Areas of black have streaks - Office Equipment & Supplies
  • 1,326 Answers
I am guessing that the lines you are getting are white??? Have you tried to clean the primary charge roller or charge wire's? Also, it depends what kind of copier you have, some have cleaners that come out and clean the wires > one or all of them maybe stuck and blocking the charge. Have you looked in the developing unit... You may have to change the developer.... Good Luck
Posted on Feb 21, 2012
Black image streaks on sharp 2700n
You only have to make single color copies with each color CMYK
and check all the copies if only the black and white copies is smeary
then replace only the black the drum unit.
Mar 21, 2014 | Sharp MX-2700N Color Copier
Black line on scans with neat receipts mobile scanner
Multiple lines appeared in every scan right after scanning a document from a credit card company that had those nasty adhesive strips used to attach credit cards.
First, I scanned multiple full pages to see if the problem would clear itself. After about 6 pages, I was able to identify the specific areas where the lines occurred on a document.
Next, I sprayed a tiny bit of glass cleaner (I used Sparkle glass cleaner, but I suspect any brand would work) onto an 8.5x11 sheet of plain paper in the area where the black lines appeared. NOTE: DO NOT SOAK THE PAPER, just get it damp.
Finally, I ran the dampened paper through the scanner. After each run, I would compare the result to the prior scan. As each streak was removed, I used a different piece of paper wetting only to address the remaining streaks.
After only a few runs, the streaks were gone (in my case).
Hope this helps!
May 14, 2012 | NEAT Receipts Mobile Scanner
I have inserted a new black cartridge and now my printing comes out incomplete
Try 'aligning' the cartridges... If you have done that already, do describe the problem in more detail - Are you getting streaked areas?
Dec 19, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
Copies have black streaks now
Dirt on the narrow glass will cause streaks through the Auto feeder, but copies should be clean if using the main contact glass if that's the case. Dirt/toner anywhere else (ie:laser optics) would cause light areas on the copies- not dark. Did this happen the very first time you used it, or shortly after? In other words, could it be coincidental? It sounds more to me, like the PCU (photoconductor/drum unit) needs replacement, or a fuser roller.
If cleaning the glass doesn't help, then one of these 2 things is causing your problem.
Apr 23, 2009 | Ricoh Aficio 450 Copier
Samsung CLP 510 light grey vertical streaks
you have 2 problem.
1). toner is bad
2). toner is low
change the toner should fix both porblem.
try to clean the roller while you have the toner out. (just in case).
Mar 27, 2008 | HP LaserJet 5p Printer
Black line
The problem could be the system and not the printer itself. Try turning it off, unplugging and then replugging and switch on try again. Sometimes this can reset errors. Post back if no go lilacgerry xxx
Jan 29, 2008 | Brother MFC 6800 All-In-One Laser Printer
CANON PC 20 COPIER
I think the plastic broke that held the spring, so you need to figure out where it broke and drill a new hole for the spring, and sounds like you need a new cartridge, GOOD LUCK!!!
Jan 24, 2008 | Office Equipment & Supplies
15 people viewed this question
k24674
jasbo
jasbo
