Question about Ricoh Aficio SP 3410SF Laser Multifunction MonochromeDesktop Scanner Copier Fax Printer
Cannot copy insert paper into adf
  • jessi_holtro
    jessi_holtro Feb 21, 2012
    I have a Ricoh Aficio sp3410sf and I try to copy from the flat bed and it gives an error that i need to insert paper into the ADF and continue. It was working yesterday morning and then by the afternoon I couldn't copy without using the ADF. This is a networked printer.
Cannot print screen shows ADF.what does this mean?
Hi!
ADF stands for Automatic Document Feeder and it means the device mounted on top of your pixma that allows multiple pages to be scanned/copied/faxed one at a time automatically.
Now why does it not print? The machine "believes" some document is inserted in the ADF in order to be scanned/copied/faxed, and wants that operation to be completed before it accept any print job. Please remove, if present, any paper from the ADF. Maybe its only some small piece of broken paper or even dust on the sensor in the ADF.
Aug 08, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
It senses paper loaded into the ADF but doesn't feed
There should be a button with settings on it.....ie: 2 sided, collate, etc. There should be an option to change paper settings.......or just clear the whole menu, and go to default to reset the rollers.
Oct 19, 2009 | Canon PC-980 Color Copier
Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
Sep 11, 2009 | Canon PIXMA MX310 All-In-One Printer
I have a 8840D. the doc feeder became unglued from it hinges on the base of the machine. Also it does not feed docs any more.
you configure your printer adf insert paper adf congigure copy quantity button press print key then make copy how much quantity
thanks
reply me comments
Sep 10, 2009 | Brother MFC-8840D All-In-One Laser Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
The ADF Konica Minolta causes paper jamp or may bend 1 corner of
check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Apr 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
No paper message for ADF
I called Xerox and the technician told me the ADF cable was loose. I went home readjusted the ADF cable and now it works like a champ.
Jan 19, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Users Manual
the ADF is the automatic document feeder the part on top of the machine that you insert the paper to Automatically feed the paper in one at a time, there may already be a document on the glass lift the top and put it back down it should clear
Jul 31, 2008 | Canon PC-1060 Black and White Copier
Canon ir5000
hi im jules_09.have you set the paper size first before copying.there is nothing wrong with adf its fine.if you want to use fls go to the program then set the size of the paper and which tray you are going to use each paper tray can be adjusted according to your paper size needs
Nov 06, 2007 | Office Equipment & Supplies
Will not copy
If the paper isn't feeding in the ADF (automatic document feeder - upper paper feeder) then the ADF roller assembly will need to be replaced. Try a copy on the flat glass area. If it work, then it's the ADF, If not then the upper scanner assembly with have to be replaced.
Apr 28, 2007 | Canon imageCLASS D880 All-In-One Laser...
Ricoh Aficio SP 3410SF Laser Multifunction  MonochromeDesktop  Scanner Copier Fax Printer Logo
69 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
