Question about Konica Minolta bizhub C250 All-In-One Laser Printer
How to print onto smaller paper
Cannot print onto compliment slip ie size w205mm x h 97
  • Gillian Sutherland Feb 21, 2012
    It just does not seem to recognise paper size for some reason and comes out the wrong way. I have tried changing to landscape from portrait but that does not work either. Thanks for your help anyway.
  • Anonymous Mar 26, 2014
    I am having trouble printing with compliment slips (DL size) in landscape format. Can you assist?
Under printer setup select your print, then change the paper size in the settings to the paper you're using.
Change the alignment of the paper feed on printer to the size of the new paper
Posted on Feb 21, 2012
Tip
Lexmark laser paper jams and wrong size paper reporting
the quickest way to find out if your paper jams are due to wrong size paper reporting is to print the network status page.
This page is outline with a line that runs 1/2inch from the edge all the way around the outer edge.
if the box of this page prints smaller than the letter size paper the paper reporting is smaller than 8 1/2 x 11 and if the line at the bottom of the page is missing its reporting a size larger than 8 1/2 x 11 either of these occurances willl be the cause of your paper jams
on Jun 07, 2010 | Office Equipment & Supplies
Is there anyway to print onto A7 size paper on this printer?
yes-
you can print 2 A7 pages onto 1 A6 page and then manualy cut the page in half- hey presto 2xA7 prints
Dec 11, 2013 | HP Laserjet CM2320nf All-In-One Color...
Up to what weight paper can I use in my HP Color Laserjet 2600n
Usually you can print up to about 60lb paper. You may be able to go as high as 90-110 (card stock) if the paper print path is straight thorugh. If you printer has a rear paper door then you can try heavier paper. Usually 40-60 is safe for printer without a rear door/heavy paper path.
The problem is that the heavier paper cannot bend around the rollers inside. So if it is setup to allow heavy paper it runs through flat and out the back instead of curling around and out the top as normal.
Apr 17, 2010 | HP Color LaserJet 2600n Printer
Samsung CLP300 jams when normally printing, but will print test
If you are using a 6cm paper to print that is smaller than a A4 size paper.
do a check when you print did you select the correct paper size. as wrong paper size is print will course paper jam too.
Apr 08, 2010 | Samsung CLP 300 Laser Printer
On my 2265+ I will be printing and I recieve "paper width error" press online to continue
The "paper width error" indicates you are printing out side the area of the paper. ie the document you are trying to print is wider than the physical width of the paper you have in the printer.
The printer displays this error to give you the opportunity to remedy the problem as printing outside the area of the page may be undesirable;
  • Data printed outside the area of the paper will be lost, you will not see this information you printed on the paper.
  • You may shorten the life of the print head by printing on the platen with no paper to protect the print head.
I would recommend the following;
  1. Check the size of paper selected on the computer system, or ensure the data print width is the same or smaller than the actual paper size used in the printer.
  2. If it is not possible to change document size on the system or if the printed outside the paper width are not required or are simply spaces (ie no print) you may wish to turn of the paper width sensor so the edge of the paper is not detected and the error is no seen, the paper width sensor can be disabled in the following way.
  • Power printer OFF
  • Hold down the ONLINE button and power the printer ON, keep the ONLINE button held down whilst the printer powers on and initializes.
  • Release the ONLINE button when you see ASCII80 and ASCII 136 along the top line of the display.
  • Press BUTTON 4 (under NEXT) repeatedly until you see the APW option along the top line of the display.
  • Press the button directly under APW
  • Press BUTTON 2 or 3 to toggle the APW setting to OFF
  • Press the button under SET (button 1)
  • THen power the printer OFF and after a few seconds back on again.
The above actions will disable the Paper Width Sensor and you will no longer see the Paper Width Error, be aware you may be losing data and or shortening the life of the print head.
Jan 07, 2010 | TallyGenicom 2265+ Matrix Printer
HP C7280 does not print straight, ie the print is angled on page
There is no way that a printer prints out of alignment unless the paper slips enroute. Meaning that the rollers are not holding the paper tight and the guides not pressing the paper snugly, as you put it. So, it could either be the rollers not aligned to each other properly or the guides not pressing the paper equally. The print head moves on a steel rod which is straight. So that can not be the culprit as the print head has to move in a straight line, irrespective of the paper being straight or slipped. So, that leaves us with the slipping paper for which there are the rollers and the guides. If you feel that the tension in the guides is not equal, then change the guides, else the rollers need a closer look. Or at least clean them with a damp soft cloth and allow them to dry up before using them.
Nov 04, 2009 | HP Photosmart C6180 All-In-One InkJet...
I'm trying to print some photos on 4 x 6 paper. i selected notecard paper size, but the printer keeps printing the 4 x 6 photo on 8 1/2 x 11 paper.
Are you telling the printer to use the smaller paper?
If it has 2 sizes it will keep using the last size used unless you tell it to change.
Sep 27, 2009 | HP Photosmart 3210 Printer
How to print pictures on smaller pieces of paper
If you go to your Printer properties advanced tab,
or preferences tab, toolbox where ever in your o/s,
main page, paper type, click the little down arrow,
choose from many sizes, at the bottom user defined size, choose your own sizes.
Hope this helps
Regards.
Apr 14, 2009 | Office Equipment & Supplies
How is 4" x 6" paper loaded?
There are settings that should allow you to specify the page size usually in the printer program that is installed on your computer as well as if you were using your printer as a stand alone device ,it will not be a problem with your Mac or printer but perhaps the instruction menu not been user friendly , I suggest you look at your printer settings in trouble shooting under paper loading etc or paper size as even the very cheap printers allow for smaller paper sizes even envelopes .You might try the print preview which should let make changes if need be .
Aug 07, 2017 | Epson Stylus Photo R200 InkJet Printer
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
101 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
