010 | Computers & Internet
I have a Dell laptop computer with Windows Vista Basic. The mouse on the screen has become very sensitive and sometimes it clicks on an item when it scrolls across the screen. How can I make it less...
  1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
  2. Alternately, click Start and type Mouse in the Search field, and select Mouse when it becomes available in the program list. The Mouse Properties settings window will open.
  3. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings . In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
  4. Select the PalmCheck option to adjust the sensitivity of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
  5. Select the Touch Sensitivity option to adjust how much finger pressure is required to move the mouse on the screen and how responsive the touchpad is to taps.
Jul 12, 2010 | Dell Vostro 1000 Notebook
Whenever i click on touch pad its not working
Try to check in the mouse properties if the tapping feature of the laptop is turned on. If the mouse button works and you can move the pointer throught the touch pad, then definitely its working.
Mar 29, 2010 | Compaq Presario CQ60-220US PC Laptop
Re toshiba techra 8000
Some laptops have a touch pad between the keyboard and the edge of the laptop. This works like a mouse except you slide your finger around the pad to move the mouse pointer and the buttons next to the touch pad are the left and right buttons.
Other laptops have a small round button in the middle of the keyboard which is a mini joystick and it is used to move the mouse pointer around, it will have a couple of mouse buttons at the botom edge of the keyboard.
You can connect a normal mouse to your laptop, it is mush easier than using the laptop's touch pad or mini joystick.
Sep 16, 2009 | Toshiba PA3121U - Satellite Pro 6000,...
Touch pad is moving but click the folder but not working
go to the control panel and open mouse properties.  you should find an option there to enable the touchpad click.
Jan 29, 2009 | Acer Aspire 5610-4648 Notebook
How to set up mouse pad so it works with touch
Check in the control panel under mouse. There should be a setting to enable tapping. If there is a touch pad icon on the bottom right of the screen you can also right click on that and select options.
Dec 31, 2008 | Gateway MT3705 Notebook
Laptop t-series
Use external (USB) mouse; check/adjust mouse properties double-click speed. Open/clean or replace touchpad.
May 25, 2008 | Gateway Computers & Internet
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
