Question about White Sewing 1418 Mechanical Sewing Machine
More questions about tension
I've read your instructions and I'm still a little lost. I have the long spring with the hook bit on the pin first. Next, I have the washer with the wing on the side of it on next, but I am not sure which way to orient it? it kind of clicks into place with the wing pointing away from me and the hook catch part at the top.
Next I have the bent washer then the straight washer, then the bent one again. (bent ones pointing away from eachother)
Then the heavy duty spring, then the washer with the bar across the middle, then the knob.... sadly its still not quite right.!?
Thanks! Have tried every combination...and just like you described. Still will not work! Cannot get an answer from White sewing Co requesting a photo of how it should be installed. Can anyone help?
    Habit-Forming:
    New Friend:
  • 6 Answers
Hi, you will need to place the two bent washer together letting the surface touch like the first c washer followed by the inverted c washer then then follow by the spring and finally the screw nub. use the sequence and revert. alternatively send the pix of what u have and label them accordingly so that i can guide u better.
thanks
Posted on Oct 10, 2017
    President:
  • 2,712 Answers
Here is a video tutorial on how to use the 1418:
http://www.whitesewing.com/download/1418.wmv
Or you could try calling their customer service at 1-800-331-3164 to obtain a manual. If you prefer to write:
Mail to:
White
Attn. Customer Support
31000 Viking Parkway
Westlake OH 44145
Hope that helps!
Posted on Oct 27, 2008
  • adams hope
    adams hope Oct 10, 2017
    mail to me at hopeadams01@yahoo.com
    Scholar:
  • 155 Answers
Can i get the exact model number and details of ur device
How do I thread a kenmore sewing machine model #117812
For the top thread, make sure that the needle is fully up. With the spool on the spool pin. Bring the thread in front and under the first hook and then under and behind hook two. Bring the thread down and under the third point below the spring eyelet. Bring the thread up until hooks into that spring eyelet. Continue up and get the thread into the hole in the take-lever from back to front. Bring the thread down to the needle clamp thread guide and hook it into the guide. Finally pass the thread through the needle from left to right.
The manual for the 117.812 is the same as that for the 117.552. Manuals Lib has this manual here: https://www.manualslib.com/manual/1050640/Kenmore-117-552.html . The threading diagram and instructions are on page 4, https://www.manualslib.com/manual/1050640/Kenmore-117-552.html?page=4#manual . See the later pages for winding and setting up the bobbin. The pictures may help more than the verbal description.
I hope this helps.
Nov 04, 2016 | Kenmore Sewing Machines
Tip
Sewing Tips for Beginners
1. Sewing Pins are essential
2. And how about a cute little Pin Cushion to hold those pins.
3. Before getting started it's best to Understand About Fabric Grain.
4. Knowing All About Sewing Machine Feet is essential.
5. Finish Seams without a Serger
6. Gather Fabric easily.
7. Serger owners can Gather Fabric on a Serger.
8. Making Bias Tape is sewing simple.
9. Attaching Bias Tape ~ even easier!
10. Once you've mastered Bias Tape, Making and Attaching Piping is the next step.
11. Shirring Fabric with Elastic Thread ~ tons of bang for your buck.
12. Attaching Buttons with a Sewing Machine
Best Sewing Machine Reviews 2018 The Ultimate Buyer Guide iSewing Machine
on Oct 13, 2017 | Brother Sewing Machines
Why did my thread take up spring break? And what do I do now?
Type www.fixsewingmachine into your web browser and when page comes up, click on yellow section left-hand side of that site page titled TIPS. All FREE info, instructions, videos. Jimmy
Apr 04, 2012 | Sewing Machines
I need instructions on replacing the thread take up spring Juki DDL 8700
contact a juki dealer to see if they can give instructions
Jan 31, 2012 | Juki DDL-8700
Sewing machine
The top thread is probably breaking due to the bobbin thread tangling.
