Question about Maytag PYE2300AY Electric Dryer
Maytag dryer: pye2300ayw
Dryer is 7 years old. The drum turns and it runs but does not heat at all. The Thermal fuse must be okay (it was replaced 1 year ago), or it would not run at all. I have had the Thermostat checked, and it is okay. Is there a third thermostat? I have thoroughly cleaned all the places where lint builds up- all ducts and the dryer front door components.
What is the problem likely to be? Can the heating element go bad without tripping the thermal fuse? In other words, will the dryer run with a bad heating element?
Thanks,
gregg
  • Anonymous Apr 12, 2009
    dryer will not blow hot air
I had the same problem last month. My heater element broke in two places. This created an electrical open that prevented the heater from functioning. I replaced the heater element and my problem was solved.
In order to check your heater element: With the machine unplugged, disconnect one wire to the heater element and then use an ohm meter or multimeter across the heater element lugs to read resistance. Infinite ohms = open circuit.
Posted on Nov 04, 2008
  • 67 Answers
Yes, it will. you should be able to take off the panel on the bottom of the front of the dryer. way in the back is the heating element. do not put your hands in there with the power on, but start the dryer and look in there and you will see if the heating element comes on. it will be like looking inside your toaster.
Posted on Oct 28, 2008
I replaced my thermal fuse on my pye2300ayw dryer now it gets to HOT
Whenever you change the thermal fuse the thermostat should also be changed...
check out this electric no heat tip...
heatman101
Dec 23, 2010 | Maytag PYE2300AY Electric Dryer
The dryer runs about 10 seconds then shut off. It
Maytag gas dryer , runs for about 15 sec. heats up , then completly shuts off , Checked thermal fuse & it was blown , replaced & it ran for about 15 sec again & blew fuse again ....help .
Apr 26, 2010 | Maytag PYE3300 Dryer
Location of Thermal Fuse
The thermal fuse is located near the heating element. The part number for the replacement kit is LA-1053. You can view an illustrated parts break down of your dryer at searspartsdirect.com. Just type in your model number and locate item 5 under the "Heater" section. Pay close attention to the instructions in the thermal fuse replacment kit. One thermostat is for a GAS dryer, one is for an ELECTRIC dryer. Read the instructions and make sure you use the correct one. If you have any questions, please let me know. I hope this helps you.
Jan 06, 2010 | Maytag PYE2300AY Electric Dryer
Dryer won't run
thermal fused are one time fuses / maytag want's you to correct the problem that causes this . so dryer is safe. hi heat caused it to fail . so either the fan is not going or there is a restriction causing no air flow . try running the dryer off the vent if it works ok then clean the vent ,, hope this helped . pls leav feed back mm
Dec 14, 2009 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AYW Dryer wont start or run. I replaced both thermal switches still nothing. What next?
Check the dryer breaker pair in the house electrical panel. Push off, then on. Try the dryer again. If works, ok. If not, recheck the breakers. If tripped again, the dryer has an internal short circuit--likely in the heating element(s). The drum must be removed to service the element(s).
Aug 28, 2009 | Dryers
Maytag Dryer quit working mid cycle
sounds like the timer,the only thermal fuse i know of is to protect from overheating which cools and resets itself
May 10, 2009 | Maytag PYE2300AY Electric Dryer
Pye2300ayw Dryer will not start. I think it is a bad door switch. How can a confirm this?
Change your thermal fuse first. when thermal fuse goes bad either the whole dryer won't run or the heat element won't come on. Check out item # 3344 at www.repairclinic.com/Appliance-Parts?s=t-pye2300ayw-%3d%3d&z=100 If your thermal fuse is bad there will be no continuity through it.
Mar 01, 2009 | Maytag PYE2300AY Electric Dryer
MAYTAG PYE2300AYW ELECTRIC DRYER running but no heating
you need to take it apart if you'd like call 417-926-0106 i'll walk you through it Jim
Feb 27, 2009 | Maytag PYE2300AY Electric Dryer
Where in Thermal fuse located maytag model #PYE2300AYW
Take the top off the dryer and you should find it located at or near the drum.
Jan 17, 2009 | Maytag PYE2300AY Electric Dryer
MAYTAG PYE2300AYW ELECTRIC DRYER not heating
Check the terminal block and make sure you're getting 220. If you only get 110, the dryer will run but without heat.
Apr 03, 2008 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
386 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
