Question about Frigidaire GLWS1339CS Top Load Washer
Dryer not working
The dryer starts but the drum dosen't roll,what could be the source of the problem and on the day it happened,a smell of something burning came up.
    Scholar:
  • 147 Answers
The smell was your belt burning into. (If it smelled like rubber) Take the bottom of your back panel off and you will see your belt just hanging in there. Cost $15 to replace and eazzzy to do.
Posted on Oct 27, 2008
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
The dryer makes a lound noise like grinding and smells like something hot or burning. I see no smoke and it started ok after a couple of turns or so the first time but the second time was when I smelled...
my daughter had a maytag dryer doing the same thing. I took it apart and the bracket that holds the drum broke off. it is cheaply made. what happens it that this causes the drum not to spin freely and causes a lot of resistence on the motor. the motor will get over worked and also the belt will slip causing smell and heat. my daughter ran hers for a while it was doing this and it also messed up the motor. we just bought a new dryer. all these parts are available, but it might be cheaper in the long run to get another one.
rick
Jul 18, 2011 | Maytag Dryers
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Dryer won't start
Good day,
Sounds like the motor is trying to start but can't. If the drum turns freely then the motor is likely shot.
If the drum is locked, then disassembling the machine and find out why. Frankly once the windings are burnt, beside anything else that could be wrong, the motor is unlikely serviceable.
Thank you for using FixYa
Jan 19, 2010 | Dryers
Frigidaire dryer quit
sounds like the motor unless something is stuck in the blower housing such as a sock
Jul 13, 2009 | Frigidaire Dryers
Horrible noise and burning smell when dryer is on
Same thing happened to us, the noise is one of your wheel bearings are going bad, (they are just a small piece of plastic rollers) and the smell is your belt. The dryer is dismantled from the front. I figured out how to take my dryer apart from google. Also, you may need some help to pull out the drum wheel and pay attention to how it came out. I ordered parts from repairclinic.com and it was very inexpensive and the parts took 3 days to come to me ( I wouldn't pay for faster shipping).
Good luck, you won't believe how uncomplex your dryer really is.
Jun 06, 2009 | Kenmore 62602 Electric Dryer
Dryer stopped working after working w/door open or closed
Sounds as if the door switch/latch had stuck.the smell was probably a small short. try unplugging unit. But I would imagine you need door latch/switch replaced
Feb 06, 2009 | Malber TD700 Electric Dryer
My maytag neptune gas dryer model #MDG3000AWW When I push the start button on my maytag neptune dryer it sounds like it wants to start but doesn't and then it gets this smell like something is burning?...
It sounds like the drum bearings are seizing up preventing the drum from rolling easily, and when the motor runs, it can't pull the drum belt around the drum that won't turn, so starts squealing and burning the belt.
You need to lubricate/replace the drum bearings, and replace the belt.
Jan 29, 2009 | Dryers
Frigidaire GLWS1339CS Top Load Washer Logo
65 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