First-off fit a new needle .... do that anyway ! And if you haven't recently cleaned your machine (and you should do it every week as a minimum), clean-out under the stitch plate, remove the hook, clean the hook race and give it a small drop of oil, even if you're using the lightweight plastic hook/shuttle. Check that you have adequate bobbin tension ... when you pull the thread out of the bobbin case there should be a bit of resistance --- technically, this should be set-up using the correct tool and a set of weights, but if there is no, or very little resistance, you need to increase the bobbin tension a little bit at a time using the small screw that holds the tension spring down onto the bobbin case. This is a very fine adjustment, so you may find you only need to turn the screw less than a quarter turn to get it right. Ensure that, when you thread the top thread up, you do-so with the foot lifted so that the thread goes down properly between the top tension discs.If you're still not getting anywhere, check the basic timing/needle depth by looking at some of my other posts on the subject.
Nov 26, 2011 | Bernina Activa 140
I'm having trouble getting the bobbin tension correct. I have followed instructions in the manual but still have problem with birds nest underneith.
You should not need to adjust the tension on the bobbin case for this model at all. The problem is more likely to come from your top thread being insufficiently tensioned if you are getting threads looping on the underside of the fabric.
Here is my trouble shooting suggestions and the general things on threading up apply to most sewing machines.
Check the top threading up, you need the thread to go through all the thread guides but in particular, the thread take up lever and the top tension discs are critical. Always thread up with the pressure foot raised as this opens up the tension discs so the thread can seat in fully. Set top tension dial on 4. Once youve got the thread down to just before the needle, lower the pressure foot and pull the thread, it should be really firm and hard to pull. If it isn't then recheck the threading into the tension device again. If you can't get tension at all, then this device is faulty and will need to be serviced.
Also, if you have never cleaned your tension discs, its a good idea to give them a clean every month or so. To do this, turn tension dial to zero, then "floss" between the discs using the selvage edge of a clean piece of cotton fabric offcut, sometimes you can get build up there of dye particles or thread fibres, especially if you use some cheaper cottons that are very "hairy". Remember to reset tension to 4 when you are done cleaning.
Next, remove your bobbin from the bobbin case and make sure there are no threads looped around the hook or caught in this area. If you can see a stray thread, then unscrew the needle plate (two screws) and take it off. Lift out the bobbin holder, it will come up and and out towards you. Using your little brush that came with your machine, brush out the hook carefully, removing any lint or thread bits. Also check the bobbin case itself and brush it out everywhere and check that no thread piece is caught into the tension spring on the case. Also check the case itself for any damage or piercings from your needle (if the case dislodges during a jam up it may swing and the needle strike it). If there is damage, you can file it out with an emery board.
Replace the case back into the machine, it has a flat side that goes to the back of the machine and a mark which should match up with the stopper in the machine, two red arrows to match.
Now, look at your bobbin, is it wound smoothly and evenly or a bit of a birds nest itself. If it is not an even wind, then pull the thread off, and do it again. The thread needs to come from the thread spool, across to the tension disc on top, then back to the bobbin spindle so it is tensioned as it winds onto the bobbin. Please read my bobbin winding tip here http://www.fixya.com/support/r10598580-winding_bobbin_correctly for more on this, it is important.
You can now replace your needle plate and screw it down and drop in your bobbin making sure it turns anticlockwise when you pull the thread tail. You always want the thread to come off the bobbin, then reverse direction in a "V'as it comes out of the case. Now take the thread tail around the outside of the bobbin case moving it clockwise until it does into the little groove on the side, then press down on it until it clicks into the tension spring. Pull upwards to check it is into tension. If it comes out again, it wasn't in fully; repeat until it is fully into the spring.
Use your needle up down function while holding the top thread to draw the bottom one to the top, then put the clear cover back in position covering the bobbin.
Try stitching again; please always hold the two threads firmly at the start of a new seam, to ensure the threads don't get pulled down into the hook as this will cause a thread jam.
Hopefully one of the above will resolve the birdsnesting problem, that does really sound like no top tension happening. Feel free to post again if its still not resolved.
Happy stitching
Nov 07, 2011 | Janome 1600P-DB Mechanical Sewing Machine
I can't replace the shuttle hook.
