Question about White Sewing 1418 Mechanical Sewing Machine
White Sewing machine, Model #1418 - put tension back together
Tension is messed up. Has been a continuous problem from the purchase of this machine. Lost my temper....took the tension apart and now I can't get it back together and make it work at all. I need a photo or better explantion of how the parts go back on the shaft. I am apparently not doing it correctly.
  • 35 Answers
SOURCE: white w750 sewing machine
I would suggest removing all of our thread and rethreading your machine. Put the thread tension at medium. Try a few stitches. If they are unacceptably loose or tight, try loosening or tightening the bobbin's tension. To do this, locate the tiny hole at the front of the bobbin area. This hole is on the outside of the machine. This hole lets you have direct access to the bobbin's tension screw, so find a tiny screwdriver and turn the screw inside the hole a little to the right for tighter tension, or to the left for looser tension. Let me know how it works - I love this sewing machine!
Posted on Aug 16, 2008
  • 5603 Answers
SOURCE: when im sewing the thread in my bobbin comes out
Check you have the bobbin in the CORRECT direction. If upside down it will come out.
Posted on Aug 14, 2009
  • 980 Answers
SOURCE: white 1418 sewing machine
If you have taken the hook out that is the half moon shape first of all make sure the needle is at the top of the machine, hook in, gate up and that is all there is to it.
Posted on Apr 10, 2010
  • 1788 Answers
SOURCE: I need help -
Go to and download a free manual for your machine. Just go under support and manuals, enter 1521 and you will see your manual to download. Nice to have an extra copy anyway, plus you can enlarge the diagrams for seeing better. Good luck
Posted on Sep 17, 2010
  • 340 Answers
SOURCE: I lost my manual and dont know how to tread sewing
There is one available on the Singer site, it's free to download.
Just type in 2037 and click on search.
On the next page click on free download!
The Model number is W2037 as the W stands for White.
Hope this helps!
Posted on Sep 28, 2010
How do I replace the upper tension spring on White sewing machine model 1418?
Go on and you will see a video on replacing White tension springs. The videos are free and very good for lots of things..
Dec 31, 2017 | White Sewing Sewing Machines
How do I thread a white sewing machine model 1777 need step by step
You probably already have some documentation, but if not, here are some:
White sewing Machine model 1418 (not your model, but most machines thread very much the same)
When threading the machine, ALWAYS RAISE the presser foot during the threading process. This releases the tension disk so the thread will seat properly.
White 1735 Sewing Machine Instructional Video
Jun 05, 2016 | White Sewing Sewing Machines
Deagram of tension assembly for white sewing machine 1418
This is why you take the machine to a trained professional.
The only thing DIY about a sewing machine is what you can sew with it.
Jul 15, 2014 | White Sewing Sewing Machines
Tension settings
Some general suggestion - not familiar with White. If you know where the tensioner is, take a scrap of relatively stiff cloth in a constrasting color to the thread to make it easier to see. A good stitch tension will look like a line of adjacent dashed on top and dash-dot-dash on the bottom. If you are seeing dash-dot-dash on top and Dash-dash on the bottom, the tension is too tight. If - usual case - the bottom has dash-loopyloop-dash, or worse, snags, the tension is too loose. Remember tension may need to be adjusted for thicker or thinner work.
Jan 20, 2014 | White Sewing 1418 Mechanical Sewing...
Does the bobbin on a white 1418 thread clockwise or counter-clockwise?
You can download a manual from here, just type in the model number and click on 'search' to locate your machine's one.
As a rule of thumb, the thread usually comes off a bobbin goes through the tension then reverses direction back the other way. So as you pull the thread, the bobbin usually turns anticlockwise. But always check the manual to be sure.
May 22, 2011 | White Sewing 1418 Mechanical Sewing...
Breaks thread after sewing about 8 feet. Thread is freyed away
try changing your tension (loosen) should be between 4-6 don't ever mess with the bobbin tension only the top, if that doesn't work change the needle, or re-threading.
Dec 18, 2010 | White Sewing 1418 Mechanical Sewing...
W1409 model, I need a diagram on how to put the tension knob parts back on
You can google, tias, relics and they have a service manual for White & dometic generic and it would help you. It costs $21. but maybe a better way would be to go to and buy the part for $19. with the directions, and they will be able to tell you how to do it. It must have had a problem to begin with, so it may not work if you get it back on. Good luck, but I think I would opt for the new part, if it were me.
Sep 12, 2010 | White Sewing 1418 Mechanical Sewing...
More questions about tension
Tension on my White sewing machine, Model #1418 is messed up. Lost my temper and took it apart and now I can't get it back together properly. Every combination I try does not work. Need a photo or a better explanation of how it goes back together. Tension has been a continuing problem from the day I purchased this machine. Very frustrating! Thanks
Sep 03, 2008 | White Sewing 1418 Mechanical Sewing...
White Sewing 1418 Mechanical Sewing Machine Logo
63 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
