Question about Panasonic Televison & Video
Copying from Sky Plus to DVD with Panasonic DMR-EX773
How do I copy from the hard drive in Sky Plus to a DVD in my Panasonic DMR-EX773?
  • Peter Dixon May 06, 2012
    The same process should in theory work for the Sagecom DTR94320S Freesat recorder (said to be the free alternative to Sky) but I cannot get it to work. But then the Freesat box does not have the COPY facility that my former Sky box had
  • 409 Answers
Go to planner...highlight the program that you want to copy.
Press right on the navigation keys then the green button then select.
When you are ready press select to start followed by record on your recorder...
Posted on Feb 21, 2012
SOURCE: DMR E80H hard drive
DMR-E80H Hard drive problem seems to pretty common. My drive started making the famaous kerchunk noise tonight. After disassembly I see the drive is a ATA133 Maxtor drive....are you sure that you replaced it with the correct drive? I may contact Maxtor and try to get an RMA since the drive is only 3yrs old. Good Luck
Posted on Oct 17, 2006
rizla
  • 1463 Answers
SOURCE: copying vhs to dvd
you could google for macrovision scart leads that will do the job .
of transfering the vhs tapes to dvd .
riz.
Posted on Feb 12, 2008
KEV TECH
  • 3 Answers
SOURCE: Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Posted on Apr 11, 2008
SOURCE: unlock code to play any dvd and record to hard drive
You need a special remote, there are no codes. Have a google for "panasonic region free" and you'll see what I mean. I have the same model and had to take to a dealer to unlock for me. Panasonic are a bit unfriendly about unlocking dvds as I think they are part of the whole DVD organisation. there are ways to do it with a Palm device or something like it (even a pc with IR port) but it is tricky. You can also rent a suitable remote for about £20 I think, again google it and you'll find companies that offer that.
Hope that help, though I guess you may have sorted it by now as you posted about 6 months ago,
Stu.
Posted on Jun 03, 2008
SOURCE: How do I copy a programme I have recorded on the
On your machine or on the r/control you should have a copy button,if you press this you should get a menu come up on screen.It should ask you which way you want to copy,so you will go HDD-DVD-R,then press copy again and it should do it automatic,hope this helps.
Posted on Jul 11, 2009
How to besto connect this unit to record from Sky plus box
SCART from Sky box to SCART input on Pana. SCART out from Pana to TV to monitor results. The Pana SCARTs should be marked, one for external source such as Sky box, one for TV
Oct 26, 2013 | Panasonic DMR-E65 DVD Recorder
Can the panasonic dmr-eh75v copy a vhs tape to DVD?
Yes, that's mostly what I use mine for. You actually copy your VHS to the Hard Drive, then copy from your hard drive to your blank DVD. I'm about 1/3 of my way through reformatting my VHS library (800+ tapes.)
Nov 25, 2008 | Panasonic Diga DMR-EH75V DVD...
How to copy recorded files from hard disk of TV (LG 47LY3DE) to Combo DMR-EZ47V
From what I've read, you can't. There is no way to copy from the HDD to a DVD, and the HDD in the TV can't be read by windows. Same if you add an external HDD. Thats the only downside I can see to this TV
Jun 15, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
VHS record to DVD
Insert the VHS and rewind or fast forward to the point you want to begin copying from.
Insert the disc you plan to use and format it if necessary. It will usually prompt you if it is necessary to do so.
Put the television on the channel or input needed to view the recorder on-screen.
Select the DVD drive and set the record mode you prefer - XP, SP, LP or EP.
There are two things you can do:
1. Press and hold the dubbing/copying button on the recorder itself in the direction of the DVD for 3 seconds. If you are using a DVD-R/RW or +R you will receive a message stating to press Play to record without finalizing or press Record to record and finalize. If you are using +RW or -RAM, these cannot be finalized - therefore this message will not display.
2. You can access the Functions menu and go to Copy, then select the copy direction VHS to DCD and select Start Copying.
Apr 01, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Copying vhs to dvd
The write-protect tab on the cartridge is set to "PROTECT" or the disc is protected witht the "DVD Management" settings.
Some video tapes on the market(including rental videos) are copy-protected to prevent illegal reproductions. Copy-protected video tapes cannot be properly recorded.
You cannot use the copying function when the FUNCTIONS window, the Scheduled Recording List screen, etc. are displayed.
I hope this information can be of some help to you all. Ms Tanya 2/12/08 3:54AM CST.
Jan 30, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hard disk failure
It really depends on what is failing on the old drive...accordianman
Oct 24, 2007 | Panasonic DMR-HS2 DVD Recorder
Televison & Video Logo
241 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
