My laptop continually reboots and does not go to the home screen
  • 669 Answers
This is usually caused by a corruption in the boot sequence of windows. Your best bet is to do a full factory restore on the computer. This will wipe everything out and set it back to the way it was the first day you turned it on.
Hope this helps
Posted on Feb 21, 2012
Laptop wont reboot
suspected your mainboard is overheated, call the service center for replacement board if your laptop is still under warranty, or you need to send for the hardware repair
Nov 12, 2013 | Medion Computers & Internet
Tip
How to hard reboot your ipod touch if it is locked
So if anyone has ever forgotten their ipod touch's passcode or somehow gets locked out and can't get back in even if you restart it, you can try the one and only solution, the hard reboot. It works great, except you will lose all data on the ipod touch. There are two ways to complete this task successfully, first of all you can use the first way i learned, which is: hold both the top screen lock button and the home button for about 8-10 seconds, and the slide to power off thing should pop up, don't slide it though. When you reach this point you release the top screen lock button but continue to hold the home button until the ipod turns off, then it won't turn back on until you plug it in to a computer and then restore it using itunes. The second way is a little bit easier, you just have to hold down the screen lock button and the home button at the same time for 30 seconds and this will do the same thing as the first method. Thanks for reading, I hope this helps :D
Shorter Simplified Version: Hold down sleep and home button until you see the restarting apple logo, then release the sleep button and continue holding the home button until it shows the sign to plug into your computer then restore.
on Mar 23, 2010 | Audio Players & Recorders
Computer keeps trying to reboot continuously
overheating?
did you do any hardware upgrade befor this problem?
Nov 11, 2012 | Dell Inspiron™ E1505 PC Notebook
My iphone 3GS is stuck at the Apple screen. I've tried holding the off and home buttons to reset, but it's not working
This is not a good sign and one of the most common causes with this device. I could tell you a series of troubleshoot.If that would not work, device needs to be send for repair.
Have you tried a hard reset? Hold the Home and Sleep buttons together for 10-15 seconds, until you see the Apple logo come up on the screen. You may need to do this while the phone is plugged into it's charger or a computer, so that it has power.
Usually If it's stuck at that screen, and holding the buttons together for 10-15 seconds didn't help, then there's a hardware issue, and it will need to be replaced.
However, try few more steps
1. Connect to iTunes via USB. Do not disconnect for rest of these steps. iTunes may appear frozen or stuck with spinning beachball....this is okay, do not Force Quit iTunes. I tried a few times w/o it being connected to iTunes and it doesn't work.
2. Once connected, hold Home + Power until screen blinks then Apple logo comes back up.
3. Wait until Apple logo dims slightly (~5 minutes or less). Do NOT reboot until the apple logo dims.
4. Hold Home + Power again until it reboots and Apple logo comes back up.
5. After 2 min or so, the phone may vibrate once or twice. Continue waiting for the full 5 min until Apple logo dims slightly. iTunes at this stage MAY recognize the phone...do not sync or do anything in iTunes.
6. Hold Home + Power for the 3rd time until it reboots. Phone may vibrate again after 2 minutes or so. Eventually you'll break into your Home screen.
Or
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Disconnect you phone from your pc leaving the wire connected to your phone not your pc.
open itunes
hold sleep wake button + home button until your screen goes blank...
let go of sleep wake button and continue to hold home while plugging back into pc... should take about 15-30sec and itunes will see your phone in restore mode
IF THIS NOT WORKING
Try rebooting you phone by plugging it into the charger & turn wall socket on
If that also does not work then you need to take it the apple store.. They will replace it or service it.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 28, 2010 | Apple iPhone 3G
Opened my lap top HP dv9000 black screen sounded like it was running, I shut down then tried to reboot,starts to reboot then cuts off then tries to reboot and continues this cycle
Try starting the laptop in safe mode.
This is done by pressing F8 while the computer is starting. You will be presented with an option screen and should in the first instance choose safe mode. If the laptop boots you can then check the hardware for faults. If you are not getting past the initial bios boot screen it would be worthwhile downloading the latest bios firmware from the HP web site and installing this.
May 04, 2009 | HP Pavilion dv9000z Notebook
Toshiba Satellite 1115 S103 can't install Windows XP home edition
after it reboots it will ask you to boot from cd,
ignore this and let it boot from harddrive, where it has already copied the files to... it should setup ok from there
Apr 06, 2009 | Toshiba Satellite 1115-S103 Notebook
Stalled screen, openning 75 windows at a time, dead blue screen
Reboot and while its rebooting keep tapping on F8 to go to Safe Mode. Once in Safe Mode select "Last known good configuration" and press Enter. If that doesn't work continue to go to Safe Mode and do System Restore to an earlier date of before this happened
Jan 31, 2009 | Microsoft Windows XP Home Edition
Screen keeps minimizing.
Mine does it ,too.Extremely annoying! Just hit Control and 0 and it will go back to normal.
Dec 28, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
