Question about HP Office Equipment & Supplies
Print Cartidge Error. I am having this problem with my printer. I filled in the ink and using since two years. Now printer is not accepting it and not even NEW one. Always says Print cartige Error mostly with Black cartige. Any HELP Please!!!!
  • Ishwer sharma Feb 23, 2012
    I dont know where is the problem. I changed the cartidge, cleaned the cartidge. Follwoed your instructions to uncheck the checked boxes on HP printer series. But still the same result.
    Actually I was trying to connect my pc to a router through modem. Modem is of Motorola company and Router is of NETGEAR. So PC SCREEN Down tool bar is showing that pc is connected to Lan. LAN Transfer rate 100,0MBit/s
    But it is not connected to the router. When I deactivate the Lan connection in the setting then there is no internet connection. Even when my printer is off there is no connection to the internet.
    I think printer is Lan connected to the desk top which I use. There is no other PC OR Laptop in my house.
    But I want to disconnect the lan connection so that no one can see my private things through LAN.
    How can I disconnect it. It is irritating me. It Looks tha My desk top is in LOVE with my Printer and printer too but not acceting the cartidge.
    Do I need an expert to solve this problem which will cost me more than 150 Euros.
    Why my Desktop is connected to Printer.?? It is saying shared printer how to disconnect
    I did everything but no good result.
    Please help
    Thanks
    Ishwer
  • Ishwer sharma Feb 25, 2012
    I checked everthing. No success. Any other TIP.
    Problem Solver:
  • 16 Answers
You have air pressure inside the cartridge caused by loose leakage if it's a HP printer, it's a damaged cartridge incorporated jet..
Posted on Feb 21, 2012
5 Suggested Answers
SOURCE: HP Photosmart all in one C3180
My suggestion: Don't buy HP. I have the same region coding problem. All I want to do is buy HP ink, put it in my HP printer and print stuff. Too hard. I've wasted 30 pounds on ink and another 30 pounds on "support" phone calls to HP. Hopeless. I will never buy HP again. Waste of time and money.
Posted on Nov 19, 2007
  • 390 Answers
SOURCE: black ink cartidge
If a black cartridge will not print, with no error messages, it is probably th printhead. Clean it with proper cleaning solution. Refilled ones if done yourself or by someone else, can also have air bubbles, Try blowing down refill hole with tissue under the cartridge to stop ink spills. Also, if you press a folder non scented wipe under the cartridge firmly, you should get a solid little black line or impression. This will tell you if the ink is getting down ok. Try reprinting.
Posted on Feb 12, 2008
Basti
  • 1447 Answers
SOURCE: How do I use only Blank ink on Epson R265
are you using windows or mac? on windows go to printers and faxes under control panel, right click on printer and go to printing preferences and under advance put a check mark on the box that will say grayscale or black ink only.
On mac when you click on file print go to advance tab and print setting, select grayscale or black and white.
pls dont 4get to rate the solution thanks!!
Posted on Apr 12, 2008
Joed911
  • 4338 Answers
SOURCE: My copy prints come out blurry after changing ink cartiges
Try this:
Checking the print quality:
  1. Press the Ink or Ink Management key on the control panel.
  2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
  3. Press the up or down navigation key to select PRINT QUALITY and press Menu/Set or Set.
  4. Press Color (Colour) Start. The MFC/DCP begins printing the Print Quality Test Sheet.
  5. By reviewing this Test Sheet, you can determine if the print quality needs improvement.
  6. Closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
    If all lines are clear and visible, press 1 (YES) and press Stop/Exit.
    If you can see missing short lines, press 2 (NO) and go to Step 7.
  7. The display will then ask you if the print quality is OK for black and three colors. Press 2 (NO) for black or three colors with the problem.
  8. The display will then show START CLEANING? 1.YES 2. NO.
    Press 1 (YES) and the MFC will start cleaning the color ink cartridges.