I'm dealing with the same issue. I just now returned to the machine and got the blankety blank thing back in. I find I have to manually lift the metal bar that runs across the shuttle race, and then get lucky. Please keep me in your prayers. I'm under the gun on a Halloween costume, and can't afford the down time. I'm using an embroidery font, and in the home stretch, having thread bunch and break, so am having to clean the bobbin area frequently. Grrrr. Had this machine 10 years. When it's good, it's very good. When it's bad, it's horrid. Good luck and happy sewing.
Oct 21, 2011 | Sewing Machines
My needle thread keeps breaking. I've tried different thread (top and bobbin), a new needle, and I opened up the bottom plate to clean out lint. I have also tried adjusting the thread tension.
Are you sure you have got the top thread threaded correctly including the take up lever? Start at the thread spool and follow the thread all the way through the thread path checking that it is not snagging on anything enroute and that the thread is correctly through the tension device. Also tension dial should be on 4-5, if its higher this could be breaking the thread. YOu should not need to adjust top thread tension more than a half increment at any time.
Other possibility is that the bobbin holder under the needle plate has moved out of alignment and then the top thread is catching there as it goes around the hook.
If you check your manual it should give you instructions on removing the needle plate (2 screws need to come out), then you can lift the bobbin case out towards you, clean underneath with your little brush, then reinsert it. There are two little red marks on the right side of the bobbin case and a stopper, these need to be lined up. Then put in bobbin and rethread into tension spring, replace needle plate, bobbin cover, and test stitch.
Hopefully one of the above is causing the thread to break.
Aug 02, 2011 | Janome Memorycraft 6500P Computerized...
How do i install a bobbin in a toyota rs2000 please
Your machine has a removable bobbin case and vertical rotary hook (front loading) so it is very alike to many other machines in that you insert the bobbin into the bobbin case in a clockwise direction, pull the thread into the tension spring on the case, then place the case into the front of the rotary hook while pulling out the little latch on the case, then release it to secure into the rotary hook. The latch usually goes into the "12" position on the rotary hook, there should be a little indentation for it.
If you go to this page https://sewing.aisin.com.au/upload/1255582851068_file_RS2000SD2D3D.pdf you can download Toyota RS2000 manual and full instructions and drawings are there about page 8.
If you go to www.sewing.about.com, http://sewing.about.com/od/sewingmachineindex/ss/windbobbin.htm there is lots of helpful sewing machine pages too, general threading up, trouble shooting and getting the right needle for the job. How you wind the bobbin is important and you need to put it into the bobbin case the right direction so the thread comes off the bobbin then reverses direction through the tension spring.
Great video on You tube too which should help you http://www.youtube.com/watch?v=KHl-j4pYx4I
visually its so much easier than trying to describe the steps. But once you've mastered a bobbin case and bobbin system, they are all very similar between makes and models.
Jul 25, 2011 | Sewing Machines
How to thread a singer feather weight machine
  1. To begin threading the Featherweight, use the third photo below as a guide.
  2. Put a spool of thread on the thread spindle
  3. Pull the free end of the thread to the left across the top of the machine and hook it over the thread guide (number 1)
  4. Pull the thread down and under (from right to left) the tension discs. (number 2)
  5. Hold on to the spool of thread to create tension on the thread, and pull the thread so in puts pressure on the thin wire called the “take up spring" (number 3). The uptake spring is part of the tension knob device.
  6. Pull the thread up making sure it passes behind the metal bar thread guide. (number 4)
  7. Pass the thread from right to left through the hole in the take-up lever (number 5).
  8. Refer to photo number 4 for the remaining instructions. Guide the thread down and hook it behind the thread guide (number 6).
  9. Then hook the thread behind the next thread guide located at the bottom of the chrome face plate (number 7).
  10. Hook the thread behind the thread guide on the needle bar assembly (number 8)
  11. Finally, thread the needle from right to left.
Jan 16, 2010 | Sewing Machines
White Sewing 1418 Mechanical Sewing Machine Logo
107 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
