Memory dump blue screen
My pc is working fine windows 7 64 bit as rock 970 extreme 4 , 8 gig ddr3 memory 2 tb hdd radeon HD 3800 video card , i can open traktor pro 2 as soon as i turn on my traktor s4 it crashes to a blue screen & says memory dump , its got me stumped to why as it is all new , it wasnr doin it before have been using traktor pro 2 & traktor S4 for 10 months built a new pc & traktor S4 is crashing it with a blue screen , please help
    New Friend:
  • 150 Answers
Sounds like you are having an audio driver problem try using a different driver for your sound card
Posted on Jul 01, 2017
  • 42 Answers
SOURCE: Toshiba A105-S2101 keeps crashing!
the problem is in your hard disk. replace it with another one and install the operating system and let me know.
also check for vibration, the hdd needs no shaking.
is that ram DDR II SDRAM - 533 MHz ?
Posted on Jan 20, 2008
SOURCE: blue-screen crashes
I just had this problem too, I had to replace the hard drive ($94) and lost everything. easy fix though.
Posted on Jan 25, 2008
  • 221 Answers
SOURCE: HP Pavilion laptop freezes daily and i force manual shutdown
It sound's like there could be a compatibility problem, maybe corrupt file's, or missing start up file's, have you tried doing a window's update, or doing a disc check on the hard drive, go to my computer right click the drive then go to propertie's, click on tool's then click check now for drive error's. if that do'es not work you may need to reformat back to the original xp os.
Posted on Apr 16, 2009
  • 27 Answers
SOURCE: Inexpensive Graphics Card for Notebook Video Editing?
Definetly the ati one. 120 stream processors is really good and it has
direct x10.
Posted on May 27, 2009
  • 32 Answers
SOURCE: Registry File Failure c0000218
Try this: Reboot and select Recovery Mode, then from the c:\windows prompt type: chkdsk
Let it run through checkdisk then try it should boot up.
Posted on Sep 15, 2009
In call of duty ghost do i need to buy 1 whole 8 gig of memory
You need to have 6 gigs of free dynamic ram.(Not including that used by the operating system and any other applications you have.
The way that memory is organised in a computer these days is usually in pairs or DRAM (dynamic random access memory) sticks which are matched. This allows the CPU to withdraw data from both memory sticks in the same clock cycle (DDR double data rate) which improves the over all speed of the processing.
So legal combinations over 4 gigs which will use the dual channel feature on your motherboard will probably be.
2 x 4 gigs sticks = 8 Gig DRAM
2 x 8 gig sticks = 16 Gig DRAM
Below is the minimum specification requirement.
Note: MINIMUM Faster CPU better graphics card and More ram is better.
CPU: Intel Core 2 Duo E8200 2.66 GHZ / AMD Phenom X3 8750 2.4 GHZ or better CPU Speed: Info RAM: 6 GB OS: Windows 7 64-Bit / Windows 8 64-Bit Video Card: NVIDIA GeForce GTS 450 / ATI Radeon HD 5870 or better Sound Card: Yes Free Disk Space: 40 GB
Feb 24, 2015 | Activision Call of Duty: Ghosts Full...
How do I find working XP video card drivers for a Gateway TA7/ Viper-SR laptop/tablet?
are you sure about the driver/chip? You may need to double check - was this an upgrade/ change of OS from a Vista machine? Or could it be direct x? read below.... otherwise I have no idea sorry ATI Mobility Radeon HD 2300 csm_ati_radeon_chip_05_e8206cf22f.jpgThe Mobility Radeon HD 2300 graphic card for laptops is the successor of the X1300 and supports only DirectX9 (according the informations of the AMD homepage). The performance shall be somewhat above the X1300 and therefore present average or worse game performance. AMD / ATI tells that the relation of performance/Watt has been improved. Rumours tell that the chip is only a renamed X1300 / X1350 video chip.
A difference to the X2300 are the amplified video options (UVD).
The HD 2300 graphic processor is certified for Windows Vista and supports the Windows Aero Glass Interface.
Manufacturer ATI Mobility Radeon HD 2000 Series Mobility Radeon HD 2300 4/2 cores @ 480 MHz 128 Bit @ 400 MHz Codename M71 Architecture RV5xx Pipelines 4 / 2 Pixel- / Vertexshader Core Speed * 480 MHz Memory Speed * 400 MHz Memory Bus Width 128 Bit Memory Type DDR1/DDR2/GDDR3 Shared Memory no
HyperMemory wird unterst?tzt DirectX DirectX 9c, Shader 3.0 Transistors 115 Million technology 90 nm Features 90nm manufacturing process, PCI Express X16 Interrace, PowerPlay 6.0, Avivo Video architecture (MPEG-2, MPEG-4, DivX, WMV9, VC-1 acceleration), 64-bit floating point HDR, Ultra-Threaded Shader Engine, OpenGL 2.0 Date of Announcement Link to Manufacturer Page
Nov 25, 2014 | Gateway Ta7 E-295 Laptop Tablet, Core 2...
When i connect my graphics card to my pc i get a black screen there is no beeps and i cant even hear an windows sound. when i disconnect my gpu my pc works fine i have tried to disable onboard graphics...
