Hello.
When you performed the Windows XP install, not all the drivers were available and installed.
To find and install the driver for the simple communications controller:
Go to Device Manager and click on the pci simple communications controller
Go to Properties and then Details. You will see a code like PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in the example the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to
www.pcidatabse.com. Enter the two codes
and you should get the name of your hardware.
From there, you can search for a driver download for
your hardware.
Hope this helps.
