Question about HP Hewlett Packard LaserJet P3005n Printer
Hp laserjet p3005n 55.04.92 dc controller error
    New Friend:
I need help,my printer are hp lj 3035,the error is 55.04.92-DC CONTROLLER ERROR,how to fix this erroer?
Posted on Nov 27, 2015
SOURCE: HP laserjet 5550 not printing cycan. Replaced
You will not find the answer to this problem on any forum as I have searched each one! However I have had the same problem and found out that if you have reseantly replaced or reseated the Paper Pic-up assy you may have not pushed down the plastic top cover which sits directly underneath the Cyan Cartridge, this will cause your 5550/5500 to think there is no problem and carry on printing without any error messages.
I'm just a man doing a boys job, lol
Posted on Feb 23, 2010
Testimonial: "Wow! Thank you sir. That was the problem. I had not touched the paper input assembly. So obviously, a user did this. Thanks again!"
  • 8 Answers
SOURCE: mem check failure replace dimm
Hi<br /> <br /> The formatter board in the printer is faulty. The heat from the chips softens the soldier and makes the joints bad causing all types of misleading errors.<br /> To solve the problem you can try two differant methords, both will endevour to melt the soldier joints back to good.<br /> <br /> Slide the right hand cover to the back of the printer and remove.<br /> <br /> Open metal door to see formatter board<br /> <br /> Disconnect the three wires from the top left of board, they only go in one way so you do not need to mark them.<br /> <br /> Undo the screws around the board and pull the board free.<br /> <br /> Using a hot air paint stripper heat up the reverse side of the board applying plenty of heat to the soldier joints<br /> <br /> Reasemble<br /> <br /> Do a cold restart and away it should go.<br /> <br /> Alternative to the hot air gun you can but the board in the oven.<br /> Trust me on this one it will survive.<br /> <br /> Support the board at the edges on small blocks of wood to stop it from touching the pan<br /> <br /> Pre heat the oven to 180 degrees<br /> (soldier melts around 165)<br /> <br /> Put the board in for eight minutes and then remove, let cool befour touching.<br /> <br /> Reasemble<br /> <br /> Do a cold restart and the printer should work.<br /> <br /> Chris<!-- from fixya rte -->
Posted on Aug 12, 2010
Midwest-Tek
  • 864 Answers
SOURCE: my hp laserjet p3005n is giving me a message
Check the sensor flag where the paper exits the printer, make sure it is not stuck in the "up" position. There is a small black plastic flap right in the center of where the paper exits. When this flap is up it tells the printer that this area is full. HP instructions are to "flip" the sensor flag up and down to make sure it is not stuck. Please be careful when doing this as it is a delicate piece.
If you need further assistance i will be here to answer your questions thanks and have a great day.
Posted on Aug 17, 2010
SOURCE: Using hp laserjet p3005n, when I print one page it sends blank pg
Annoying but easy to solve.
Go to the printer's ip address management page from a web browser. Look under the TCP/IP address settings. Click on the advanced selection. Disable the LPD Banner page. That should fix it, if it's not under advanced poke around until you find LPD Banner Page. ;)
Posted on Oct 08, 2010
puertobori
  • 7733 Answers
SOURCE: how to ip configure
If you had the printer installation CD start the installation again and you will be prompt during the installation if you want wireless/or usb connection.If you don't had the CD you need to download a driver at LINK.
Posted on Nov 04, 2010
Error Code: E197 0000 in cannon 2900 printer
Printer engine communication error
Erroneous communication between the DC controller PCB and image processor PCB was detected.
- Check the connectors of the DC controller PCB and image processor PCB.
Replace the DC controller PCB for normal connection. - Replace the image processor PCB.
E197 0000 Laser Driver PCB communication error
Description :
Description Error in communication with the Laser Driver PCB (communication data failure)
Causes :
Solutions :
Remedy
1. Check the Laser Scanner Unit connector.
2. Replace the Laser Scanner Unit.
3. Replace the DC Controller PCB (PCB1).
Nov 16, 2017 | Cannon Office Equipment & Supplies
A system error E197 has displayed on my canon iR1018 copier. how will i solve the error problem?
the error is E197-000 Printer engine communication error
processor PCB.
- Replace the DC controller PCB for normal connection.
The part number for the DC controller PCB is FM2-8365-000.
Best regards,
Marius
Jul 29, 2016 | Canon CART303 Laser Toner - Genuine, Suits...
55.00.00 DC Controller error
Replace the DC Controller first, next the Formatter.
The 55.xxxx is a communications error between the DC Controller and the formatter.
Apr 03, 2014 | HP LaserJet M9050 MFP Printer
E733-0001 Error Code 8104007505 mo
Communication error between DC Controller and Main Controller.
Poor connectivity between the DC Controller and Main Controller or the DC Controller if faulty
Oct 22, 2013 | Canon imageRUNNER 3300 All-In-One Laser...
Hp 3600 54.17 error
54.XX ERROR An error has occurred with one of the tonerlevel
sensors.
XX Description:
15 Yellow
16 Magenta
17 Cyan
18 Black
1. Make sure that connector J1020 on
the DC controller is seated correctly.
2. Replace the DC controller.
Dec 12, 2012 | HP Office Equipment & Supplies
Sir, i have hp laserjet colour printer CP5225, having error 55.0601. Kindly give me online solution
this all i manage to find for hope it helps
55.x Error
Error Message
55.X Error
Turn off then on
Description
The printer has experienced an internal error. The printer may experience one of the following errors:
55.0 DC controller communication error
55.0601 DC controller NVRAM data error
55.0602 DC controller NVRAM access error
55.1 DC controller memory error
Action
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the printer to initialize.
If a surge protector is used, remove it. Plug the printer directly into the wall socket. Use the power switch to turn on the printer.
If the message persists, contact HP support.
You need to first check the connection between the dc controller and the formatter and if the connection is fine you need to replace the dc controller.
Dec 22, 2010 | Office Equipment & Supplies
Please help e0020-00ff black toner supply????? comes and goes
Check for blockage in toner supply ,located at rear of hopper. Also is the toner ok
Jun 26, 2010 | Canon imageRUNNER C6800 Copier
Error code e000733-0001
E733
0001 A fault is detected by the main controller PCB in the communication between
the DC controller PCB and the main controller PCB.
Main cause The connector has poor connection. The DC controller PCB is faulty.
Action
1. Connector, DC controller PCB
Is the connection between the connector J1015 on the main controller PCB
and the conductor J316 on the DC controlled PCB normal?
NO: Correct the connection.
YES: Replace the DC controller
Jan 23, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Error code 59.c0 in HPLaserjet 5550
This means a printer motor error has occured. From the service manual: C developing disengaging motor rotation error.
To fix:
Developing disengaging motor
error
1 Reconnect the connectors J16 for the developing disengaging motor and J1100 for the DC controller PCB.
2 Replace the developing disengaging drive assembly.
3 Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
So, at the very least you'll need the developing disengaging drive assembly and, if that doesn't fix it, then you'll need the DC controller board. My bet is the DC controller has failed.
Sorry for the bad news, but please rate this solution as fixya even if it wasn't what you wanted to hear. Thanks.
Jan 10, 2009 | Office Equipment & Supplies
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
HP Hewlett Packard LaserJet P3005n Printer Logo
3,527 people viewed this question
Ben Johnson
