Question about Fuji FinePix S5000 Digital Camera
Lens has become Loose
Hi.I have recently noticed that the lens has become kinds loose where it joins the body. It feels losse in it's socket.seems to take pics fine but it can't be right:o)
Anyone seen this before?
Thanks ppl :o)
Isn't the internet amazing?? :o)
  • LazyRiverzz Nov 16, 2008
    Thank you for that my friend. It has at least put my mind at rest:o)
    Bless you :o)
    Sincere Regards
    James:o)
  • 593 Answers
If it is at all like my C8080, there are 4 screws that hold the lens guard in place, accesible only when the case is opened. This is the fixed tube that the lens extends out of. The knurled coller is a screw on piece that allows a lens tube to be screwed on, that can be tightened by hand. If the lens itself seems kinda wobbly, that is normal and is just showing a little sign of age. It wont affect the picture. The lens rides on helical rails on a rotating inner barrel and these rails and bushings get a little worn over time.
Posted on Nov 16, 2008
When i look through the viewfinder its darker than usual, my lens wont seem to come off its stuck even while holding down the release button and trying to rotate it by force. When taking pictures on auto...
Hi tin_080 , the aperture actuating lever was bent or loose and is ahead of the control mechanism of the diaphragm opening in the camera body.
Check this: point the lens towards you notice that the diaphragm is closed.
To avoid more costly damage you take it to a workshop for servicing.
Best regards
Mar 26, 2011 | Nikon D90 Digital Camera with 18-105mm...
Err 99(Error Code). Removed battery and re-instaled. Still no image on display or Flash Card. Problem with my EOS Rebal 300 Digital Camera.
Seems to be related to the lens, is it fit to be used with this camera? disconnect the lens and try again.
Aug 19, 2008 | Cameras
Hi, I have a Canon EF 75-300mm f/4-5.6 II Lens. I recently noticed that if the lens is pointing down, the zooming barrel is going to 300 by itself. Is there anything i can do to fix this? Whet it was...
Definitely do NOT open the lens!
This can cause much bigger problems like misalignment of glass etc.
Take this lens to a professional if it's causing that much of an annoyance to you.
Mar 07, 2011 | Canon EF 75-300mm f/4-5.6 II Lens
Left brake light
open the trunk and pull the fabric away from the inside of the hold the light in place. Make sure you back of the brake light. There are plastic wing nuts that you remove to take the whole lens out of the body. When you have taken all of the wing nuts off, the lens wil become loose. Push on the studs that go through the metal part of the body and follow the wires to the sockets and turn them a quarter turn to release the socket from the lens. Replace the bulbs and put it all back together after you have tested all the lights. Best of luck and be safe..
Apr 22, 2009 | 2000 Mercury Sable
Unable to take photos. F stop flashing and r05 message shows.
do a reset in custom menu and you will be back to out of the box set up
Apr 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
Loose part inside nikkor lens
This part serves no useful purpose if you can fish it out do so!!
Mar 29, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Manual Focus won't work
Which camera are you using? If the body has AF/MF switch, put that also to MF.If this fails to help, take out the lens and try to change it to MF.
Feb 05, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
17-85MM IS - mechanically stuck at 17mm - will not zoom -
Hi all,
I've had the same problem. So I decided to give it a try because I didn't find any solutions on the net. Unfortunately you have to pay pretty much for a Canon lens while the internal quality is pretty cheap, the whole mechanism is of plastic and this is also the problem. And after a while some screws will vibrate loose from the plastic components and canon could have done this better.
Probably within your lens is now one of the three zoom mechanism screws complete removed and you will notice that there is some abnormal movement in the zoom part. Unfortunately these screws are deeply mounted inside the lens and you need a lots of skill and patience to get it fixed.
First you need to completely disassemble the lens, and please make a picture of your lens after every step you make because I had to disassemble my lens 4 times! Because some of the elements was not right in place.
I will try to place a more complete description later today including some pictures.
Regards Gert
Aug 30, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Lens is loose from body
One note on this fix. There are four screws that need to be tightened on the lens. With the cover off and the lens pointing straight forward, there are three small screws visible. After tightening them, rotate the lens upward to expose the fourth screww. After that one is tightened, you can then replace the cover and six cover screws.
Jan 18, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
Lens assembly
"Lens Error" requires to be sent into repairs.
Sep 12, 2006 | Casio Exilim EX-Z40 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
81 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
