Question about Dell Optiplex GX280 Intel Desktop PC - Intel P4 3.0GHz, 512MB RAM, 40GB HDD, CDRW, 10/10
Memory size error - Dell Optiplex GX280 Intel Desktop PC - Intel P4 3.0GHz, 512MB RAM, 40GB HDD, CDRW, 10/10
  • Rasputin666 Feb 21, 2012
    What is the error ?
A pc shows memory size error ?
Posted on Nov 07, 2012
Memory error
G1W card formatting issue - Dash Cam Talk
dashcamtalk.com > ... > Generic Chinese Cameras > G1WX
Nov 18, 2013 - 20 posts - ‎12 authors I ended up assuming that they meant CLUSTER size, or also called ... Worked right away and started recording when I turned the car on. ... I had a complete memory errorwith this brand and size card even ... ON, but camera responded with blue screen and "custer size wrong, please format" error message. G1W-C -- Do all have date reset issue? What's the fix?
Aug 26, 2014
G1W stops recording
Mar 6, 2014
More results from dashcamtalk.com
Memory error When we start the car the dash cam always ...
www.fixya.com > Forum > Cars & Trucks
45 mins ago - Memory error When we start the car the dash cam always comes up with a blue screen and "memory error". We can clear it but if we forget to do ...
iN-CAR CAM Series - Nextbase
Dec 14, 2015 | Cars & Trucks
Hp Laserjet 2300 showing error 53.10.03
  • 53.xy.zz
  • CHECK RAM/ROM MEMORY
  • Description
  • There is a problem with the printer random-access memory (RAM) or read-only memory (ROM). The DIMM that caused the error is not used. Values of x, y, and zz, are as follows:
  • x = DIMM type
  • 0 = ROM
  • 1 = RAM
  • y = Device location
  • 0 = Internal memory (ROM or RAM)
  • 1 to 3 = DIMM slot 1, 2, or 3
  • zz = Error number
  • 0 = Unsupported memory (for example, presence detect bad)
  • 2 = Unsupported memory size
  • 3 = Failed RAM test
  • 4 = Exceeded maximum RAM size
  • 5 = Exceeded maximum ROM size
  • 6 = Invalid DIMM speed
Jan 04, 2015 | Office Equipment & Supplies
Error 0184 memory size error
One of you RAM Dimms are no good. Try starting with only 1 Dimm and see which one is bad.
If you just added memory enter the BIOS, Go to Memory hit Save & Exit
Mar 26, 2014 | Computers & Internet
Error memory when loading calculus made easy on ti-89 titanium
You may get Memory Error when you try to access an archived variables. From the other hand Memory Error message is displayed if there is not enough free RAM to access the archived variables. For correcting Memory Error message use the 2ND then MEM to check RAM free size and 2ND then VAR-LINK to determine the size of the archived variables that you want to access. As the third step for correcting this problem deleting unnecessary variable from RAM and archiving large variables or programs. By the definition, the RAM free size must be larger than the archived variables
Feb 23, 2012 | Texas Instruments TI-89 Calculator
I have a problem when I put the memory in the camera tells me a few things and then jump error e00100
The memory may be too large for the camera. It may not be able to use a memory card of that size (storage size not physical size).
Mar 02, 2011 | Kodak EasyShare C330 Digital Camera
I have a fisher & paykel aqua smart WL26CW1. I just replaced the module. I am now getting an error code of 9. What does that mean?
Hi dear.That's related to size error.When you replace the motor control module you need to set the machine wash capacity like:5Kg or 7.5Kg.To do that please follow the steps: Phase 1 to 6 Size Switch Error
The Display size switch setting does not match that stored in the memory.IW machines, Phase 5 and 6
To access Size Setting Mode. Push and hold the Fabric care button and then press the Power button to enter Size Setting mode. Select the correct size on the display by pushing the White button next to the correct size (phase 5) or using the Adjust button to highlight the right size (phase 6). Size setting is then achieved by pressing the Power button. Powering off will set the size into the memory. Check the size is set before starting a cycle.
I hope that helps.Thanks.
Sep 03, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
Error 53.21 hp color 5550
Doesn't specifically mention the 53.21 error this is the closest they come so you will know it deals with the ram anyway
Control panel message Event
log error
message
Description Recommended action
53.XY.ZZ CHECK RAM
DIMM SLOT X
To continue press
CANCEL JOB
None An error occurred on some
memory of the printer.
X DIMM Type
1 RAM
Y Device Location
1 DIMM Slot 1
2 DIMM Slot 2
3 DIMM Slot 3
4 DIMM Slot 4
ZZ Error Number
0 unsupported memory
1 unrecognized memory
2 unsupported memory size
3 failed RAM test
4 exceeded maximum RAM size
5 invalid DIMM speed
Press CANCEL JOB. If the problem
persists, replace the DIMM card in
the slot indicated.
Click Here for Memory
hope this helps and if so please mark FixYa!!
Jul 30, 2010 | Office Equipment & Supplies
Hi Iwill be glad to assist you:
Description There is a problem with the printer memory. The dual inline memory module (DIMM) that caused the error will not be used. Values of X and Y are as follows: X = DIMM type 0 = read-only memory (ROM) 1 = random-access memory (RAM) Y = device location 0 = internal memory (ROM or RAM) 1 to 4 = DIMM slots 1, 2, 3, or 4 ZZ = error number 0 = unsupported memory 1 = unrecognized memory 2 = unsupported memory size 3 = failed RAM test 4 = exceeded maximum RAM size 6= invalid DIMM speed Action
  1. Press Cancel Job to continue.
  2. If the problem persists, turn the printer power off and then turn the printer power on.
  3. It might be necessary to replace the specified DIMM. Turn the printer power off, and then replace the DIMM that caused the error.
Nov 05, 2009 | HP Color LaserJet 3500 Printer
53.10 Error "Shut off printer and turn back on"
The error points to your memory see below. the .10 indicates internal ram. You may need a formatter bd.
53.XY.ZZ PRINTER ERROR To continue press cancel job Description There is a problem with the printer memory. The dual inline memory module (DIMM) that caused the error will not be used. Values of X and Y are as follows: X = DIMM type 0 = read-only memory (ROM) 1 = random-access memory (RAM) Y = device location 0 = internal memory (ROM or RAM) 1 to 4 = DIMM slots 1, 2, 3, or 4 ZZ = error number 0 = unsupported memory 1 = unrecognized memory 2 = unsupported memory size 3 = failed RAM test 4 = exceeded maximum RAM size 6= invalid DIMM speed Action
Jan 20, 2009 | HP LaserJet 4350dtn Printer
Can i install windows xp on compaq presario 7360 . because it says memory size error
memory size error means that the computer doesent have enough physical memory to run windows xp,
Jan 04, 2009 | Compaq Presario 7360 (163874-003) PC...
Dell Optiplex GX280 Intel Desktop PC  - Intel P4 3.0GHz, 512MB RAM, 40GB HDD, CDRW, 10/10  Logo
62 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
