Question about HP Photosmart Premium C309A All-In-One Printer
Waste ink pad HP C309A All-In_One Printer
Waste Ink Pad
  • 14 Answers
SOURCE: Ink System Failure HP D7360 Photosmart
Ok this is a critical issue with the printer and actually if the printer is in warranty the printer will be replaced as it is an issue with the printer and if it is out of warranty then sorry to say this problem hardly has any resolution opt for a trade in option with HP.....
Sorry this has no other resolution other than the reset that you have performed ,You can call up HP as well they will also say the same thing
Posted on Mar 04, 2009
  • 366 Answers
SOURCE: waste ink near full
This page gave me a solution worked for me:
Posted on Mar 24, 2009
  • 1901 Answers
SOURCE: I am getting a message that states that the waste
You need to replace the ink service module BEFORE it gets completely full.
You can go to this web page for instructions:
Replacement of Ink Service Module
The part number is CB026-67043 for the Officejet H470 printer. You can order it from HP or check for availability from a local office supply store such as Staples or Office Max.
Here is the HP page to order:
HP H470 Ink Module
Thanks for using Fixya.
Posted on Jan 12, 2010
  • 2022 Answers
SOURCE: Why does my HP Photosmart C3135 printer always
that is alignment page just scan it and press the scan button it will complete the process and next time it wont print.
Posted on Jan 19, 2010
  • 53 Answers
SOURCE: I have an error message on my HP Photosmart
Unplug the USB cable from theback of the printer if it is connected. Now take out the power cord.
Now Reset the printer:-
To reset it.
Connect the printer power cord to the Wall Outlet or Wall Jack.
Make sure it is not connected to the Serge Protector or power strip.
Partial reset :-
Now on the printer itself. --> Press and hold the
# and 3 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 3 button the hold time )
(On the printer screen it should say Part nvm reset.)
Now try to turn on the printer and check if it shows the Ink system failure - 0xc19a0027 option. If it works Perfect. If not then do this :-
Semi-Full Reset:-
Open the front door and take out all the cartridges from the printer. Now close the door.
# and 6 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 6 button the hold time )
( On the printer screen it should say Semi-Full rest )
The printer might shut down automatically or may be it won't. At this point Put the cartridges back into the printer and then turn on the printer if it was shut down.
or If the printer is on turn it off and then switch it back on.
The problem should be resolved up till now.
If still the problem Exist Call HP as the product has gone bad. The printer will be replaced if it is still in warranty. Remember the printer HP replaces is always a refurbished printer.
HP :- 1-800-474-6836 ( Tech Support )
Posted on May 06, 2010
Why my epson stylus c 67 ink and paper flashing alternately and cannot print, printer occured a problem
Look at this link for the app to reset the waste pad ink counter, and the video helps too; remeber to clean your waste ink pad because it can spill ink to your desk in a extreme case; you need to open your printer to clean the waste ink pad; search for instructions online.
PD: I have reset my counter six times and cleaned the waste ink pad two times; after six years I keep using my printer correctly.
Jan 09, 2013 | Epson Stylus C67 Photo Printer
Waste ink pad hp deskjet 2050
look in toolbox as you install ink and cartridge
move the artridge from printer and test in on the paper
Aug 08, 2012 | HP Deskjet 2050 All-in-One Printer
How can I change the foam pad that absorbes ink? What part is that called?
Its better to just remove them clean them up and replace it in the printer, because usually some printers require a reset code to re-set the waste ink counter. If the counter is not re-set there will come a time when then printer will refuse to print.
Here is how to clean your waste ink absorber;
Open the printer and locate the waste ink absorber near the ink cartridge.
Remove the absorber pad and hold it in cold water while squeezing the ink out. It would be wise to wear gloves while doing this, because the ink in the pad will leave stains.
Use paper towels to dry the waste ink absorber pad. Let it dry completely before installing it back in the printer.
Reinstall the ink pad into the printer and run a test page to make sure it works.
Apr 20, 2011 | Epson Stylus Photo R300 InkJet Printer
When printing coming on the screen "The Ink
When turned on, the printer initializes the cartridge, and perform inkcharge. So there is some ink discharged to waste ink pad. The printer calculates the amount of waste ink, and when the waste inkreaches a certain amount, which approached the waste absorptioncapacity pad, then the printer will stop printing command. Intendedto waste ink does not overflow from the waste pad. To be able to re-use the printer must be reset waste ink counter., and replace thewaste pad. Or it could also extend the exhaust hose to outsidebottle.
Jan 14, 2011 | Canon Office Equipment & Supplies
Locate waste ink absorber pad
canon pixma ip1000 printer, how do you access and clean waste ink absorber pad
Apr 13, 2010 | Office Equipment & Supplies
What is waste ink obserber? How it will be replaced?
waste ink pad absorber is like a waste tank made of absorbent pads, in here the waste ink is absorbed. In time this waste ink pad will be saturated or full. When it happens the printer will suddenly stop working. The printer needs to be reset to function again and the waste ink pad replaced to prevent flooding of waste ink inside the printer. The waste ink pad is replaced by disassembling the printer.
Jan 17, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink full
Dear sir,
You clear the EPROM chip. its cant possible at u r home. Better you bring it to service station for cleak ink.
Sep 21, 2009 | HP LaserJet 1020 Printer
I have a warning that my ink pad is saturated and needs replacing contack dealer for assistance (help)
Ink means pad for waste ink nearly full. Epson program read and count all waste ink from head cleaning and ink charge. Next, you need reset waste ink counter, and replace or washing pad. You can extend outlet pipe to outside of printer, so next time you don't need replace pad again.
Jun 27, 2009 | Epson Printer
How do you find the waste ink collector on a printer/scanner ?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
The waste ink absorption pads are inside the printer, in the very bottom. They are usually soaked with ink when full and are very messy.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
May 18, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Waste ink pad
to Reset Waste Ink Counter
  • RUN AdjProg.exe file Epson C90
  • choose Particular adjustment mode
  • select waste Ink pad counter
  • Klikinitialization
That’ all!
Jun 01, 2008 | Epson AcuLaser C900 Printer
HP Photosmart Premium C309A  All-In-One Printer Logo
116 people viewed this question
Ben Johnson
