Question about Belling Ovens
Belling XOU 487 Synergie 50/50 Double Electric Oven
I need an outer glass with stainless steel sides for the bottom door for this oven but cannot find the right part number. Can you help please
SOURCE: belling synergie. oven
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Posted on Aug 19, 2008
SOURCE: How do I find the model number on belling synergie oven?
I have the same problem. I have inherited a Belling Synergie multifunction double oven. The Model No is worn out - yet there is a specification 492SS which isn't. I am going to purchase the element with this number and hope this works.
Posted on Mar 28, 2009
SOURCE: can't get my belling oven to work
Press & hold both the 'Cook Time' and 'Stop Time' buttons together and, while holding both of them down, press either the + or - button (this is the way to set the time of day). Release all buttons simultaneously. This should enable the cooking functions to operate.
Posted on Apr 27, 2009
barkencoa
  • 3463 Answers
SOURCE: oven not heating up [fan works]
It wilbe a faulty oven element, you will need ti fit a new one.
It is located at the rear of the oven, behind a removeable cover.
Please rate my solution.
Thankyou.
Posted on Feb 11, 2010
  • 5 Answers
SOURCE: How do I set clock on Belling Synergie
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To set the clock
hold the cook and stop buttons together at the same time then use the up and down arrows or+/- to set the time in 24 hour format
Posted on Mar 29, 2010
Replacement door for upper oven belling XOU592
I am unsure where to get a replacement door-- If you are only looking to change the appearance of the existing door then I do know where to find the solution for that. Go to www.applianceart.com and check out all their options. They have solid colors, textures, designs by artists, and even stainless steel options. While their website does not have pictures of the oven doors available yet... all the designs on their site will work for ovens. Contact these guys with any questions you may have---
Hope this helps.
Oct 30, 2011 | Belling XOU592 / XOU593 Electric Double...
The outer glass on my hotpoint oven door has shattered do i need special replacement glass
You must replace it with the glass as supplied by the manufacturer, as it is is special heat tempered glass.
Nov 11, 2010 | Hotpoint DY46 Style Line Stainless Steel...
Belling synergie element not working
Hi the bake part in the top oven of my synergie, and how do i get it out? thanks.
Sep 05, 2010 | Belling XOU592 / XOU593 Electric Double...
Fan oven option not functioning on main oven, its a Belling synergie multifunction oven, about 5 years old
On my Belling it was the oven multi function switch that was faulty. I replaced it - carefully (lots of coloured wires) and it works fine now. Hope this helps
Oct 24, 2009 | Belling XOU590 Electric Double Oven
Mar 23, 2009 | Belling XOU174 Electric Single Oven
Belling XOU 252 Oven suddenly stopped working
Yes ,I would say that without doubt the element has gone
Elements can go without any warning at all.
Dec 13, 2008 | Belling XOU252 Electric Single Oven
Dirty oven window
Try to remove the door. For the Kitchenaid, thereis a hinge on each side with a latch that flips up. Once the door is removed, remove all screws and you should be able to get at glass. Be very careful, the Kitchenaid had four panes of glass.
Jan 08, 2008 | Whirlpool GBD307PRS Stainless Steel...
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Belling Synergie
NEED NEW FAN OVEN ELEMENT THAT CAN BE FOUND HERE
You need Element code AB20 on link below
http://cookerandovenelement.co.uk/bellingfanovenelement.html
element is located on back wall of oven you need to pull oven oven to remove the element element is held by two nuts from back and i screw from front
Dec 22, 2006 | Belling XOU270 / XOU271 Electric Single...
Ovens Logo
238 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
