Question about Casio FX5800P Scientific Calculator
I couldn't switch on the casio fx-4800p calculator
Yes
SOURCE: m mod n in Casio fx991MS
there is one button ab/c beneath CALC... if u want to calculate 7 mod 4 then... u should press 7 then ab/c 4 and equal to
1, 3 ,4 which is 4*1=4 and 7-4=3 remainder...
Posted on Jun 29, 2009
  • 7993 Answers
SOURCE: how do i calculate permutation in fx-82ms casio
Find on the calculator the [nPr] key either (you may have to use the [2nd] or [2ndF] key) then
1. Enter the number that corresponds to n eg. 18
2. Press the [nPr] key
3. Enter the number that corresponds to r eg. 5
18[nPr]5 gives 1028160
If you calculate combinaitions use [nCr] key.
Hope it helps
Posted on Sep 06, 2009
  • 7993 Answers
SOURCE: how to calculate inverse of a 3x3 matrix in casio
Here is the solution for th FX-991ES.
The error may be due to the key you used to signifie inverse. It says in the manual that you should use the key x^-1 not the one used to input general powers.
Here is screen capture from the Appendix to the manual. The picture shows the sequence of keys to press to obtain the inverse of a 2x2 matrix. It is taken from page 41 of Appendix
The matrix used in the exemple is
a_11=2 a_12=1 a_21=1 a_22=2
Here is the link to download the manual and the appendix
http://support.casio.com/manualfile.php?rgn=1&cid=004001004
The link is for FX991ES. Look there foe you manual.
Hope it helps
Posted on Sep 07, 2009
  • 7993 Answers
SOURCE: Casio fx-9860g ............ how to do percent operation
[OPTN][LIST] scroll right till you find %. Press the function first then the number. It gives you the percent.
Hope it helps.
Posted on Oct 01, 2009
  • 7993 Answers
SOURCE: Hi, I have a Casio calculator fx-991MS giving me wrong answers!
I am only looking for a plausible cause of the error, because I do not believe your calculator can make such a mistake. I think you accidentally activated the Exponential display format and did not pay attention to the small, raised -03 that came at the end of the number displayed. It is a common mistake for those not very familiar with Scientific or exponential notation.
Let us try to reset your calculator to the normal (floating point) format.
Press the [MODE] key a number of times until you reach a screen that has FIX, SCI, NORM and under each one a number (FIX 1, SCI 2), Norm 3). To have the number of decimal place you gave in your result (4 decimal digits), you press 1 to select Fix then 4.
Be aware that scientific calculators usually stop displaying results in floating point format ( 0.0000045 ) if the number is smaller then 0.001. So basically, 0.00099 will be displayed as 9.90-04, -04 being raised above the level, and in smaller size.
Hope it helps.
Posted on Oct 02, 2009
Testimonial: "Thanks so much, its working now:) I thought I was going to have to buy a new calculator!"
How to do interpolation in Casio f2f-4800p?
Interpolation mannual in fx-4800P - Fixya
www.fixya.com/support/t22818601-interpolation_mannual_in_fx_4800p
Jan 11, 2014 - interpolation mannual in fx-4800P - Casio Rare Vintage Scientific question. ... SOURCE: how can we do linear interpolation in casio fx-991ES ...
interpolate how can interpolate linear regression by casio ...
www.fixya.com/support/t22818666-interpolate
Jan 11, 2014 - interpolate how can interpolate linear regression by casio fx-4800P -Casio ... SOURCE: how can we do linear interpolation in casio fx-991ES ...
how to perform linear interpolation manually and on casio fx ...
? 6:39
https://www.youtube.com/watch?v=rCVM6RWMjQ4
Jan 7, 2015 - Uploaded by Yabets Jab
In this video you can simply understand how to find a value of a given missing number in a table on Casio fx ...Missing: 4800p
Linear Regression on a Casio calculator - YouTube
? 6:25
https://www.youtube.com/watch?v=OGmHagjZPjg
Oct 31, 2012 - Uploaded by cpobyrne1
How to perform a linear regression on a Casio scientific calculator. Example uses a ... A Casio fx-83WA calculator is used for the demonstration. .... Lagrange Interpolation Easily Explained on Casio fx-991ES Calculator!Missing: 4800p
Jan 05, 2016 | Casio Office Equipment & Supplies
I'm using fx-570ES..i couldn't find the inverse matrix using the method shown..it keep showing syntax error..hope u can help me..
