Question about Daewoo KOR6N9RR Microwave Oven
How do i remove child lock
Just bought it new. All the buttons work and the lights come on but nothing else. Not sure what I have pressed. No manual with it.
I have a whirlpool microwave WM1107ADWC and I want to turn off the Child lock. How can I do it? I don't have kids and i want to save time when I use my microwave. Thanks
Child locks on microwaves act as a safety feature to prevent children from getting harmed or from causing other possible damage. The child safety lock does not lock access to the microwave; it simply prevents the microwave from being operated. To remove the child lock press the Stop button three times.
Lock the microwaveIf you wish to re-lock the microwave, perform a similar procedure. Instead of pressing the Stop button you need to press the Start button. Press the Start button three consecutive times to lock the microwave. This enables the child lock once again and prevents the microwave from being operated.
check this video also. Many Whirlpool microwaves are made by LG. between these two you should get it.
How do you remove the child lock on microwave
Jun 12, 2017 | Whirlpool Microwave Ovens
My child locked the microwave pad. How do I unlock it?
The operation manual is available for free download from Samsung at this site: http://downloadcenter.samsung.com/content/UM/200305/20030529145700437_MW5592.pdf
The answer to how to lock and unlock is on page 15 of the manual. It's instructions are: 1. Press the '0' button, the display will show: "PRESS 1- DEMO 2-CHILD LOCK"
2. Press the "2" button, the display will show: "PRESS START"
3. Press the start button and the display will show "LOCK" then returns to the time of day.
At this point the microwave can't be used. To unlock, just repeat steps 1-3.
Hope this helps
Jun 18, 2011 | Samsung MW5592W Microwave Oven
My mother mistakenly locked her samsung microwave. She can't figure out how to unlock it and she can't tell me what model it is. Can you help?
On a friend's Samsung (she didn't tell me her model number either), you lock the keypad by pressing "0" and then "2". Press the same sequence to unlock the pad. Maybe this will work on her model.
May 31, 2011 | Samsung MW7490 Microwave Oven
Screen says "locked" and nothing happens when you
The child lock has been enabled on the microwave. To disable the lock, press and hold 0 until the Locked message disappears from the screen. To set the Lock, press Stop/Clear (to clear the display) and then press and hold the 0 pad until the phrase Lock appears and you hear two beeps.
The manual for the microwave is available here: http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JMC8130DDS&siteCd=JA_EN_US&userType=Consumer . The direct link to the manual is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208112P218-60.pdf .
I hope this helps.
May 24, 2011 | Jenn-Air JMC8130DDS Microwave Oven
My microwave reads loc and nothing works
This is from the 1100ST manual:
CHILD SAFETY LOCK
The safety lock prevents unwanted oven operation such as by small children.
To set, press and hold STOP/CLEAR for 3 seconds, LOCK indicator lights.
To cancel, press and hold STOP/CLEAR for 3 seconds, LOCK indicator goes off.
Kelly
Mar 15, 2011 | Magic Chef Microwave Ovens
The cleaning lady cleaned the microwave inside and
It may be that the child lock has been operated accidentally, although if that were the case the POPCORN button should not work.
If the lock is on you should see an L in the display.
If the problem is the safely child lock you have to press and hold the
CLEAR/OFF button for about three seconds.
Apr 05, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do I unlock the child lock on my Panasonic Genius Microwave?
March 2009 press the function key,select option #5, select option#2. This should take it out of child lock. If this doesn't work enclose your model number and I will try to look up the manual
Or, press "Cancel" three times to clear the (child) lock.
You set the lock by pressing "Start" three times.
Apr 01, 2010 | Panasonic NN-T888S Convection/Microwave...
Child sign in window of microwave ,cant start it panasonic
On my NN-L738BA there is a Child Lock feature.
You set the child lock by pressing the Start button 3 times.
If the Child Lock is enabled it displays the word :CHILD".
To disable this feature on my microwave the manual says to
press the Stop/Reset 3 times.
Check your manual for the Child Lock.
Mar 06, 2009 | Panasonic NN-S541 Microwave Oven
Galanz Microwave Oven - Unable to disable child lock
Galanz's website seems to be useless. I tried finding information but kept being told "no data available." So while I can't tell you where to find the manual, here's something to try. Most microwaves get put into lock by pressing and holding one of the buttons for longer than normal, or by pressing one of the buttons several times in a row. Some ovens use the TIMER button. It won't be one of the number keys, but one of the function buttons. So start with a button, press and hold it for at least 5 seconds before you let go. If nothing happens then try another button. If that doesn't solve the problem, then try pressing each function key several times before moving on to the next one. If that still doesn't get it going, maybe a store in your area that sells Galanz will take a look at the book for you. The process should be the same for any similar model.
Nov 11, 2008 | Microwave Ovens
Panasonic microwave
the child lock feature is activated.
if you can look at your manual, it would be stated there how to activate and deactivate your child lock option.
tnx 4 using fixya
drcool
Sep 01, 2008 | Panasonic NN-S254BF Microwave Oven
Daewoo KOR6N9RR Microwave Oven Logo
46 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
