Question about Canon Office Equipment & Supplies
Error code on IR 7105 says E000578-8001 - Canon Office Equipment & Supplies
5 Suggested Answers
  • 11 Answers
SOURCE: canon iR 7105
The Tray A Area Sensor Unit may be faulty. Replace the Sensor
Posted on Oct 28, 2008
SOURCE: We have a Canon IR-7105
it is a transfer corona problem ,clean it first.even its not ok change the corona wires.
if its not ok finally change the transfer corona .
Posted on Jan 21, 2009
Cogz
  • 1326 Answers
SOURCE: i have this machine Canon IR 7105 B&W
Odds are is that the finishers exit bins got stuck while looking for it's HP. Most of the time it is a garbage can.... Move the object blocking the path of the exit trays first. Then turn the power switch for the finisher off first then turn the main power switch on the right side of the copier. Once it is all off > turn the finisher back ON first then the copier and then remove the paper jams.... Good Luck
Posted on Apr 25, 2010
Daniel S
  • 4323 Answers
SOURCE: error code for canon ir
Hi
This error is caused due to faulty thermister however; you can check the fuser unit for any jammed paper around the upper fixing roller and try to clean that area. After this is done try to clear the error by entering the service mode, to enter press Additional functions, #. Then go to #7 Printer and press OK, then go to #4 printer reset and press OK, yes= *. If the issue returns then replace the thermistor. Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 09, 2011
Hi, I want to know about Canon Image press 1110/1125/1135 these copiers use which type of toner. Can we put IR 5000 or IR 7105 toner in them How is the drum
no you can not, the toner in a image press is a dual component toner. in the 5000 and 7105 are a mono component toner please dont and if you did please tell the tech because it will drive him crazy trying to figure it out unless he is a veteran in the copier business.
Oct 17, 2015 | Canon Office Equipment & Supplies
Ir 7105 black copy is appear
I've had the Laser go bad on two occasions causing black or partial black copies
Feb 07, 2015 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
Error e805-0002
EXHAUST FAN FM 20 MAY BE EXHASTED
Apr 23, 2014 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
Canon ir 7086 error e012
DRUM MOTOR OR SOLID WAST IN DRUM UNIT (PROCESSING UNIT)....OR DISCONNECT AND CONNECT ALL DC CONTROLER JACS
Apr 15, 2014 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
Canon ir7105 error codes 000602
TRy this link. Reading similar errors, similar machine = hard drive error. can ir7200 602 001 Archive Copytechnet com
Apr 09, 2014 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
Error code e121
Reader controler cooling fan fault replace the fan or dc board
Jul 17, 2013 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
Canon IR 7095, error code E000005-010
Hello to all
I have a client server ir Pass has forgotten his password and I reset.
how reinitialiser server S2 canon ir Pass?
Thank you for the help.
Dec 27, 2012 | Canon Imagepass S2 Fiery For Ir...
I have this machine Canon IR 7105 B&W
Apr 24, 2010 | Office Equipment & Supplies
We have a Canon IR-7105 which keeps jamming , then codes out with code Error E000069-00000 (the tech was just in and did a PM)
Jan 21, 2009 | Canon imageRUNNER 7200 Copier
Canon iR 7105
Oct 27, 2008 | Canon imageRUNNER 7200 Copier
188 people viewed this question
old marine
old marine
