Question about Dishwashers
Dishlex dishwasher won't heat up - Dishwashers
3 Suggested Answers
SOURCE: Dishlex DX302SB Dishwasher water not
Mine too displayed the same problem - not heating, therefore not cleaning or drying properly (door still cold 20 minutes into cycle). I've found that there is a common (yet not often talked about) issue with a point on the controllers circuit board. If you remove the controller (simple to get at), remove the circuit board from the controller and flip it over you will see a 'burnt' solder joint on one of the legs to a black box component - resolder that joint and all should be well. Don't pause or open the door during a cycle as this seems to cause the joint to blow.
Posted on Jul 23, 2008
  • 713 Answers
SOURCE: dishlex global 300 : dishwasher dispenser won't
Hi just read your posting.The problem could be a faulty dispenser coil ,or the wires to it are faulty or the computer is faulty.Try selecting a normal eco wash and when you push the start button to start the machine hold the button in until the pre wash light turns off.This should make the dispenser activate straight after it fills.The only way to test which part is faulty is with an electrical meter.Have you or can you borrow one.If so then I can guide you step by step in finding the fault.please reply with additional information and I am sure I can help you further.Looking forward to your reply.
Posted on May 22, 2011
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
What would make my dishlex dishwasher display the error code i60?It runs the wash cycle and stops.
Heating time out. Usually is heting element defective or relay on main board.
Dado
Sep 03, 2014 | Electrolux Dishwashers
Dishlex dishwasher won't complete a cycle. Number 60 shows up and a small flashing line. ??????
Drain pump is blocked. .If you are good with tools you can clean it yourself. Let me know
Mar 28, 2013 | Dishwashers
My dishlex dx103sk won't start at all. How do I fix it?
Hi Daniel,
model dx103sk Electrolux
I am getting water hammer through copper pipes
every time dishwasher water valve opens and closes
I have changed 3 types of anti hammer washers on supply tap.
also changed the one way water valve at hot water service
next I am looking at changing the pressure valve next to the dishwasher as this problem really on happen when I changed brands of dishwasher.
? kpa rating do you think I should use?
Am I going down the right path here?
thanks David Desira
Jul 19, 2012 | Dishwashers
Dishlex Global 200 won't fill with water
Shut off the water to the dishwasher. Take the line off where it connect to the dishwasher. Get out a bucket (dishpan, etc.) and put the open line into the bucket, turn on the water. Does it have a good stream? If not the problem is in the supply coming from your house. If the stream is good, house water is fine. Connect the supply back up, find the electrical solenoid that the water feed goes to and disconnect the line on the other side of it. Try turning the dishwasher on with bucket catching water, when the solenoid clicks on is there a good stream of water? If not either solenoid is bad, or maybe there is a filter (screen) before the solenoid that needs cleaned. If there is a good stream after the solenoid, then the controls must be bad telling it to shut off too early.
Dec 25, 2011 | Dishwashers
Dishlex global 300 : dishwasher dispenser won't
May 22, 2011 | Dishwashers
No drying cycle on the electrolux dishlex 302 any idea's
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Nov 10, 2010 | Electrolux 18 in. ESL4114 Slim-Line...
Elextrolux dishlex DX 302 - not cleaning dishes properly and dishes still wet after drying
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Sep 12, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Dishlex Global Unable to remove heater element retaining screw
I have a simialar problem with the Dishlex 450 Global model, after searching for the heating element on line, I found a picture of the element (450 model), showing that the Stainless Steel screw is actually spot welded to the element bracket, hence you should be able to remove it by accessing a retaining nut from underneath the dishwasher....(turn power off first!)..
May 24, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
Dishwashers Logo
Top Dishwashers Experts
