Question about Lexmark C540N PROD SPECS TBD Printer
Lexmark c540n leaving black marks on paper
My Lexmark c540n printer is leaving 3 black smudges down the left hand side of the paper - I was told it was a faulty toner but I have changed it and it is still doing it. Any ideas why please???
XboxModifier
  • 123 Answers
SOURCE: Paper has black marks only on the edge
hello, it sound like you might have whats called a black spot on the image drum, try print a few blank pages and see if it starts to clear up for you.
Posted on Feb 19, 2008
  • 2072 Answers
There are several issues that will cause a problem like that.
1, As X box mentioned is a problem with the drum. That is part of what is called the print cartridge or imaging unit. There is most likely a shutter or opening in the cartridge which you can shine a flash light at and see if the defect is visible. If so you will have to replace that cartridge. I would suspect that is the most likely issue.
2. There may be something in the paper path. A small piece of paper riped off in it, something else, a piece of tape, label, etc may have made it into the machine, that will make contact with the paper and smear the image.
3. Lastly, your fuser roller may be bad causing the reprint.
How to determine where the issue is, shut the machine off while it is printing and jam the paper in the image area. See if the defect is on the paper before the fuser. Eliminates the fuser ....
  • 25 Answers
SOURCE: Lexmark E232
If this model has separate toner and photoconductor then the photoconductor is at end of life and needs to be replaced. Follow the directions that come in the new photoconductor package to install and reset the PC count this is important.
Luck
Posted on Mar 11, 2008
SOURCE: Pringed Pages are coming out with yellow and blue smudges on edge
I have also had this problem which I solved by changing the photoconductors of the colours shown.
you can try this.I am not sure if that is the best solution but it solved my problem
Posted on Jun 18, 2009
  • 1684 Answers
SOURCE: Printer making marks down the left hand side of every page
hello,
This sounds like the photoconductor units for both black and blue need to e replaced. Open the front of the printer like you are changing toner cartridges. On the front door parts that opens to you there will e four pieces, 1 for each color. Look at the one with blue on it and the one with black and look on the ends of these, they are the photoconductor units. I bet both of the colors have worn sections compared tothe magenta and yellow ones. The replacement part number is C53030X and you will need 2 of these. They have a life span just like toner and have to be replaced too.
I hope this helps,
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Testimonial: "Spot on... solved the problem"
How do I correct black smudges when printing?
If the smudge marks are down the edges of the paper, the PC Kit needs replaced.
Feb 13, 2015 | Lexmark E232 Laser Printer
Lexmark c540n creasing paper
First, check the quality of the paper you are using. The fuser will heat the paper, it tends to give a wrinkled effect on the paper. Try a new ream of good quality paper, and if it still does the same, the fuser itself might be causing the issue and you might need to replace it. For further details, please contact our Technical Support Hotline on 1-800-539-6275.
Nov 24, 2012 | Lexmark C540N PROD SPECS TBD Printer
Lexmark printer is printing pages out with three black smudges on left margins
Best bet is to remove the cartriges, open all areas of the printer you can, remove the fuser. Then take a can of air and blow everything out. Reasemble the printer and run a few test pages. The smudges may be worse at first but should clear up. If this does not work, then try replacing the cartridges with a spare if you have one. If you find that it is a certain cartridge that is causing the issue, then you have a bad one. If it makes no difference at all, try to replace the fuser.
Feb 22, 2012 | Lexmark C540N PROD SPECS TBD Printer
Lexmark E120. When it prints it leaves a thick black smudge about 1/2-1 inch thick down the entire left side of the paper in waves. Is there away to clean something or replace something to correct this?
It's time to take your printer to a professional technician, to trouble-shoot and fix this problem,
if you don't know how to do this by yourself.
Jul 30, 2011 | Lexmark E120n Laser Printer
I've got a LEXMARK C540N. what's means "error 82"?
printing head problem mostlly black one nothing to do sorry :(
Dec 13, 2010 | Lexmark Office Equipment & Supplies
Black smudges on left side of printed paper about 3 1/2 inches apart
You have to order the lexmark photoconductors (C53034X) and replace them. it is easy. instructions in box.
Oct 05, 2010 | Lexmark C522n Laser Printer
Lexmark c532n prints smudges on page
The problem could be caused by the photoconductor units. Try to swap the affected photoconductor units (like swap the magenta with black and cyan with yellow). If problem still occurs, then the photoconductors need replacement. I suggest you contact Lexmark Technical Support for assistance. Thanks
Jul 26, 2010 | Lexmark C532n Color Laser Printer
Hi. Im having problems with the printing, every 4inches or so, on the right hand side of a printed page, the printing is very faded.
sounds like you have a bad drum... if you roll the paper in a cylinder and match up the faint spots you get the aproximate diamerter of the drum... call up lexmark support and see if they have a drum refresh option on their machine...
Dec 21, 2009 | Lexmark C540N PROD SPECS TBD Printer
Lexmark laser printer leaving a white streak 2-3
take a q-tip and clean the scanner window. this is located in a 3/16' opening on the roof of the printer cavity it will be about 8inchs long. pull the toner cartridge and feel with your fingers on the roof of the cavity this will be located above the transfer roller slightly towards the front of the printer. white lines like this mean the laser is being blocked usually by a bit of toner or other dirt of some kind
Nov 30, 2009 | Lexmark E232 Laser Printer
Lexmark C540N PROD SPECS TBD Printer Logo
174 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
