Question about CORSAIR Computers & Internet
Schematic HX-520w are there any who have or know the link to schematic corsair HX 520W-? I am a technician has a HX-520W, could the flame but not strong enough to power a mainboard or CPU. 5V rails = 4, 8V 12V rails = 11, 7V help me please...
2 Suggested Answers
  • 10 Answers
SOURCE: 12v reads 7v --5v reads 3v. This to me is not
Use a paper clip and plug it in between the GREEN (PS-ON) wire and a BLACK wire. This should get your PSU running without the potential to harm your motherboard. I also like to plug in an LED between the GRAY (PWR OK) wire and a BLACK wire, but it is not necessary.
Now that you can have the PSU running by itself, you can test the voltage on each rail without a load affecting the reading.
I'm not sure of the quality of your PSU in particular, but the better ones have good regulation to compensate for voltage droop, while the cheaper ones have little or no regulation at all.
As stated in solution #1, the problem is most likely bad output filter capacitors. This is the most common problem I find in PSUs with low or no volts on some or all of the rails.
Of the dozens and dozens of switching PSUs I have repaired, I almost always encounter vented (blown) filter capacitors in the secondary (output) side. Along with vented filter caps, I sometimes come across shorted or burned resistors. Even less often I find shorted Schottky diodes.
It's common for components to fail as a chain reaction inside of switching power supplies. The most common causes are either poor quality components (as stated above) or too high of power demand AKA overcurrent (most ofen caused by rails being shorted to ground).
The moral of the story is: If you don't know how to repair power electronics, don't bother opening the case. You're better off buying a new power supply (assuming you're in the USA).
If you do know what you're doing, then be prepared to remove all capacitors that are blown or bulging. After a visual inspection of the components still on the board, check resistance between each rail and ground. If there is no longer continuity between the rails and ground, then replace the caps with new ones of the SAME VOLTAGE RATING AND CAPACITANCE. Make sure the replacement caps are rated 105C. Good luck!
Posted on Nov 29, 2009
How do I get my SHARP EL-520W ADVANCED D.A.L. to display my answer in radical form?
Unfortunately, you don't. The EL-520W can show fractions, but not radicals.
Apr 05, 2012 | Sharp Office Equipment & Supplies
I need a HP pavillion 520w motherboard. Where can I find one
Try E-Bay or just type the part number into google and look for prices.
Mar 01, 2012 | HP Computers & Internet
HP pavilion 520w
what do you want to know about pavilion 520 w
Jun 23, 2011 | HP Computers & Internet
Replaced a bad power supply and now won't pass POST.
Power supplies are one of the most common failures for computers but as you have found they are also very easy to replace and a nominal cost.
I probably average 4 power supplies a week on my bench and always do as you did and suggest to clients to get a higher rated supply.
Bob.
Jul 14, 2010 | Syntax SV266A SKA KT266A Motherboard
How do I input multi variate( x, y) statistical data into my sharp 520W calculator?
I have 3 questions in aquestionnaire wherein respondents answer yes or no. with these questions I would like to determine the correlation coefficient between training impact and employee performance
Dec 03, 2009 | Sharp Office Equipment & Supplies
Hp pavilion 520w
HP/Compaq uses system specific boards rather than industry standard. Not sure if anything other than a board from HP would work. Hope this helps.
Dec 21, 2008 | HP (D7580-60003) Motherboard
Msi p35 neo2
take off all the stuff from the mobo except the processor, a stick of ram and the graphics card - will it get further now?
Jul 02, 2008 | Intel Motherboard
Computers & Internet Logo
89 people viewed this question
Top CORSAIR Computers & Internet Experts
Ezewudo Onyekachi
Ezewudo Onyekachi
JonSnell Electronic
JonSnell Electronic
Alex Cries A Lot
Alex Cries A Lot
Level 1 Expert
Are you a CORSAIR Computer and Internet Expert? Answer questions, earn points and help others
