Question about Toshiba Computers & Internet
How do i change the keyboard on my toshiba satellite A665-S6086 laptop
Keyboard needs to be change how do i do that
  • Anonymous Mar 13, 2014
    toshiba a665 keyboard light
  • Toshiba Master
  • 5,660 Answers
1) Remove ALL power. Remove the AC adapter (Charger) and Battery.
2) Open the laptop display.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A665-A660/laptop-disassembly-1.htm
Follow Steps 5 through 11.
You can click on any photo to enlarge.
( A Picture is Worth a Thousand Words )
Steps 10 and 11 are on Page 2.
(Access to the pages is done through the Top, or Bottom of the page.
In white - Page1::Page2::Page3::Find another model.
Just click on Page2. You are on page 1)
Step 5:
When you click on the photo, and enlarge it, the 3 screws indicated in the text are circled in Red.
Step 6:
I suggest using a wooden cylindrical object, with one end cut off flat.
When you insert into the indicated hole in the Battery Compartment, (Battery removed), you are pushing against the bottom of the Keyboard.
The BACK of the Keyboard. The side nearest the LCD screen.
Don't use very much force. Either with the wooden object, or your fingers. Patience, and easing the Keyboard up, will go a long way.
NOTE*
The Front of the Keyboard, (The side nearest you), has plastic tabs.
These tabs fit down in the Top Cover. (Palm Rest Cover)
The Keyboard should ONLY, be raised at no more than a 45 degree angle, and slid Forward. (Until the tabs clear the Top Cover)
Otherwise you stand a chance of breaking tabs off.
The Keyboard Cable is still attached to the Keyboard.
(The Keyboard Cable detaches From the motherboard. NOT from the Keyboard)
The Keyboard Cable must be detached from the motherboard, before the Keyboard can be removed. I am also telling you, so you will Not yank up on the Keyboard, not knowing the cable is still attached.
Step 7:
You are lifting the Keyboard up at an angle, as I described above. From the step shown in the photo, you now slide the Keyboard forward a little.
Step 8:
Lay the Keyboard up on the back of the Top Cover, next to the bottom of the LCD screen.
(Display Assembly actually. The LCD screen is part of the Display Assembly. Using LCD screen moniker, is easier to identify )
[ Note*
Toshiba:
Display Assembly = Display Assembly (Toshiba)
Video Cable = LVDS Cable (Toshiba)
Display Bezel = LCD Bezel (Toshiba)
LCD Screen = LCD Panel (Toshiba) ]
This way you can freely access the Keyboard Cable connector, on the motherboard.
Step 9, Step 10, and Step 11:
The Keyboard Cable is a FFC. Flat Flex Cable.
http://en.wikipedia.org/wiki/Flat_Flex_Cable
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
Wires laid side by side, and covered in a type of plastic insulation, in a flat cable setup.
There is NO connector on a FFC.
The wires at the ends of the Flat Flex Cable, are exposed. Each is connected to a flat thin metal terminal strip.
The connector on the motherboard is a ZIF connector.
Zero Insertion Force.
It is a connector composed of two parts, and is rectangular shaped.
The thin part going across the top, is the Locking Bar.
The Locking Bar edge that meets against the bottom unmovable connector on the motherboard, is angle shaped at the bottom.
The bottom unmovable connector on the motherboard, is also angled shaped, where the two parts meet.
[ Step 9 click on the photo. The Brown rectangular shape that has two Yellow arrows on it, is the unmovable connector part on the motherboard.
The Yellow arrows point to the white Locking Bar ]
When the Lock is pushed into the bottom part of the connector, it wedges the FFC in place. Locks it in place.
When the Lock is moved away from the bottom part of the connector, the FFC is free, and not locked into position.
Looking again at the photo in Step 9, note the two white rectangular outlines, above the tabs of the white Locking Bar.
(Which are above the yellow arrows)
In the photo for Step 10, THIS, is how far the Locking Bar moves UP, (Towards the LCD screen), to unlock the Keyboard Cable.
The two parts (Locking Bar, and unmovable motherboard connector part), DO NOT come apart.
IF, they do, you have broken the motherboard connector for the Keyboard Cable.
