Question about Dishwashers
Hotpoint dwf60 dishwasher error lights button 4 and 5
Button lights 4 and 5 keep flashin when machine is turned on, even though there is definatly a water supply
    Sergeant:
  • 316 Answers
4 Suggested Answers
  • 1214 Answers
SOURCE: hotwater runs continuously
It sounds like a little piece of trash (precipitated solids in the water line) have gotten in the water valve, or, the fill switch has failed.
If you know how to use a voltmeter, then see if there is voltage always applied to the water solenoid. If not, the water solenoid valve is bad. If it does have voltage all the time (when it's not supposed to be filling) then it's the fill switch.
Posted on Feb 01, 2009
  • 251 Answers
SOURCE: water runs into dishwasher as soon as water supply
Then replace the inlet valves for these are faulty...
A nice day to you......
Posted on Jun 22, 2011
Testimonial: "thanks"
  • 195 Answers
SOURCE: lights flashing hotpoint fdw20 dishwasher
Heater elemnt is gone cheep fix , you will need to order this lower element
Posted on Nov 30, 2011
Hi we have a Hotpoint Aquarius FDAL28 dishwasher. Machine turns on, drains and fills but then 3 lights keep flashing and washer stops programme. Any ideas what problem could be?
Depending on which lights are flashing, there is either a problem with the electronic control module, or the pump is stuck or has a motor failure. You can see which by comparing which lights are flashing with the pattern on this page of error codes:
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3293-hotpoint-fdl-series-dishwasher-fault-codes
Jul 15, 2017 | Hotpoint Washing Machines
My dishwasher is just flashing F10 all the time
Codes are pretty generic between Hotpoint, Hoover and Whirlpool.
Heating element fault
Issue: The LED lights on your dishwasher are displaying in the following sequence (please see below these error codes for your LED reference
  • LED 1: OFF
  • LED 2: ON
  • LED 3: OFF
  • LED 4: ON
Action: We recommend you call our customer service centre to book an engineer.
Here is the Hoover site.
http://service.hoover.co.uk/advice-centre/dishwashers/
Error codes Hotpoint
Jun 19, 2016 | Hoover 24 in. HD97E Free-standing...
Hi i just bought Electrolux Dishwasher ESF2433W When i first time turn it on, the "Normal" button light keep on flashing with beeping sound. According to the trouble shooting manual, it actually refer to...
If you just bought Dishwasher ESF2433W I suggest you contact an authorized service center because the appliance is under warranty..
E4 : if overflow micro-switch is act and keep for longer than 2 seconds, the E4 would occur. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown.
Sometimes defects are generated by incorrect transportation appliances so that should be taken into consideration.
Dado
Feb 20, 2015 | Electrolux Dishwashers
Dishwasher Problem
Send it to the agents, bud. It\'s probably an anode or faulty resister on the PC board.
May 27, 2013 | Dishwashers
Lights flashing hotpoint fdw20 dishwasher
Nov 26, 2011 | Hotpoint 24 in. FDW60 Free-standing...
FDW 60 lights 4 and 5 flashin.Select programme,m/c then bleeps 4 times and then lights 4 and 5 flas together and nothing else happens!Any ideas please?
Control panel which is a bit sensitive might need re-booting. Mine did the same and had a mind of its own, doing what it wanted, lights flashing all over the place, not completing the wash etc etc.
Switch off the machine and unplug from the mains. Leave for 10 minutes.
Plug back in, switch the machine on to your required programme and if ,like me, you are lucky, your machine should work again. If it happens again in the future you know what to do. Failing that go to the Hotpoint website, find the customer service number and ask if there is anything else you can do yourself to solve the problem, before paying for a service call. They are really helpful
May 27, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fwd60 eco and intensive lights flashing
Hi, I have a Hotpiont FWD60, the "delicate" lamp has started flashing about twice a second. Any ideas? Thanks, Nick
Mar 04, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Dishwasher not working - FDW60
unplug it for an hour this normally fixes this problem on my machine
Jul 28, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
Dec 12, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
82 people viewed this question
Top Dishwashers Experts