  9. After the cleaning is finished, press Color (Colour) Start. The MFC/DCP will print another Print Quality Test Sheet.
  10. If you can see missing short lines in any of the four color blocks press 2 (NO) and repeat the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
Setting the Alignment:
  3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
  4. Press Black (Mono) Start or Color (Colour) Start. The MFC/DCP begins printing the Alignment Check Sheet.
  5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
  6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
    If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
  7. Press Stop/Exit.
    If I could be of further assistance, let me know. If this helps or solves the issue, please RATE it.
    Thanks, Joe
Posted on Oct 14, 2008
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Hi, please me advice the printer hpj580 error display aligning cartridge please wait... this is not fucntion at all, try off and on the same problem. always display aligning cartridge please wait. please...
I dont know the particular model but here is a quick look to see what you have ,check and see if the cartridge is properly seated in the print head and if so are the contacts clean. If contacts arent clean use some rubbing alcohol and a q-tip to clean them up. You should have a clean cartidge choice with the printer to do a self clean If a few years old and or you fill your own cartidges the ink spill-over from an over fill could have ruined your printer head,or just wore out. Basically whart is happening is that the sensors or contacts for the cartridge to the print head arent seeing each other ,so dirty or bad is usually the case as earlier stated
Mar 02, 2011 | Office Equipment & Supplies
I've tried replacing the color ink cartridge with two brand new Lexmark cartridges, but still get the error message "Color cartridge replacement required" and printer will not print at all. Tech...
On the ink cartidge there is a ribbon that looks like a circuit board (NOT WHERE THE INK COMES OUT) clean the connectors on the cartidge and the printer and try again
Nov 16, 2010 | Lexmark X5470 All-In-One InkJet Printer
Cartridge error:remove cartridge and reinsert cartridge on left, already cleaned, still happening, when put in new black ink, printed the alignment page out and then error showed, cannot print, fax, etc,...
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Dec 12, 2009 | HP Officejet J5780 All-In-One InkJet...
I have hp 4288 printer. Refilled cartridge does not work
ur cartidge nosel is jammed. get some drop of water on ur finger tip put it on nosel then put the cartidge nosel on newspaper because it is a good absorber it wiil help the ink to come out try for some times if it not work replace ur cartidge...
Nov 29, 2009 | HP DeskJet F380 All-In-One Printer
How to check whether the black in k cartidge is
If its defective it wouldnt print or you would get an error message. If you are having quality concerns then the print head is probably clogged. Nothing you can do except replace the cartridge because it has the print head built into it.
Oct 05, 2009 | HP DeskJet 840c InkJet Printer
Error code U140 check ink because I used a non-OEM cartidge
You need to buy the ink with the new chip installed, or buy a resetter. The only way to print now is with a new cartridge either Canon, or with a new chip.
Oct 01, 2009 | Canon PIXMA MX310 All-In-One Printer
Still getting message empty cartidge lexmark x2650
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 26, 2009 | Lexmark X2650 All-In-One InkJet Printer
Print want accept new cartidge
make sure it is snapped all the way into place, try resetting the printer..unplugging and plugging back in. check your owners manual to for steps you can perform
Apr 16, 2009 | Office Equipment & Supplies
HP Business Inkjet 1000 error detecting new cartridge
Disconnect the communication cable (USB?).
Turn off the printer, wait one minute then turn it back on,
Then press the left button on the panel, the transparent one to the left of power button. It will print a status page. Check the dates and information under each color that is failing.
The ink cartridges MAY be outdated. Printing the test and information page without the computer connected fools the machine since it can't get your computer date.
If the cartridges are outdated, then change your computer year back to 2005 or so, reconnect the printer cable and send something to print, once the printer prints it out, reset your computer to today's year.
You will need to do this procedure whenever you turns off the printer. (Disconnect cable, change computer year, print, reset computer date).
Hope this works.
Wagner
Feb 20, 2008 | Canon Pixma iP6600D InkJet Photo Printer
64 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
