Question about GE Refrigerators
GE Monogram 48" Freezer light works randomly
Master board switch in on. refrigerator works good. No problem with freezer except for bulb working randomly
  • John Tripp
    John Tripp Feb 25, 2012
    Thanks for your rate and comments Shereen! I did notice the lighting circuits going through the motherboard page 31 of PDF on your Monogram. I have a feeling you have a short in the Motherboard at pin 7 or the door switch causing the two 35 watt bulbs to put out 70 watts continuous. That is like heating and cooling at same time in your freezer and will cause excessive power use. If the source is motherboard the problem will also damage the low voltage side of the motherboard. I would be right on it if it were I but thanks for mentioning the motherboard because yes of course I looked. Shereen. GE needs good Technicians like yourself! Again Thanks, John Tripp
  • GE Master
  • 4,654 Answers
About the only way to determine what is causing the intermittent lighting to your freezer is to do a little electrical testing with a multi-meter. Also to press the door light switch in and wiggle it around may help you locate a bad door switch that simply can be replaced if the light decides to come on only when the door switch is pressed and released a certain way. Click here=> GE_Monogram_Refrigerator_Service_Manual Fresh Food and Freezer Light Diagnostics begin on page 46 of the PDF. I will be here if you have any questions but most of the physical testing will need be done from your end Testing the bulb sockets for firm connections and a good steady 12 volts output and 120 VAC input. If helpful please rate, Thanks, Sea Breeze
Posted on Feb 22, 2012
Testimonial: "Excellent advice. The electrical testing showed no problems. However lights came back on and have been on for the last few days. We jiggled the freezer door switch when the lights were out and it made no difference. It will be a matter of time before the lights will go off for no reason. Maybe it is in the main board."
Sea Breeze
  • 4654 Answers
SOURCE: GE Monogram Side by Side 42" Freezer light is lit on front panel.
The defrost timer is what I think you are asking. It is behind a cover near the light, The timer puts the fridge in defrost ever 6 to 8 hours. If the timer is bad it will stop the cycle of defrost and cause the freezer and the cold food section to warm spoiling the food and increase the freezer temp. Try turning the timer screw clockwise until you hear the fridge compressor stop. If after this listen for a crackling noise that will be the sound of defrost taking place. If doing this starts defrost, you will need to replace the timer.
Posted on Oct 21, 2007
SOURCE: Refrigerator warm, freezer too cold
I had this same problem. You need to totally empty the fridge and freezer and allow it to defrost for 24 hours. Then put it back on and it will work. This happens if someone leaves the freezer door open and then it gets closed. The defrosted water freezes in the pipes and doesn't allow the cold air to move up into the fridge so the freezer gets even colder. This has happened to me twice!
Posted on Aug 16, 2008
docjohn174
  • 943 Answers
SOURCE: GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Posted on Oct 15, 2008
  • 46 Answers
SOURCE: GE monogram ZIS420D. freezer reading 17degs and
to much stuff in the frezzer?
Posted on Jun 26, 2009
heatman101
  • 43501 Answers
SOURCE: GE Monogram Freezer wont defrost
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 31, 2010
Zis480mnc ge monogram built in refer temp varies from 34 to 48 several times a day.
Try replacing that evap thermistor. The diagnostics on thermistors can be wrong. If it is rounded on the end, replace it. There is a damper between the freezer and refrigerator. There may be a refrigerator fan motor in the damper assembly, It could be bad. It could be a bad control board. When you run diagnostics there is one function that checks all the fans.
Sep 25, 2014 | Refrigerators
Temperature Cycles Inconsistently in Freezer and Fridge
Possible thermister our main board. Would need take readings at the board to see what the themisters are reading. If they check good then issue would be in main board
Aug 20, 2012 | GE Monogram Side by Side Refrigerator
48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
Aug 16, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
My refrigerator is a GE Monogram ZISS480NRGSS S/N SH031008. The temperature in both the freezer and the fresh food sides increased and did not go down. A technician came in and changed a valve (I do not...
We need to have a look at the main control board part number WRO2X11838 Tell me if the compressor is running while no cooling or if stopped. Unplug refrigerator and see if the top of compressor is too hot to keep you hand on. My drawing show the control bord in the area of the compressor and inside a box. Let me know if it has burn marks on both sides. Thanks, Let me know, Sea Breeze
http://servicepartstec.blogspot.com/
May 20, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Warm fridge cool freezer
Hi folks,
IS, the freezer so packed full with packages that they are covering the air vents in the freezer that must be open to share the circulation with the fridge?
Let me know!
If not keep calling the server and pay him only when he fixes it!
Sep 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram freezer not freezing food & refreegiration side not cold enough
first thing to look for is the freezer fan running. then is the air circulating in compartment. blockage is a cause. themostat setting is important.you can leave freezer door open and trigger the door switch.you should feel cold air comming ot. i know it may sound silly check to see if freezer light goes off when shutting door. fan,circulation,cold air input.thermostat,lightoff. good luck
Jun 28, 2008 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram ziss480dmss Side-by-side refrigerator
no replace the door control bd or check for a loose or bad connection on the control bd also in an abstract sense one of the freezer door switches could be bad ones for the freezer light ones a safety for the door dispenser sys but that would be rare but possible
Mar 28, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Refrigerators Logo
263 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
