Question about Cell Phones
Blackberry pearl 8220 flip/app error 523
App error 523
4 Suggested Answers
fleshgear
  • 541 Answers
SOURCE: i get app error 523 every time on my blackberry
On the BlackBerry smartphone, the following error message appears after pressing the Mute button, accessing an application, or performing a hard reset:
523 app. error. Reset.
To resolve this issue, first perform a hard reset.
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
If this does not resolve the issue, the BlackBerry® Device Software must be re-installed.
Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the desktop computer by completing the following steps:
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 to 5.0, perform the following steps:
  1. Open BlackBerry Desktop Manager.
  2. Click Help.
  3. Select About Desktop Manager.
  4. Click the Device Software tab.
  5. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider
Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding.
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click Application Loader.
  3. Click Next to start the installation process.
  4. Type your BlackBerry smartphone password, if prompted, and click OK.
  5. Select the check boxes next to the names of the applications to be loaded, and then click Next.
  6. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
  7. Clear the check box next to Backup up device data automatically during the installation process.
  8. Click Ok > Next > Finish.
  9. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following:
  1. Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications
  2. Click Next.
  3. Select the check box next to Do not automatically backup the application data during the loading process (if prompted).
  4. Clear the check box next to Backup and restore applications installed wirelessly (if prompted).
  5. Click Next > Finish.
The BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to open and run the application loader tool.
If BlackBerry Desktop Manager cannot connect to the BlackBerry smartphone, perform the following steps:
  1. Remove the battery and run loader.exe from C:\Program files\Common Files\Research In Motion\AppLoader.
  2. Remember to reinsert the battery after the loading operations begin.
Posted on Nov 05, 2009
esound
  • 425 Answers
SOURCE: app 523 error blackberry pearl 8220
Hi, You can reset the phone to clear the error
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry right here.
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
Posted on Jan 07, 2011
  • 24 Answers
SOURCE: blackberry pearl flip 8220 has an error 523
with regards to your issue, error 523 reset means a "System process died" You'll need I would reload the entire handheld OS again.
1. Install the software from the CD (that you received with the device), or download it from the service provider (AT&T).
2. Delete or rename the vendor.xml file, here: C:\Program Files\Common Files\Research In Motion\AppLoader (you're windows file options needs to be set to 'show system files', to see said file...
3. Open Desktop Manager (DM)...
4. Connect the Red Pearl (since am sure that's what you have!)...
5. Doing this will force the pc to see the BlackBerry as new hardware, and thus force it to reload the Operating System (OS)...
6. During the process, select YES to do a backup...
7. The whole process should take about 30-45 minutes...
Posted on Mar 01, 2011
I am trying to use an unlocked Blackberry pearl 8220 on AT&T, it won't find a signal
If you are getting an error message saying, "Invalid SIM Card" or "Incorrect SIM Card", then you would need to unlock the phone first.
Unlock Blackberry 8220 Pearl Flip
Aug 01, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
Hi. My BlackBerry Pearl 8220 Smartphone ask me to Reload Soft ware 513.What should I do? Help me please.
you much reload if .... download blackberry desktop manager.. here
http://us.blackberry.com/apps-software/desktop/
they have a guide how to upgrade or fix your blackberry device.. have a good day:)
Mar 24, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
Blackberry pearl flip 8220 has an error 523 displayed all the time what can i do
Feb 04, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
My blackberry pearl flip 8220 freezes randomly,
Invalid sim means it's locked to a career but your simcard's career, to unlock your BlackBerry go to http://blackberrymep.com and get your unlock code along with unlocking instructions .
May 14, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
I want to unlock my 8220 blackberry
Here are the updated instructions to unlock the RIM Blackberry Pearl 8220 (Flip):
Read more: http://www.mobileslate.com/blog/2008/11/04/how-to-unlock-blackberry-pearl-8220-flip/#ixzz0fNwiPynn
hope this helps! have a great weekend!
Feb 13, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
I get app error 523 every time on my blackberry 8220 pearl flip display
  2. Click Help.
  2. Click Next.
Oct 26, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Broken screen on Blackberry 8220 Pearl Flip
If you're tech savy you can use a blackberry repair guide that will show you how to disassemble it step by step and replace the screen, the screen is available on Ebay or you can go to the repair service.
Jul 15, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
External display on pearl 8220 cracked
You can find blackberry flip 8230 and 8230 LCD screen replacements on ebay. Took a while but they are available now.
They are a little tricky to replace but not to hard.
Check out the guide I wrote for replacing the blackberry flip LCD display screen. There are also links to by the new pearl flip LCD screens
Blackberry Flip 8220 LCD screen Replacement Guide
Mar 17, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Cell Phones Logo
53 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
