Question about Kenmore 63942 Dryer
Kenmore Electric Dryer Heating Problem
My Dryer information is as follow
Kenmore model # 110.62.972100 and Serial No. MMI 308776.
One time my dryer didn't produce heat and my clothes remain wet. After few hours when I turn on again it's worked properly! It was o.k for couple of days and than again it stopped producing heat. We tried after 2 days and again it's working but when we stopped and restart, it didn't work. What can be the cause?
  • punam2123 Oct 28, 2008
    Thanks for your reply. I checked ventilation. It's o.k. The air is comming with full flow and little bit warm but inside the drier everything cold. I think the next step is to check heating cercuit but I don't have resistance reading device. Can you see visually if heating element is blown or is there any ways u can determine? If that looks o.k than I will simply replace TCO/Thermostat set.
  • 5,911 Answers
Most heat related problems with dryers are attributed to poor air flow. I would start there first in determining if you have a ventilation problem BEFORE replacing any components. If you don't, and you have a clog somewhere, you will end up with the same problem and repeated failed components. The following link gives some useful advice on how to troubleshoot a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention the first major paragraph that discusses the ventilation. Follow the advice and attempt to run the dryer without the exhaust vent attached, first. If the dryer begins to heat, you may have gotten lucky and avoided any failed components. However, if the dryer still does not produce heat, you probably have blown a component in the heating circuit. More commonly, the thermal cut-out (TCO) blows. Make sure you check ALL heating circuit components before taking my word for it, just to be sure. Reminder: If the TCO is blown, it is highly recommended that you replace the hi-limit thermostat at the same time. In many cases, these components are sold as a set.
Go to searspartsdirect.com and type in your model number as "110.62972100". Look under the "Bulkhead" heading for item number 47 (This is the TCO/thermostat set I am referring to). Refer to this drawing as a reference for your component identification (the Heating Element is listed as item 14). I hope this information helps you. Let me know if you require additional assistance.
Posted on Oct 27, 2008
When was Kenmore dryer model number 11063942101 made?
The following link will take you to a website where you can type in your information and it will give you a time frame of when your dryer may have been made. You will also need your serial number as well.
Oct 16, 2014 | Kenmore 63942 Dryer
Kenmore dryer model 41791052000, SERIAL # XD1304969
first make sure the dryer vent is unplugged. then make sure you are getting voltage to the heating element.if you are getting voltage to the element then the element will need to be replaced, assuming the vent isnt plugged
Oct 24, 2007 | Frigidaire FEQ1442ES Electric Dryer
Kenmore dryer will not heat up to dry clothes. serial# MD0748533 mod# 97281100 72811
Your issue is as follows:
"the dryer works but there is no heat to dry the clothes.
Based on the information provided above, I am unable to provide a positive solution to your issue.
Following this LINK, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User's Manual.
Note: A volt-ohm meter is beneficial in performing electrical tests.
This information is for an electric, generic model dryer only!
My Solution is:
If your dryer doesn't heat, check these:
Temperature Switch; make sure a positive heat selection has been made, if still no heat, then check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house: Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element: Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse: On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring: A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Nov 26, 2010 | Kenmore Dryers
My dryer is no longer getting hot, I can only find a serial number, therefore having a hard time looking up my unit. Serial #MT0514392
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 13, 2010 | Kenmore 65942 Electric Dryer
My Kenmore dryer does not get hot enough to dry a load
If your dryer IS still heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire exhaust duct run to ensure you have no kinks or clogs anywhere. The following link explains many of the problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to actually overheat. Eventually, this can lead to component failures and is the source of fire hazards.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the door opening) and let me know. I hope you find this information helpful.
May 31, 2010 | Kenmore 62802 Electric Dryer
Dryer runs but wont heat
There are 2 possibilities for this problem.
1. The limit switch is out. The limit switch is located on the heating element on the back of the dryer. This is a small button type part. it will have 2 prongs on it for 2 wires that slide on for power.
2. The heating element is out. This will be on the back of the dryer and depending the model it should be a long metal piece that has metal elements inside of it to heat the dryer. or it could be a large round unit. these can be tested with an om meter.
The limit switch will be the cheapest to start with on replacing.
If you need further assistance please do not hesitate to ask. I will need the make, model, and the serial number of the unit to help you further. the model and serial number can be found by opening the dryer door and looking by the hings. there should be a sticker with this information on it.
Apr 13, 2010 | Kenmore 64852 Electric Dryer
Dryer isn't heating. It turns and blows air but
make sure lint screen and vents are clean. next shut off electric and check heat element for broken element. then get model # and serial # order and change thermocutoffs located on heater box and fanhousing ck these steps one by one
Dec 09, 2009 | Kenmore 75962 Gas Dryer
Dryer runs but heat is not coming on
I will be very happy to assist you in this issue as soon as you send me more information about your dryer.
its electric or gas dryer?
model n serial
thank you
Nov 14, 2009 | Dryers
No heat in kenmore series 80, model 85040
hello there:
here is some troubleshooting ideas for you to help
A dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty
Oct 26, 2009 | Kenmore Dryers
Kenmore 63942 Dryer Logo
130 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
