Question about OrangeHRM Computers & Internet
When i run orangehrm without data it runs fine but when i have data in it it runs very slowly, this seems like a memory problem,how do i solve it
3 Suggested Answers
ElDopa
  • 295 Answers
SOURCE: error "please insert data traveler and run as privileged user"
You have to logon using an account with administrive rights (like administrator) to be able to use the SecureTraveler software.
Posted on Aug 17, 2009
bob_computer
  • 3153 Answers
SOURCE: acer aspire running slowly how can i solve this problem
Some computers can be slow or short of hard drive space for quite simple reasons.
Windows and other program hide temporary files in lots of different places
The best option is not always a program or utility and if you want to do as much as you can for FREE like I do then you have a few options.
1. First you need to be in windows explorer.
2. Click TOOLS and FOLDER OPTIONS
3. Now click the VIEW tab
4. Tick the Show Hidden Files And Folders option
Unpick Hide Protected Operating System Files (it may warn you but you can ignore it)
5. Click APPLY then OK
6. NOTE some files may not delete this is OK Also DO NOT DELETE the folder itself where mentioned for cleaning.
7. Using windows explorer go into the WINDOWS folder and look for a directory called TEMP (it is possible there may be more than one)
8. Select all the contents and delete them. Do the same for any other temp folder e.g. temp000
9. Now navigate to Documents and Settings
There are quite a few folders in here that can be cleaned up
10. Look for folders named "Local Settings" In there you will find more TEMP folders that can be cleaned out
11. Now look inside the Temporary Internet Files. Delete anything EXCEPT cookies. Otherwise passwords for some sites you have stored may need you to type the password again.
12. Do this for each user / profile you see.
13. Now check the C: drive itself and see if there are any Temp folders and clean those out too
To prevent accidental deletion of any files windows needs you should go back to step (4) and change the two settings back to their original
Posted on Nov 02, 2009
1985 s10 2.8 v-6 sluggish around 45 mph
If you have a data scanner some of data doesn't code like out of range look for tps ,map,engine temps sensor data
hope it helps
Apr 01, 2014 | 1999 Chevrolet S-10
Need help on my computer hardware problem. I am
You are correct to a point. The lower memory is an issue but the main issue is your desktop is so much older so the processing power of the desktop isn't nearly the same of your laptop so it is going to run slower.
Sep 09, 2013 | Computers & Internet
It always displays a msg "memory is full "
Hello i hope u 'll be fine.... thanks for using fixya
  • Usually this problem 'll be occur due to full storage of memory, Every device needs some extra memory to run
  • To solve the problem you have to delete your some useless data of your mobile and u have to make some free memory
I hope this solution will work and helpful 4 u. Best of luck
Please do rate if if it is helpful
THANKS
Feb 10, 2010 | Nokia N72 Cellular Phone
WD USB drive (250GB) worked on PC, then used on Mac, now not PC!
you can try few options, first try on a nohter pc with windows & see if it's fast, also if there is less data, backup & try a format.
May 13, 2009 | Western Digital 250GB MyBook External USB...
The dvd player posts a message "can not play." I have tried several dvd's and none are playing.
Open the case. Disconnect the ribbons from the main control PCB. Remove the screws holding down the PCB and the rear connectors. Take the board out. Find a chip with the number MR27T1602L or similar - it is called a P2ROM. Run a screwdriver slowly all around this chip to possibly drain erroneous (yea right) data. There is a small chip diagonal to the P2ROM right next to it. I could not read what it was but i suspect it is for temporary data storage - possibly a serial ROM of some sorts. Run the *SMALL* screwdriver around the 8 legs on that chip slowly ensuring that it connects each 2 legs to each other along the way. Now this will either 1) Do Nothing 2) Mess up the chips or 3) Clear out any bad (read factory installed failure timers) data from the chips. Doing this task over a period of about 3 hours seemed to have solved the problem. Now it could have been as simple as disconnecting the ribbons to the board and leaving it sit for a few hours to drain (memory caps to lose charge). I don't know. But I know after doing this my player started working again. Good Luck to all who try.
Mar 31, 2009 | Sony DVP-NS57P
Truck will not stay running without giving gas after a jump off
when the battery goes dead it looses its memory on engine settings like idle speed.. two things you can do first one is to clean the throttle bore with carb cleaner... the other is to start with foot on gas and slowly bring it back to idle... it will pick up the idle air position to keep itself running if you do it slowly... everything happens over time so as the throttle gets dirty the computer makes these adjustment on its own and when the battery dies it starts out basicly at different percentage of idle control tht it really needs because of the carbon buildup on the throttle plates
Feb 18, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Cannot play disc
a burned disk u will need newer samsung unitto rea dthem all older units dont read well burned dvds ok upgarde to latest players so it can read it right
Oct 14, 2008 | Sony DVP-NS57P
Virtual memory
dear barbwire
your hard drive nearlly full in which your os is installed.so pls increase your winxp drive capacity or remove program and data which are not importent or send them to other drive .then remove temp files. perform disk cleanup.and run chkdsk utility in cmd. your problem is solved.
bye.
kishor khatri
Mar 18, 2008 | Computers & Internet
Computers & Internet Logo
83 people viewed this question
Top OrangeHRM Computers & Internet Experts
David Payne
David Payne
Are you an OrangeHRM Computer and Internet Expert? Answer questions, earn points and help others
