Question about Samsung Compact MiniDV Digital Camcorder
How to connect my camera to a computer with only USB ports
I have a Samsung VP-D351 PAL digital camera and I can't find a cable to connect from the firewire port on the camera to the USB port on the computer.Can you tell me how to go about doing this please, Barry.
  • mdsl Nov 16, 2008
    how do I connect my camcorder (VP-D351) to my computer.
Buy a firewire adaptor for usb maybe??
Posted on Jan 18, 2009
When I connect My Samsung VP-D77i Camcorder to my Laptop I always get a message saying "cant open camera device". My Laptop does not have a fire wire port but only with USB ports. It has Windows 7 Pre
First, try attaching the camcorder via usb cable with the camera OFF, then turning it on. This may trigger Windows to activate the driver scanner and activate the driver. If you've been attaching with camcorder off, try attaching with it on, to see if that activates driver installation.
If that doesn't work, you may have a low-power usb plug; often the usb ports in the back of the computer put out more juice than the handy ones on the front. You may also need a shorter and more robust usb cable; I've found with various cameras and phones that certain usb cables work fine for recharging but won't necessarily provide adequate data transfer.
Jul 03, 2012 | Samsung VP-D77i Mini DV Digital Camcorder
Have a samsung mini dv digital-cam VP-D351 PAL and im trying to connected it to the computer but its not being recognised by the laptop. Thank you for any information that you can give
Have you installed samsung VP-D351 driver in your computer? If the driver already been installed, it may crashed and need new installation. If you had not istalled it before, you have to install it before pairing them.
The CD driver usually bundled in new VP-D351 package together with owner manual and service centre address.
Jun 28, 2011 | Samsung Compact MiniDV Digital Camcorder
Hi. what cebels i need to conect samsung vp-d351 digital-cam to laptop
You need a USB cable to connect this camera to your computer, to get the proper USB cable for it you can go to a new computer or electronic store near your place and take the camera with you and they can provide you the needed USB cable for it.
Feb 15, 2011 | Samsung Cameras
How do i connect samsung camcorder to tv and have sound? i have connected throught the video option but there is no sound through tv. There is no port on camcorder to connect the cable with the red,...
da61d5b.jpg This is the type of cable that you will need. The connector should be towards the front of the camcorder on the side that the tape goes in (if I remember correctly). The connector you are looking for is hidden under a cover. Hope this has helped you. www.austintelstarservices.com
Sep 02, 2010 | Samsung Video Cameras
VP-D351 need to connect with TV. What type of cable is required
Make sure your TV is a PAL unit. The easiest place would be to look in the owners manual. If you no longer have it, there should be a PDF format online. It should tell you what cable you need.
Dec 18, 2008 | Samsung Compact MiniDV Digital Camcorder
Model number vp-d351
i had same problem, solved it with replacing the lcd fpc lead (ribbon).this is the lead to the screen.it breaks after about three years.this is a common fault.. replacement part from Partmaster.co.uk or 0870 240 6603..part number..SAMAD9706489A. cost £11.40.. its easy to replace ..takes a little time.. i have emailed instructions to two others and they have sucessfully completer the task.. if i can help with instructions,please ask.. i have also purchaced a second ribbon for next time..(3 years time )..good luck stefan.
Nov 01, 2008 | Samsung Compact MiniDV Digital Camcorder
I have a samsung mini dv digital-cam VP-D351 PAL and im trying to connected it to the computer but its not being recognised by the laptop. Thank you for any information that you can give me.....
If you are running windows vista this will be the problem.There are no drivers for vista firewire..If other windows then try samsung support for required driver.
Sep 07, 2008 | Samsung Compact MiniDV Digital Camcorder
Samsung vp-d351
you have 2 differnet problems. white screen is a bad ribbon cable inside unit.. eject r is a bad tape transport. something broke inside or the tape transport is outta alignment.
Aug 06, 2008 | Samsung Compact MiniDV Digital Camcorder
Problems whit Samsung VP-D351 Visor and LCD in mode normal blur but in mode NITE PIX OK...? Some body knows..about this...is CCD Sensor...when repairthis....please
samsung vp-d351. lcd screen was bright white at first then suddenly went off (no picture). sound and everything else ok. can anybody help?
Aug 21, 2006 | Samsung Compact MiniDV Digital Camcorder
Samsung Compact MiniDV Digital Camcorder Logo
516 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