Not all matrices are invertible. The matrice must be square.The matrix must be non-singular: Its determinant must be different from 0. Your error comes probably from the key you used to calculate the inverse. Use the reciprocal key, the one marked with x^-1. If the marking is not ON the key, use the SHIFT button prior to pressing the relevant key.
Sep 04, 2011 | Casio FX-115ES Scientific Calculator
Can a casio fx-115es reduce fractions
Yes. Simply enter the fraction and press =. If the calculator is in the MathIO mode it will display the fraction in its simplest form. If you're in the LineIO mode, press the S--D button to convert the decimal to fraction.
Aug 18, 2011 | Casio FX-115ES Scientific Calculator
Can I convert Decimal Degrees to Degrees, Minutes, Seconds on my casio fx-991 ES?
Yes. Pressing the DMS key (two keys above the 8 key) when a result is displayed toggles the result between decimal degrees and degrees-minutes-seconds.
For example, to convert 3.5 degrees, press 3 . 5 = and you'll see 3.5. Now press DMS and you'll see 3 degrees 30 minutes 0 seconds.
Jul 31, 2011 | Casio FX-115ES Scientific Calculator
A mod B in Casio fx-115MS How to get an m mod n (ie to calculate modulo of a number)
It's a bit convoluted, and it only works for integers, but here's one way. Press MODE 4 to switch to BASE-N (integer) mode. If the screen doesn't read "Dec" then press the x^2 key. Now, to calculate m mod n, calculate m-m/n*n. No shortcuts, no rearranging. That's m minus m divided by n times n. You have to enter both numbers twice, but you will get the modulus.
Press MODE 1 to return to your previously scheduled calculations.
May 30, 2011 | Casio FX-115MS Plus Calculator
As the Casio FX-991es Plus got a modular function if not this there away of performing mod on it.
It's a bit convoluted, and it only works for integers, but here's one way. Press MODE 4 to switch to BASE-N (integer) mode. If the screen doesn't read "Dec" then press the x^2 key. Now, to calculate a mod b, calculate a-a/b*b. No shortcuts, no rearranging. That's a minus a divided by b times b. You have to enter both numbers twice, but you will get the modulus.
May 03, 2011 | Casio FX-115ES Scientific Calculator
How to get the imaginary numbers on the 115es casio calculator? It is in purple and i cant get it with shift.
You need to be in complex mode before you can do any calculations involving complex numbers. Press MODE 2 to switch to CMPLX mode. When you're done, press MODE 1 to switch back to COMP mode. (Yes, the names are confusing. I didn't pick them.)
Dec 14, 2010 | Casio FX-115ES Scientific Calculator
How do I factor using the fx-115 ES calculator? would a problem like 9x^2+24x+16-Z^2 be solvable on this calculator? If not, does Casio sell any calculators that would help me factor this equation?
No, your calculator cannot factor polynomials. You need a calculator that has a CAS (computer Algebra System)
Yes Casio sells calculators with CAS: The FX-Algebra 2.0 and 1.0, the FX-9860GPLUS/GII SD, the GRAPH85 or 80 and the Graph 100+. You also have the CLASSPAD Series 300PLUS and 330.
TI and HP also have CAS calculators.
Texas Instruments
TI 89 /Titanium, Voyage 200PLT, TI92PLUS (discontinued), TI Inspire CAS.
Hewlet-Packard
HP 48G/G+/GX, HP40G, HP49G/G+ and the top of the line HP50G
Oct 28, 2010 | Casio FX-115ES Scientific Calculator
Casio FX5800P Scientific Calculator Logo
153 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