This usually means motherboard replacement.
Use care, and gently use the nails of your two thumbs, to raise the Locking Bar up.
Barring this is not feasible for you, use a small flat tip Jewelers screwdriver, BUT USE CARE. EASE up a little on one side, then the other side. Keep going until the FFC of the Keyboard is free.
BEFORE you remove the Keyboard Cable from the motherboard connector, I suggest you make a mark with a fine line magic marker, on one side of the cable, and the same side on the motherboard connector.
This way you will align the Keyboard Cable, back up with the motherboard connector, in the proper alignment.
The Keyboard Cable MUST go back in the same direction it came out.
EVEN if the cable is twisted. (Twisted from the factory)
Apologize if I over-detailed this solution, and/or over-simplified it.
For additional questions post in a Comment.
Regards,
joecoolvette
[ Additionally:
Free Toshiba Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Scroll down to the 'paragraph' that starts with Satellite A10. (A10 in blue)
Drop down to the second line (A350D in blue), and scroll across to A660.
Left-click on A660.
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (A660) it may take up to 30 seconds, before the first page comes up.
(Took 10 seconds with a medium speed DSL connection ]
Posted on Feb 22, 2012
  • 21 Answers
SOURCE: Would it be at all
Dear Friend,
Under Toshiba's customisation program you can upgrade your graphic card to
NVIDIA® GeForce® GT 330M with NVIDIA Optimus Technology with 1GB GDDR3 memory
this would cost you about $130.
Please contact Toshiba Service Center for this
Posted on Dec 25, 2010
shibuda
  • 1812 Answers
SOURCE: how i can download windows
If you have purchased your laptop along with pree install windows ,please follow the beloow link.
http://www.pcrecoverydisks.com/toshiba/toshiba-system-restore-vista/
Choice your brand and OS .
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Posted on Jan 17, 2011
  • 125 Answers
SOURCE: my a665-s6086 toshiba laptop does
We ran a typical Toshiba Satellite A60 battery of tests, including games, applications, and a couple other areas. Time constraints limited the amount of testing we could get done before the NDA lift (and it's already a few hours late), but we will be providing a follow-up article with further testing and information. That said, if there are any specific areas that you'd like to see tested, feel free to e-mail me or leave a comment.
Posted on Jan 20, 2011
francois90
  • 36 Answers
SOURCE: i need driver software for
all toshiba satellite A665-s6086 drivers: --->click here<----
and watch the video
Posted on May 19, 2011
Toshiba satelite laptop won't poweer up, built in battery.
Built in battery? Why? Did someone glue it in place?
Those batteries are found on the bottom of the Laptop and are easy to replace. You can get them fairly cheap (like $40)
Here's and extended life 95w battery from Amazon
Amazon com Toshiba Satellite A665 S6086 Laptop Battery 95Wh 8800mAh...
Aug 08, 2016 | Toshiba Satellite A665-S6086 Laptop
Describe your 16" Satellite A665-S6086
This is the link to all the drivers for your laptop:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2759671&rpn=PSAW0U&modelFilter=A665-S6086&selCategory=2756709&selFamily=1073768663
(Copy and paste to browser) If you find that this is information was helpfulto you, please rate me and leave a comment as this will encourage me to do morefree work for you and others. And please let me know if there's anything else Icould help you with. Without any inputswe cannot proceed assisting... Thank you for using FIXYA! Best regards,
Junior
Sep 14, 2011 | Toshiba Satellite A665-S6086 Laptop
I need driver software for lab top toshiba satellite a665/s6086
and watch the video
May 19, 2011 | Toshiba Satellite A665-S6086 Laptop
Where is tab key on Satellite A665?
all tab key is above caps lock at left side at keyboard, usually it drawed as 2 arrow
i hope this helpful
thank you for using fixya
Feb 05, 2011 | Toshiba Satellite A665-S6086 Laptop
Would it be at all possible to put a new video card into my laptop? i have a toshiba satellite a665-s6086. Thanks in advance.
Dear Friend,
Dec 25, 2010 | Toshiba Satellite A665-S6086 Laptop
Computers & Internet Logo
148 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
