Question about Sharp Office Equipment & Supplies
Looking for where in Lagos Nigeria to buy toner for Sharp Copier AR-5516 and cost of the toner
Where to buy toners for Sharp Copier AR-5516
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
sir fixalot
  • 146 Answers
SOURCE: Ar-5132 sharp copier
H3-XX codes involve the fusing unit temperature being too low or too high.
Try resetting the error.
[C] – [INTERRUPT] – [0] – [INTERRUPT]
Type in 1 4
Hit [PRINT]
Turn power off then on if it doesn't do it automatically.
If error doesn't reset then you have other trouble
I hope you ran the developer setup and reset all of the parts counters for the items you replaced. Not setting the developer reference can cause a host of problems.
Sim 25-02 adjusts developer.
Sim 42 clears DV counter
Posted on Jun 06, 2008
SOURCE: add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
Posted on Nov 10, 2008
  • 5 Answers
SOURCE: sharp digital 5516 drum life indicator along with
Try a reset first (Press #, interupt,c,interupt, then 14 start), If it pesist, Check the drum for injury lines, the developer for inpurity and clean the toner catradge proper, the close all machine doors. Good luck.
Posted on Apr 03, 2009
  • 1294 Answers
SOURCE: SHARP AR-203 copier unusable after refill
Change the unit chip or reset him.
Posted on Sep 01, 2009
My sharp xerox machine AR-5516 is bleaking a man near toner signal point. why is this bleking? Kindly solve my problem.
The blinking man who we refer to as Mr Bill is a "time for maintenance light". Just ignore it, the machine will keep working.
Aug 21, 2011 | Sharp AR-5320 Black and White Copier
I' ve a problem with copier ar 5516. i need information about using of developer. where i must to put the developer? the toner AR-021FT IS COMPATIBLE WITH THIS COPIER?
yes ar021FT toner compatible for your 5516. when replacing the developer:1) pull out the toner cartridge,2) pull out developing unit with 1 screw (blue),3) in developing unit remove 2 screws (blue) to open its top cover,4) drain d unit and replesnish with new developer. do procedure 4 to 1 to return. Good luck.
May 22, 2011 | Sharp AR-5320 Black and White Copier
I NEED A SHARP SERVICES CENTRE ADDRES IN LAGOS NIGERIA FOR MY COPIER MACHINE
i need the address of where i can buy sharp photocopier machine AR 5316 E.
Jan 20, 2011 | Sharp AR-5316 Advanced Digital Imager...
Solutions for Sharp copier 5516 error code f 2
If you change the toner nearly it refer to toner cartridge otherwise ; press "print" key to see the sub code. and if I know the sub code I can hep you more .
Jan 12, 2011 | Sharp AR-5316 Advanced Digital Imager...
AR 5516S SHARP COPIER IS SHOWING F2 4O FAULT CODE DURRING INSTALATION. WHAT COULD BE THE CAUSE. PLEASE.
During installation , use sharp ar205 developer and sharp ar021 toner cartridge. This shows you did not use developer or used the wrong ones, good luck.
Mar 12, 2010 | Sharp AR-5320 Black and White Copier
Sharp digital 5516 drum life indicator along with a man flashing. Also any compatible toner available for sharp 5516.
Apr 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5127, the error code U2-40
SOLUTION: ERROR MESSAGE U2-40, SHARP COPIER AR-5127
PRESS #
PRESS =
PRESS C
PRESS =
TYPE 16
PRESS ENTER BUTTON (the button for making photocopy)
PRESS 'OK' TWICE
Note: be fast in pressing all the buttons.
FROM EKPA ONU - (+2348055790979, NIGERIA,LAGOS)
Apr 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
60 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
