The convergence on our samsung projection tv # p55a(n) is off. We are unable to move the red convergence line left or right, but it does move up or down. Any suggestions?
    New Friend:
Hi.. i need help with my samsung projection tv model # SP - 54J8HF .. The man who came to fix said that u need to replace the convergance card (STK) .. i live in Pakistan .. and here it is no where to be found .. the television is very dear to my mother who is not ready to sell it .. i searched ebay and as well as google .. kindly help me or give me an exact link where i could find the thing .. thanks in advance
Posted on May 22, 2016
ctf1800
  • 4402 Answers
SOURCE: Projection TV Convergence
they have inherent problems with the glycol oil used to cool the tube leaking past the bladders & onto the boards.... & it's conductive :p
Posted on Dec 11, 2007
SOURCE: red convergence wont move
Bill may you help me?
I have a Mitsubishi 45" Projection TV VS-4543.
The problem I am seeing is that there is a red gosting/double image. I found out that the coil L8W01 was burnt out and the trace pad that leads to pin1 of connector VR was also burnt on the MAIN PCB board. I had replace the coil and retrace the trace pad, also I had replace a new red convergence IC STK391-020. The problem still occure. I try to adjust the color alignment and the convergence alignment using the remote controle. The red line is not thin and sharp like the blue and green line. It is blurry and wide. Also the the red wasn't able to move in to the center of the alignment pattern when trying to adjust 5 different position during the convergence adjustment. What else can cause that problem? Please Help. d57a38e.jpg
Thanks
Acqra
Posted on Jan 20, 2008
Slinteriors
  • 8617 Answers
SOURCE: Philips 60PP9202/17F.....The convergence is out
You need to replace the convergence ICs they are located on the large aluminum heat sink on the circuit board on the left. Either STK392-110 or STK392-120 are used in that chassis. And you can order them at this link and they provide free step by step instructions with pictures so you can do the repair yourself in about an hour. Heres the link. Just look for your stk numbers under the convergence IC section you will need to replace both of The ICs. If you need to know what they look like heres a pic.
http://servicemanuals.vstore.ca/a2d36f4.jpg
Posted on Mar 30, 2008
  • 20 Answers
SOURCE: convergence problem with samsung sp42w5hfx
I have same prob too is this a common fault ? Changed both convergence chips STK392-040 - Now only green and red will move - Blue will move up and down but not left and right also one of the STK's is getting very hot any ideas ??? shaundolphin@yahoo.co.uk
Posted on Jun 03, 2008
  • 2920 Answers
SOURCE: samsung rear projicton tv 42 inch aa68-50523a
youll need to have the tv converged...the red being out of line says that
Posted on Nov 05, 2008
Blue green and red not in line. how to solve
Thats a convergence issue which is caused by the convergence amp board needing repair. The samsungs with the P55A chassis such as your model usually require replacing the convergence amp board which is a simple unplug old board and plug in the new one repair. You can get the convergence amp board for your model from www.tvcircuitboards.com
Jul 12, 2011 | Samsung HCN4727W 47" Rear Projection...
There is a line right in the middle of the tv going vertically.. the left side is fine but the right side is like 3d tv.. why is that.. Model # WD-62628--- S# 117086... Mitsubishi
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 24, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Conversion-----the red lines are distorted so badly they won't move at all. I've managed to line the other lines up. The top left quadrant has drooped so badly that they will not adjust back. The bottom...
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Feb 11, 2010 | JVC AV-56WP74 56" Rear Projection...
Colors do not line up on my tv ( left side of sreen looks like 3D) digital array "+" are only white on right side.
  • Screen looks 3D
Jan 11, 2010 | Hitachi 50FX20B 50" Rear Projection...
Ther is a red line on the left side of the tv the blue an green is alright but it looks like it is in 3D i have tried to line the conrv- but still nothing the red is shifted 2 inchs to the right
  • Screen looks 3D
Jan 04, 2010 | Mitsubishi WS-48515 48" Rear Projection...
Convergence
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Oct 09, 2008 | Mitsubishi VS-50803 50" Rear Projection...
Red bow on top and bottom of 61dx01b
  • Screen looks 3D
May 21, 2008 | Samsung PCL5415RB 54" Rear Projection...
Fine tuning grid on my Samsung HDTV with remote.(BP59-00048)
To adjust manual convergence on your projection TV, follow theses steps:
  1. Turn your TV on.
  2. Let it warm up for 30 minutes.
  3. Press the Menu button on your remote. The Main menu appears.
  4. Use your remote to select Function, and then press the joystick.
  5. Select Convergence, and then press the joystick. The Manual Convergence screen appears.
  6. Select Red, and then press the joystick. A series of crosshairs appears on the screen.
  7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have. Note: You must do the outside crosshairs first.
  1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair. Note: Make the single horizontal line as white as possible.
  1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair. Note: Make the single vertical line as white as possible.
  1. Repeat for all outside crosshairs, and then for the inside crosshair.
  2. Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
  3. Repeat Steps 7 through 10 for Blue.
  4. Press the Menu button on your remote to exit.
Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
Jan 05, 2008 | Samsung BP59-00016A Remote Control
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
