Question about Philips Magnavox 27MS343S 27" TV
Folddover at top of picture about an inch from top
Magnavox 27mt3305/17 The picture at the top of the screen has a foldover about an inch from the top the rest of the picture is good
  • 20 Answers
Replace cap. 2465 and cap. 2561. That should take care of it unless the vertical transistors are bad or there are other bad caps.
Posted on Dec 30, 2008
  • Also try replacing diode 6460. It is an smd device right around where the vertical transistors are. That should do the trick. It did it for me.
Vertical foldover on bottom of 32 inch samsung lcd tv about 3 inches across bottom of screen
usually on all image related problem on all LCD comes from faulty t-con board..but for sure try to play dvd movie to test if the problem is on tv/t-con...
Jul 18, 2012 | Televison & Video
My Toshiba mw24h63 has a vertical foldover about 6 inches high at the top of the screen. What is the cause and can it be easily repaired?
caps in vertical circuit. 100uf or 220uf . the ic is in the middle back long ic with about 10 to 12 pins on a heat sink. caps are bad and utube has pictures.
Nov 04, 2010 | Toshiba MW24H63 TV
I have a 20ms3442/17 the screen only shows the bottom half of the picture and the upper half is lines and a reverse image on the first half of the top of the lower half
You have a vertical foldover. Check the caps near the two vertical ICs. HMMM it does not surprise me...There could be a couple of suface mout caps. to check...I do not remember the locations at this time. But try the electrolytics...they are easy to check.
Nov 29, 2009 | Philips Magnavox 20MS3442 20" TV
Picture problems
There is a problem with the vertical circuit. Eventually th foldover will get worse. If you are comfortable working inside the set, with a little investigation, you should be able to resolve this yourself. If you would like to attempt the repair, update this and I'll provide additional details and instructions. Realize that this will take a few interactions to locate the defective part.
Dan
Jan 29, 2009 | Televison & Video
Phillips Magnavox 60 inch tv
not showing a picture are making a sound.
Jul 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
Wide black area top of the screen.
More than likely it's not the crt. If the picture has "foldover" at the top of where the picture is currently, then more than likely there are bad caps. in the vertical scan circuit. If not, the vertical sizing probably just needs to be adjusted. You will have to get in to the service menu to do that.
May 26, 2008 | Philips Magnavox 27MT5405 TV
TV picture
This set will need to be serviced by a tech shop as you have a problem called "vertical foldover"...accordianman
Apr 09, 2008 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Philips magnavox 32" TS3260C1
Sounds like retrace lines. Leaky caps or worse can cause this.. Are you getting any vertical foldover at the top of the screen?
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
179 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
