Question about JVC TH-A35 System
Radio Tuner problems
After a power fail, my home cinema TH-A35, keeps working, but something is wrong:
When I switch on unit, it always wakes up on radio tuner, no matter what function it was when switched off.
It shows on display "FM 00.0" and I cannot tune any station (it doesn't start finding frequencies.
Also, when I change speakers volume (rear speakers, center speakers and subwoofer), if I switch unit off, when switching it back on, it lost my speakers volume change.
All the rest seems to function normally. I guess it can be a software problem.
Any clue what could be wrong? How can I performe a reset? I mean a default factory reset?
Thanks
    Top Expert:
  • JVC Master
  • 26,256 Answers
Backup memory battery may be the cause.
Posted on Mar 27, 2017
  • 130 Answers
SOURCE: System unresponsive when modes are switched
Arnt they seperate things? ive seen some systems that dont function if thery are not in that mode. If its in DVD mode nothing on the DVD works, if its in the radio mode maybe the power changes over to the tunner only? you cant play both at once maybe their idea. Will things work when its in the cd mode? Is the unit staying cool?
Posted on Apr 13, 2006
bluenadas
  • 203 Answers
SOURCE: SUBWOOFER WON'T POWER ON (Grounding out???)
Check your cable that runs between the main unit and sub for bent pins. If they look fine there may be a short in the sub itself that is causing it to go in to shutdown.
Posted on Jun 15, 2007
  • 4234 Answers
SOURCE: PSU problem
The most likely problem is something dragging down the power. There could be a problem within the power supply as well. This is a "switch mode" power supply. That means that if the primary side does not oscillate correctly, you will get this cycling as well. These are hard to diagnose remotely. Typical power problems such as this run about $15 or so for parts plus the local labor rate if it is within the power supply. The parts cost will rise to the $30-$50 range if the output amp section is the problem.
Dan
Posted on Mar 28, 2008
SOURCE: jvc th m603 center unit - powered subwoofer
Yes go to JVC.com It will cost you $20.00
Posted on Mar 31, 2008
SOURCE: JVC th-m505 and dish network box sound level control problem
It's not your receiver, it's the Dish Network equipment, I have the same issue with my Onkyo...unfortunately I'm still researching the solution.
Posted on Nov 26, 2008
I have the PR240 2 way and no matter how many times I change and add new batteries it always acts the same: When I power on, it keeps scanning and the "mode" button does not work. Also and more...
did you spill something on your unit ? or did it get wet ?
If so try cleaning the keyboard contact area, this will solve your problem if it was contaminated and one of the keyboard switches is active due to contamination.
Good luck
Best regards Falco
Nov 02, 2013 | Cobra MicroTalk PR 240-2 (7 Channels)...
I have problem with my home cinema Panasonic home cinema SA-HT 870. I can't turn on. when i push the buton on/off i hear zzzzzzzzzzzzzzzzzzzzzz and i see on display EROR F61 and after 3 sec system is turn...
Hi
this error comes when you keep your device powered all the time.
Definition: power is constant to components always on so it heats up.
look for condensers that are popped up or seems to be
change it with same type and voltage
Description of Error Code. F61
State, Condition
When the power is turned on, the unit is automatically
turned off. The power does not turn on.
· Cause, Troubleshooting
Power circuit system failure and/or direct current flown to
speaker terminal
Good Luck
Nov 19, 2017 | Panasonic SC-HT740 System
The DVD player seems to immediately attempt DVD mode upon powering on, despite no disc being present. The display shows "ERROR, PRESS POWER OFF/ON TO RESTART" and no other action is possible...
You have an internal mechanical switch/sensor which failed and will need replacement.The reason it is giving this message because the sensor might have been stuck in a position when it was damaged. And also along with it some parts(semiconductors and capacitors needs to replaced too)need some checking too.
Jan 30, 2011 | JVC TH-A35 System
Marantz SR870 tuner not working
Make sure your FM antena connection is good. A receiver will not pick up an FM signal without an antena. Even a small piece of wire will work to test. If the Tuner section is bad, an external tuner can always be connected to an Aux input. Due to cost, it may not be cost effective to repair this unit.
Hope this helps.
Oct 08, 2009 | Marantz Audio Players & Recorders
Subwoofer switching off
have you checked all speaker conections? is the cooling fan working ?are you using the correct speakers supplied with the unit ? have you tried using headphone's if so could you then increase the volume .hope this helped.if you tried everything and are still having problem's i think the amps output transistor's or module is failing.you could try tapping the unit if you get a crackling sound you might have dry joints ..good luck farr64
Apr 29, 2009 | Televison & Video
PSU problem
Dan
Mar 28, 2008 | JVC TH-S5 System
NO SOUND From JVC TH-S5 Home cinema system
I know this is an old topic however someone somewhere might benefit from this feedback. I purchased the JVC TH-S5 service manuals from ManualsParadise.com and after metering all the supplies as 'OK', I then focused in on the 'common' lines associated with the two onboard power amps IC's (STK413-400) and found that they were missing a bias supply. This is derived from the onboard 40v Supply 'dropped' down by a 47 ohm resistor R2702 (rated 1/4 watt but advised to make this at least 1/2 watt). The resistor was found to be open circuit i.e. a very high ohmic value. Looking at the circuit diagram again, I would feel that this is going to be a common issue with this unit.
Mike.The.Cork
Jan 29, 2008 | JVC TH-S5 System
Unlock code for jvc dvd
hi if you can help me i have a dvd jvc th-a35 and it wont play all the dvds what is the number or how i can unlock to play all dvds
Nov 25, 2007 | JVC TH-A35 System
TH-A35 receiver
You can't get 5.1 sound from a MP3 source !!! You get a 5.1 sound only from a good STEREO (analog) source or from a REAL 5.1 DVD audio track. Also check your "Autosurrond" setting on the remote-control.
Sep 14, 2007 | JVC TH-A35 System
Error message upon powering on
Unplug it for 10 seconds then plug it in again
Apr 23, 2007 | JVC TH-A35 System
JVC TH-A35 System Logo
70 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
