Question about LG 32LG30 32 in. LCD HDTV
When i turn on my LG 32lg30 on, the power indicator light flashes red 4-5 times, then the monitor turns on to a steady dark blue color. I tried to press buttons on the remote but there is no display.
Red light blinks 4-5 times, steady dark blue display.When buttons are pressed on the remote there is no visual display.
  • J. Rivera Feb 21, 2012
    tv turns on but no display.
  • wily157 Aug 17, 2014
    It's been working just fine for 4 years with the same HDMI input, nothing has changed.
  • LG Master
  • 1,205 Answers
Now there is a challange.
My LG has not shown this behaviour yet. Do you still have the DVD disk that came with the TV.
If you do you will get your answer there I presume.
Make sure that you are using the correct input.
kollagunn
Posted on Feb 21, 2012
  • wily157 Aug 20, 2014
    What if you can't use any inputs or other buttons for that matter? I presume you understood buttons don't work....
When I turn on the external drive, the lights flash.
It all depends on the type of your external. The different light color may indicate different thing. I would say that it may be an update being applied, a hard drive error or a power issue. I agree that this is not very helpful, but it all depends on the drive. Check your device's manual for some details about those lights meaning.
Hope this helps
Oct 14, 2014 | Computers & Internet
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Need control codes for my 32LG30
Hello
Four digit universal remote setup codes for LG TVs are:
0004 0050 0009 0005 0227 0338 0012 0057 0080 0156
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Mar 02, 2012 | LG Televison & Video
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
I have an LG LCD (42LG10), and it will not turn on properly. When you switch it on a red light flashes and then it turns to blue. Only after several times of doing this will it turn on.
This tv problems it is the causes and the problems of the tv power supply board.That the board where the tv a/c power cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv power supply board for the replacement.
Aug 16, 2011 | LG 32LG30 32 in. LCD HDTV
My 32LG30 stopped showing picture but still has power on it is blinking red
Since the power indicator isn't turning blue, there is an issue that won't allow your power supply to come up. I would take this to a certified technician and have them check it out. Most likely there is a problem with the power supply itself.
Nov 04, 2009 | LG 32LG30 32 in. LCD HDTV
Can't get monitor to power on
I have a similar switch on mine, although mine is a Gateway. So my solution is going to assume the same indicators and functionality.
On mine, a blue-violet power switch indicates it is off, red indicates standby mode, and blue to indicate it is on and/or searching for a signal. When turned on (blue), the monitor will go to standby mode (red) after 3 to 4 seconds if it does not detect a source signal. So if you toggle the power switch to blue and it soon changes to red, you'll need to check your signal, cable, or possibly for a bad source connection on the monitor.
Oct 12, 2009 | LG L206WTY-BF Monitor
LG 32LG30 32 in. LCD HDTV Logo
445 people viewed this question
Computer Repairing
Computer Repairing