Hello xvanpersiex, these are "Full Specifications" of your [Graghis Card].
"Check this to the 'Specs' of the "Motherboard to see if it 'Supports' the Graphic Card?"
"Try 'disconnecting, and reconnecting' the "Graphis Card"
Verify that 'all' the "Connections" are "Tightly Inserted."
*Go to the Control Panel > Device Manager > AGP Graphic Card > Verify Installed? >
Update Driver! > Restart Computer"
"If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9"
ATI Radeon X1650Pro (AGP 8x, 512MB) General
  • Device Type Graphics adapter
  • Enclosure Type Plug-in card
  • Vista Capability This graphics card is capable of running the new Aero interface featured in Windows Vista Home Premium and higher.
  • Interface Type AGP 8x
Processor / Memory
  • Graphics Processor / Vendor ATI Radeon X1650 Pro
  • Graphics Card Performance This card's graphics processor and memory mean that it is not recommended for most games, but it will still be fine for office applications and other normal computing tasks.
  • RAMDAC Clock Speed 400.0 MHz
  • Video Memory Installed 512.0 MB
  • Technology DDR2 SDRAM 128-bit
  • Features Avivo Technology
Video Input
  • Type None
Video Output
  • API Supported OpenGL 2.0,
    DirectX 9.0
  • Max Monitors Supported 2.0
  • TV Interface HDTV out
  • Analog Video Format S-Video,
    Composite video
  • Digital Video Standard Digital Visual Interface (DVI)
Expansion / Connectivity
  • Interfaces 1.0 x DVI-I (dual link) - 15 pin HD D-Sub (HD-15),
    1.0 x HDTV output - 29 pin combined DVI,
    1.0 x VGA
  • Compatible Slots 1.0 x AGP
  • Microsoft Certifications Certified for Windows Vista
Software / System Requirements
  • OS Required Microsoft Windows XP,
    Microsoft Windows XP Media Center Edition 2005,
    Microsoft Windows XP 64-bit Edition,
    Microsoft Windows Vista
  • Recommended Power Supply 350.0 Watt
  • Peripheral / Interface Devices CD-ROM
Feb 22, 2011 | ATI RADEON X1650 Graphic Card
Can the Dell Latitude D610 run any of the following games: Age of Conan Star Trek Online Champions Online Aion
Check your system if it meets the following requirements
Age of Conan
OS: Windows Vista/XP
Processor: 3GHz Pentium IV
Video Card: Shader Model 2.0 and 128MB RAM: NVIDIA GeForce 5800 or ATI 9800
Processor: Intel Core 2 Duo 2.4 GHz (E6600) or better
Video Card: NVIDIA GeForce 7950GX2 or better
RAM: 2GB or more
Enhanced for: DirectX 10, 64-bit processors, multi-core
Supports Parental Controls on Windows Vista
Start Trek
System Requirements
  • OS: Windows XP SP2 / Windows Vista / Windows 7 (32 or 64-bit)
  • CPU: Intel Core 2 Duo 1.8 Ghz or AMD Athlon X2 3800+
  • Memory: 1GB RAM
  • Video: NVIDIA GeForce 7950 / ATI Radeon X1800 / Intel HD Graphics
  • Sound: DirectX 9.0c Compatible Soundcard
  • DirectX: Version 9.0c or Higher
  • HDD: 8GB Free Disk Space
  • Network: Internet Broadband Connection Required
  • Disc: 6X DVD-ROM
Recommended System Configuration
  • CPU: Intel E8400 Core 2 Duo or AMD Athlon X2 5600+
  • Memory: 2GB RAM+
  • Video: NVIDIA GeForce 8800 / ATI Radeon HD 3850+
  • Disc: 6X DVD-ROM
To check your system hardware> click on start>all programs>accessories>system tools> system information.
Thanks for using Fixya
Mar 27, 2010 | Dell Latitude D610 Notebook
Okay, you don't need two video cards. Your 4 memory slots are grouped in two's. One set is black and blue, and the other set is black and blue also. These are your dual memory channels.
The reason you can't see more than 2 gig ram is because you are probably not running 64 bit Windows with a 64 bit processor.
32 bit windows will only display 2 gigs, but max memory is 4 gigs. It will draw on the extra 2 gigs if ever it is needed, but this does not happen very often, if ever.
Jul 14, 2009 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
Help me to choose right component for Radeon HD4850 512MB ddr5?
run at least 2.5 gig of memory. You can get them cheap on ebay. Processor should be duo core or equivelant. Single processors work, but do lag. Graphics cards are not actually as important as people think. You can use a stock graphics card with good processor and 2-4 gig of memory and have a good gaming computer.
Jul 11, 2009 | ASUS EAH4850/HTDI/512M RADEON HD 4850...
What causes your video to freeze?
sounds like a hardware fault, do you get an error msg and blue screen? ide say motherboard and video card not running correctly, swap the vid card first, see if this helps,
Jun 07, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
direct x10.
Jan 08, 2009 | HP Pavilion dv6000z Notebook
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
Computers & Internet Logo
221 people viewed this question
David Payne
David Payne
