Question about HP LaserJet 4700 Printer
Standard top bin full.. remove paper
My printer is not printing due to a system error "standard top bin full remove paper"
jaylex
  • 417 Answers
SOURCE: standard top bin full remove paper
Hi there is seems that the machine thinks there is too much paper at the paper printout exit. If there are printouts on the top of the printer remove them and the printer will start printing or the error message will go away. If there is nothing on top of the printer then where the paper comes out after it has printed you will see a black plastic lever type it is more likely to be in the up position without breaking it if it hasn't already been broken move it so it is in the down position it is on a hinge so be careful and it should sit at an angle. Once this has been done the printer will reset the message itself.
Hope this is help you oh if the arm is broken it will need replacing (just the arm)
Thanks J
Posted on Jan 13, 2008
  • 49 Answers
Greets!
Firstly, is the exit bin full of paper? If it is, just remove it.
If not, then it's going to be a sensor that recognizes the paper amounts in the exit tray. Check for broken plastics and possibly stuck plastic flaps in the exit tray.
If it's neither of those, try turn it off, unplug, then reverse.
Other than that, if no go, then it's an internal sensor issue. At that point, probably the best bet is to replace as repair costs would outweight a new unit cost most likely.
Posted on Feb 27, 2009
  • 46 Answers
SOURCE: when i try to print its comming up standard top
either the paper switch at the exit is stuck or the light barrier is bad or the cable came off
Posted on Oct 23, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: standard top bin full remove all paper from bin
Check the sensor flag where the paper exits the printer and make sure it is not stuck in the "up" position. This is a small black plactic flap right in the center of where the paper exits. When this flap is up it tells the printer that this area is full. HP says to "flip" the sensor flag up and down to make sure it is not stuck.
Good Luck
Posted on Nov 25, 2009
  • 87 Answers
SOURCE: Standard top bin full remove all paper from bin
Is this occurring even with no paper in the face down top bin? Likely a stuck paper sensor flag, or dirty optical sensor. You need to remove the top to access it, investigate and replace the flag or sensor, or clean the optical sensor. Service manual free at feedroller.com - look down the left navigation bar for an icon and link to service manuals. You can download the PDF free - dont make people selling copyrighted material on ebay rich.
Top cover isnt that hard to remove and requires patience and a #2 phillips screwdriver. Be careful of the cable for the display and buttons when you lift the cover off.
Posted on Jun 25, 2010
Printer shows standard top bin full
Where the paper exits, there should be black tabs that lift up each time a page exits. They might be stuck in the up position, or possibly broken. Usually caused by aggressive removal of a paper jam.
Sep 24, 2014 | HP LaserJet 5200 Printer
Can not print. Standard top bin full shows up on the display
Clean top bin sensor.
Remove back cover., observe a flip moving up & down while paper is coming out & the same was fed into a ir sensor., u can see from back side., clean that sendor with good brush or cloth..
Standard bin full
This error is cause by either having your output paper bin full of paper or the flag sensor out of alignment where the paper comes out of the top. Look at the top f the printer where the paper comes out and you should see a black plastic sensor flag, it should move freely. If it is stuck remove the top cover above it and try to free it so it can move. Below is a picture of the printer with the output sensor flag circled.
Feb 02, 2013 | Lexmark T632 Laser Printer
Hp 5550n error - standard output bin full please remove all paper from bin
After print paper reaches upper bin, you can observe a flag moving while paper coming out. once this flag is stopped moving printer treates bin full..check the flag is moving freely. open top cover clean this sensor.
Sep 21, 2011 | HP Hewlett Packard LaserJet 5550n Printer
I can not print from my lexmark t642 printer. I get this message " Remove paper from Standard paper bin." I do not have any paper in that area.
If there is no paper on paper bin and you are getting error to remove paper from the standard paper bin, please check for paper jam. it possible that paper stuck right on the path on the paper bin.
For further assistance, please contact Lexmark Technical Support.
Sep 12, 2011 | Lexmark T642 Laser Printer
When i on the printer then "standard top bin full
Just check at upside where paper iscoming out after print, there you can see the two black flips to monitor the paper out position, this flag sensor got dusty this error apprears, remove back cover, you can observe left side this sensor, just clean it..
Aug 25, 2011 | HP LaserJet P3005 Printer
My printer Lexmark T634 is showing "remove paper standard bin"
What your printer is telling you is that it thinks or knows that the top exit tray for the paper is full. This is the tray that is moulded into the top of the printer.
This caused by two things. It is actually full or the Bin Full Actuator is out of position and forcing the error condition.
Look at the standard bin. Over to the top at the top left corner there should be finger (almost the same as paper clip) hanging down. If it is not there, then it is more then likely that the finger is jammed up.
Don
Nov 04, 2009 | Lexmark T634 Laser Printer
Standard top bin full error in hp 5200 tn laserjet printer
i have hp 5200 printer
printer shows message top bin full
and not prints what slution of this error
Aug 28, 2008 | HP LaserJet 2420 Printer
Hp 3800dtn standard top bin full remove paper error
top bin full error is hte lever sensor where you see the paper coming out, the lever is stuck in the up position.
It's used to tell you to remove the paper from the exit because it's too full.( Too many copies on the top)
Jun 27, 2008 | HP Color LaserJet 2600n Printer
Standard top bin full remove paper
Thanks J
Jan 12, 2008 | HP LaserJet 2420 Printer
HP LaserJet 4700 Printer Logo
302 people viewed this question
Seeker5211
Seeker5211
