Question about Miele W864 Front Load Washer
Miele Novotronic W844 drum will not go round - Miele W864 Front Load Washer
5 Suggested Answers
  • 56 Answers
SOURCE: My Miele Novotronic W1918's drum is moving forward
sounds like your inner tub is broken. check your manual for the warranty. if there is no coverage left be prepaired for a hefty bill
Posted on Feb 07, 2010
Macmarkus
  • 2605 Answers
SOURCE: Miele Novotronic W828 Water Control System Front Load Washer
Hello Ellen, welcome to fixya. I would begin by removing the rear panel and checking the belt and insure the basket pulley isn't loose as well. If the belt is in tack ( not broke ) but has come off that sometimes is caused by a loose or bent pulley, hence the suggestion to check the pulley. If the belt is broke, it may simply be a matter of normal "wear & tear" and just time to replace it. Hope that helps point you in the right direction. Please take a moment and rate this info according to it's helpfulness or let me know if I can assist you further. Thanks for visiting "fixya" today and good luck. Macmarkus :)
Posted on Jun 03, 2010
  • 40 Answers
SOURCE: I have a Miele novotronic
The detente is not working on the push button. The push button switch needs to be replaced.
Posted on Feb 28, 2011
beltronic205
  • 1466 Answers
SOURCE: miele novotronic w864 The motor is
Providing the motor is okay then yes could be the belt...if so you will find that the drum turns by hand no problem with ease........In which case order new belt....
Posted on Mar 03, 2011
Novotronic w844 when washing large load sticks at rinse program and has to be restarted often several times
It sounds like your heater element is not working. If the washer doesn't reach the desired temperature it will not advance to the next level. Try to do a cold wash and see if it completes the cycle if it does you need to replace the heater element.
Feb 01, 2012 | Miele Washing Machines
Miele t224 tumble dryer is broken. the problem is how to access the drive motor and drum
http://www.maybenow.com/how-to-remove-the-front-panel-on-miele-dryer-q24016479
Mar 06, 2011 | Miele Novotronic T220 Electric Dryer
Miele novotronic w864 The motor is still working but the drum is not going round. Could it be the drum belt?
Mar 03, 2011 | Miele W864 Front Load Washer
The check drain light on my Miele Novotronic W844 washing machine is flashing; I have drained water out from the drain pump/filter section behind the panel at the front then refilled water in the detergent...
Hi dear.Related to your explenation: It does have faulty pump but first checked the pump harness.That's important.If every thing seems OK then you can replace the pump.I hope that helps.Thanks.
Feb 13, 2011 | Washing Machines
I need from manual guide on English for dryer Miele t565c
I have a t565c novotronic dryer,the light in the drum comes on but when i close the door and turn it on it want start .?
Dec 28, 2010 | Miele Novotronic T220 Electric Dryer
I owna W844 Miele washing machine. Shortly after I have pressed the start button, the "spoolen" light starts blinking and the washing procedure doesnt continue. Do you know which the problem may be?
Hi dear.If the machine starts the cycle but does not start agitate there are two things could be wrong.1- Good thing loose motor connection,2- Bad one is control board gone.To checked the loose connection,take out the detergent drawer.There are 3 secrews,unsecrew them.Bottom left hand side where the filter lid open it.free the drain hose.Out of the front doorjust under the filter lid,there is one little clip holds the door.free the door & cheked the motor connection.If it's loose,make sure firmly attach the connection housing.put the machine back in order & start the machine.If machine takes the water in & still not rotate the drum(If the rinse "spoolen" light flashing),you need to call miele service centre where you are to get it replace the control board.I hope that helps.Thanks.
Oct 13, 2010 | Miele Novotronic W1918A Front Load Washer
My Miele Novotronic W1918's drum is moving forward and scraping on the door glass. It is also making a clunking sound when washing.
Feb 07, 2010 | Miele Novotronic W1918A Front Load Washer
Miele W864 Front Load Washer Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
