Question about Spectralink Lands Phones
SpectraLink 6020 Link Battery Problem
I am getting a 'Battery Failure - Bad CRC'...is there a way to refresh this batter or do something with the handset itself to clear this error? Or is this just a dead or bad battery?
Thanx
Ken
ken.gordon@providence.org
snakehead
  • 1074 Answers
SOURCE: Base won't charge handset
the base of your handset needs to be repair take it to a tech
Posted on Apr 04, 2007
  • 4102 Answers
SOURCE: Motorola MD760 dies after 5 minutes of use-- from being charged for days on base
this is a battery prob replacing battery will solve this prob hope this solves your prob make sure the battery connectors are conected propery securely first before replacing if ok then replace batt and prob should be solved check then conectors are clean where the phone sits on base and check phone sit on base properly if it does then it is def the batt replace.
Posted on Nov 15, 2007
SOURCE: KX-TG5631 handset
I can't a make call not dial
Posted on Mar 18, 2008
SOURCE: GE 900mhz model 26936GE2-C
HI NEED HELP MY PHONE IS SAY NO LINK TO BASE
Posted on Jul 03, 2008
PyroPCMan
  • 405 Answers
SOURCE: No link to base
Good Day,
See this link, this is pg 105 of the manual on how to re-register the handset to the base.
http://www.fixya.com/support/p123254-panasonic_kx_tg2740_cordless_phone/manual-7363/page-105
Hope this helps
Posted on Jul 07, 2008
Display shows a phone number but no dial tone. device seems "stuck." On/off and remove/replace battery did not help
You may visit your Mobil Sevice Provider's Client Attention and ask them. Maybe it's a configuration issue. Maybe it can be solved doing a Factory Reset - The know the codes to do it.
Aug 01, 2015 | Polycom, Inc. Spectralink 6020 Single...
Polycom spectralink 6020 voicemail
All depends what phone system the Spectra runs along side with, call your vendor who installed it or your office manager/admin
Nov 17, 2012 | Polycom SpectraLink 6020 Wireless...
I forget my security code now i want to refresh it plz send the code 12345 i try it but donot get the result nokia 6020
To unlock your phone, follow the information from this link.
Also, try these default codes:
Default 4 Digit user code: 1234 or 0000
Default 5 Digit Security code: 12345 or 00000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Feb 10, 2011 | Nokia 6020 Cellular Phone
My mobile is getting turned of automaticaly so kindly gett me the refresh setting code for nokia 6020
hi,
go to main menu then >SETTINGS >RESTORE FACTORY SETTING >then enter your security code...if not change ,the default code is 12345 ...wait until the phone reboot and its done..
i hope it will help you ,thanks for trusting fixya
Jan 29, 2011 | Nokia 6020 Cellular Phone
I have an isuzu dmax2005,it doenst start
first test your battery if it is charged then you ether have a bad starter or and open in one of your wires it may unless it cranks and dose not start then it would be high resestence coused by corroshen or something of the sort and if the batter is depleted then it is ether a bad batter or a bad connection from the altenater to the battery coused by lose wires or corrison or altenaters bad that is basicl any and all posibiltys oh one last thing you might just have bad gas
Jan 26, 2011 | 2006 Isuzu i-280
Low battery back up
1 reples batter
2 chaging 2 h only batter
3 heeting M/B
Dec 25, 2010 | Nokia Classic 2700 Cell Phone
My expedition keeps dying on me the battery dies once i get it started though it works fine its when i leave it parked over night there is a new alternator on it cause the old one went out and the battery...
I'd run it by Autozone if this was the batter that was in it when the alatnator went out it may have cause the batter to get a bad cell, they will check it for free, Most batters have a 3 to 5 yr. warrenty. DONT tell thim your alatnitor went out if the battery showes bad this will void the warrenty just simpley say my batter has a bad cell....of corse the place you bought the batter will test it as well befor they give you or pro-rate your old battery good luck
Dec 24, 2010 | Ford Expedition Cars & Trucks
What is the beep code asus p5ntws
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
Apr 20, 2010 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
Spectralink PTB400 internal error
Correcting Spectralink Errors Below are instructions on performing a “soft test” which will correct any internal error 8 and 4444-444C messages on your Spectralink phone. To aid you in educating your staff you may view the following Word document showing the step-by-step instructions. Please feel free to print and post this document where the Spectralink phones are kept on your floor. Soft Test Instructions
  1. Power off the phone.
  2. Press and HOLD the volume key (VOL) and the power key at the same time (the phone will chirp and display the serial number.)
  3. Now…release ONLY the power key (phone will vibrate and make a long tone.)
  4. Now release the volume key (the display will have a lot of black boxes and ZZZZ’s – you will also see the bottom of the display showing “msg”, “bat”, etc.)
  5. Count to three and then power off the phone.
This “soft test” is to correct only certain internal error messages. When the phone is experiencing a correctable error the display will read “internal error 8” or “internal error 4444-444C”. For all other internal errors the phone will need to be taken to Teleservices, NE-165 to be replaced.
As per : http://depts.washington.edu/uwmcdir/spectralink.html
Mar 16, 2010 | Spectralink (PTB400)
As soon I turn on it shows internal error 8 & 4444-444c
http://depts.washington.edu/uwmcdir/spectralink.html Correcting Spectralink Errors Below are instructions on performing a “soft test” which will correct any internal error 8 and 4444-444C messages on your Spectralink phone. To aid you in educating your staff you may view the following Word document showing the step-by-step instructions. Please feel free to print and post this document where the Spectralink phones are kept on your floor. Soft Test Instructions
May 16, 2009 | Spectralink (PTB400)
Lands Phones Logo
195 people viewed this question
Top Spectralink Lands Phones Experts
Are you a Spectralink Lands Phone Expert? Answer questions, earn points and help others
