Question about Brother DCP-8060 Laser Printer
Self-dianostic brother dcp-8060
Só aparece self-diagnostic
Brother dcp-7055 self diagnostic
Go to the Maintenance Mode by pressing Pressing "Menu, *, 2, 8, 6, 4". If you done it correctly, the printer will beep, lights will flash and the control panel will read Maintenance.
After it Press 9,9 and it will reboot and start its normal reset procedure.
If it still not work, then there may be the problem with fuser or main board. Check both one-by-one. This may solve the problem.
Jan 25, 2015 | Brother Dcp-7055 Laser Print Copy Scan...
MY BROTHER PRINTER DCP-395 CN ERROR IN UNABLE TO INTI 4F PLEASE SOLUTION
This error is associated with the self test the printer does on the print head during power-up of the printer.
Sadly, it is indicative of either a faulty print head or a faulty main control board, neither of which are easy or inexpensive to replace.
Unless you can get hold of another machine with a different fault and swap over the print head and/or board (you'll need very good skills and tools to do this) then I'm afraid the machine is beyond economic repair*.
* Brother will repair your machine but the cost will likley be more than a new one.
Jul 09, 2014 | Brother DCP-330C All-In-One InkJet Printer
Self diagnostic autoatic wil with in10
Could be main board or power supply unit problem
Jun 26, 2013 | Brother DCP-7020 All-In-One Laser Printer
Como resetear dcp165
Instrucciones para reparar el error 46 DCP-165C
Desconectar el enchufe de CA
Conectar de nuevo el cable de CA mientras mantiene pulsado el bot?n "Men?"
y manten?rlo presionado (por 15 seg)
ahora est?n entrando en el modo de mantenimiento aparece en la pantalla LCD "error 46"
Seleccione 8 utilizando el boton de flecha hacia arriba, pulse OK
seleccione 0 y pulsar OK
00:00 00:01 OK (en la pantalla se muestra este mensaje)
Presionar la tecla azul (star black) 25 veces hasta que salga PURGA: xxxxx
Seleccione 2, ok.
Seleccione 7, ok.
Seleccione 8, ok.
Seleccione 3, ok.
El contador de la purga indica ahora: purga: 00000
apaga la impresora, (desconctar el cable CA)
listo para imprimir!!!
May 26, 2011 | Brother DCP 165C Compact Color Inkjet...
Im getting a unable to clean 46 on my brother dcp-350c printer
If you look at the Brother website you will find a trouble shooting guide for your machine.
In the guide, for the error you quote Brothers guidance is to check for a stuck piece paper, however it also states that if the printhead is hard over to one side (righthand side if memory serves me correct), then to contact Brother. If you do so, Brother will tell you it needs to be serviced by a Brother agent, which will likely cost you more than a new one !
If it isnt a stuck piece of paper, the problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Nov 03, 2010 | Brother DCP-350C InkJet Printer
Brother DCP-8060 Laser Printer Logo
477 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
