Samsung printer/copier toner doesn't bond very well to paper. Toner is on the edges of the paper too.
    Master:
  • 788 Answers
It would seem that your fuser is faulty in the printer. Odd that the printer is not reporting a low temperature error maybe the Samsungs don't check the temperature.
Depending on the value of the printer it may not be a good idea to replace the fuser, it might be hard to find a replacement. If this printer is worth less than $200 new, I would say replace the printer, the fuser would likely cost more.
Posted on Oct 27, 2008
Color is faded and not very bright and gets darker toward the edges
MODEL PICTURED IS REAR PROJECTION WITH PICTURE TUBES.
IF IT HAS NOT BEEN "SERVICED" FOR SOME TIME TRY THIS:
WITH SET UNPLUGGED REMOVE BACK COVER---LOOK UP AND LOCATE THE THREE LARGE ROUND BLACK LENS--they can be cleaned with either a lens cloth or a paper towel with glass cleaner sprayed on it.
They are the light source for your picture and if even moderately dusty will make picture duller and darker than it once was.
Cleaning, depending on how dusty a environment you have the set in, should be done once a year.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
If you have any questions post a comment right here and I will assist you.
SD TECH
Aug 21, 2010 | Samsung HC-R4755W 47" HDTV
I have a buzzing noise from inside the TV
immediately check your plyback connectors and wirings.there is a leak in your high voltage and this is dangerous so be carefull..to locate the leak,open the back cover of your tv enough to see the inside components...specially the plyback transformer..power on the tv and look for the arking of the high voltage.it is like a lightning strong light that produces the buzzing sound..once you see the source of the leak..power of the the tv.use a silicon adhesives (silicon gel) a silicon that is use by the glass intallers to bond the mirrors use on the display show room..apply the silicon on the leak area .apply a large amount of it to be sure there is no leak...once it is bonded you can power the tv right away...to check whether the leak is cured...
good luck hope this helps you..
please rate my help tnx.
May 29, 2010 | Samsung HCL4715W 47" Rear Projection...
Picture is off center. Bottom edge is about
sounds like VERTICLE problems...check verticle circuit for bad Capacitor...bad cap might be visible...you must locate verticle ckt inside of TV and change BAD cap!!!
May 19, 2010 | Samsung HLN4365W 43" Rear Projection...
Samsung hcn5529W hmdi input dispaly issue
then try using RY able instead of HDMI input to test if its a cable problem
Mar 29, 2008 | Samsung HCN5529W 55" Rear Projection...
Dlp picture has vertical shadow on the left edge
I bet you have a Samsung set. If you do then you have a bad Light Tunnel and you will need a trained samsung tech to replace it. Samsung knows about this defect and in most cases they will repair at their cost. Call 1-800*Samsung. Even if it is not a Samsung you still have the same problem. Call the manufacture of the set.
Jul 11, 2009 | Televison & Video
Lex. x 5495 won't print from pc.It worked up to a short time ago.Will print from laptop.Driver,cables. connections are good, occosionally will print a remaining document from previous attempts first thing...
check all this possible problems and solutions:
-Check the printer status lights, or the status LCD screen. If there's a flashing light, or if the status screen shows an error, then it's your first clue to a problem. Most printer manuals have a diagnosis process for alerts.
common problems are related to toner or toner cartridges. If the problem is toner-related, check to see if the toner cartridge is empty or low. The printer warning should indicate this. Swap it for a new one and the unit should work.
check to be sure that it is connected to your computer. Personal printers connect via either a parallel or USB (universal serial bus) connector to the back of the printer. Follow the cable from the back of the printer to the back of the computer to make sure the connection is good.
When a printer acts up and there is no hardware problem, the solution is often driver-related. A printer driver is a piece of software that allows a computer to "talk" to a printer. It's a kind of translator. Occasionally, if a printer has worked previously, but suddenly doesn’t work with a newly installed program, there could be driver problems. To remedy this, download a driver from the printer maker's website, remove the old driver, and install the new driver. Drivers are normally available under the "support" area of a website.
Sep 16, 2008 | Televison & Video
I have a Samsung CRT slimfit that I bought in 2006. It has worked splendidly until about 4 months ago and suddenly I have started to notice the edges of the screen about 2-3 inches on both sides have...
In my experience from doing Samsung's warranty work on slimfit sets, they have issues with picture tubes causing problems on the circuit boards. Many times I would replace a board only to have it fail a short time later. The wide crt draws a large amount of current and many have purity (discoloration around edges) problems. I would suggest you try contacting samsung to see if any recall exhists on these and if that doesn't work I wish you luck having it repaired properly for under 275.00
May 21, 2008 | Samsung Televison & Video
Cannot get a samsung remote to control my samsung tv.
Hi i will give you a parts dealer phone number that only deals with samsung parts give them the model number when you order. you might have to use a credit card.. If they dont have it maybe universal. good luck. 18006274368
thanks i hope this helps doctor video leading edge electronics 1987
May 03, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
