Wont turn on properly
Alba MP3256D10 wont turn on properly
Alba tablet black screen reset don't work and pressed the on and volume button
ALBa something, it has model number or sub name.'
googling that name,gets me nothing
what you said makes zero sense
try the full story
what does not work,computers have 1000s of ways to fail.
the screen is black. is our only clue.
this i can not understand
i can connect to my laptop and says device? works properly?
what laptop what device, connecting how?
if you turn on the ALBA
and it seems its ALIVE
use a flash light, to see if the LCD screen has data
if yes, the back ligting is dead.
but , what is an ALBA.
i can not tell what any person can fix.
in my shop it is taken apart and we check power to the screen first
if it dead,maybe the battery is toasted.
Feb 18, 2017 | The Computers & Internet
Cannot tune in my 19 inch Alba tv to main channels ie bbc and itv
POOR AERIAL SIGNAL, CHECK THE COAX JACK IS ON PROPERLY. NO OUTER STRANDS OF WIRE SHOULD BE TOUCHING INNER COPPER CORE. OR CHANGE CABLE & GO INTO THE BACK OF A SKY BOX TO THE TV, THEN RESCAN.
Jan 15, 2017 | Alba Televison & Video
Hello my 32' alba tv LCD32880H DF wont turn on. Instead of the standby light being lit as normal it is flashing
bad caps on power board.......
either repair caps or replace the board......
cheers
Nov 03, 2016 | Alba Televison & Video
ALBA MP3 PLAYER i format the drive but music wont playing in mp3 what to do?
MAKE SURE UR FILES ARE NOT DAMAGED IF THEY ARE DELETE THEM THEN DOWNLOAD THEM AGAIN
Mar 04, 2015 | Alba Clip MP3 Player Silver
My alba tv will go onto standby when I plug it in but it wont turn on when I try to turn it on with the tv remote
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 15, 2015 | Alba Televison & Video
Alba lcd42880f1080p
Could be a failing power supply
May 12, 2013 | Alba Televison & Video
Alba 32 inch tv when i turn it on the off/on light keeps flashing but the tv wont go on
check for a power supply failure, replaced capacitors with leak and bulged on its tops. that cause the dc output supply to drop.
Aug 13, 2012 | Televison & Video
I have been bought a Alba 1.8lcd MP3 palyer and have installed the cd it came with and it comes up in my computer but after ive put music on it and then go to play it it just says empty file ???
1. May be there is a particular music folder in which you have to copy the songs.
2. otherwise there is something wrong with the device and get it replaced.
Apr 04, 2011 | Computers & Internet
Help
Might be that Windows 7 does not support that webcam (yet).
You could try a driver finder tool to find a compatible driver.
Mar 17, 2010 | Computers & Internet
 Grubhead
Grubhead
